  3. My own board (50mm x 30mm)
133 Posts 22 Posters 122.0k Views 21 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    @Carl-H It is part of the expansion connector.
    I added more info on the OpenHardware.io site.
    • rmtuckerR
      rmtuckerR
      rmtucker
      wrote on last edited by rmtucker
      #114
      Ok my boards arrived from DirtyPCB.
      A couple of questions:-
      1.I am not using NR2 (The radio socket that protrudes),Also i am using the internal osc and not the xtal.
      So can i leave out C9,NR2 Socket,C5,C6,Xtal ?
      2.What are C2,C3 doing.
      The socket for the cpu i have fitted will not let me squeeze them in.
      Should i solder them in underneath or can they be left out?
      • BartEB
        BartEB
        BartE
        @mtucker
        1. Yes you are right about leaving out these components, but if you use NR1 i should leave out C8 and keep C9 (mount the decouple C's as close to the decouple component as possible)
        2. these components are for decoupling the uP. You can mount them at the bottom, do not leave the out.
          I used a tip from earlier in this forum thread for gaining a little bit more space when using these
        Cheerz
        • GertSandersG
          GertSandersG
          GertSanders
          #116
          @BartE answered perfectly. You can leave out C5,C6 and XTAL if you use the internal oscillator. C9 is for the NRF24, no matter if you use NR1 or nR2 socket. And yes, you only need 1 socket, so if you use NR1, no need to add NR2 (and vice versa).
          Socket NR2 is for the longer (and power amplified) radio with external antenna, NR1 was intended for the standard NRF24L01+ with PCB antenna.
          C2 decouples AVCC (the analog power input), just as C1 decouples the VCC (digital) power input. C3 stabilises the analog reference input. If you do not use the analog->digital conversion, you could skip C3 as well.
          I also do not use standard 28 pin sockets, but strip sockets just like BartE.
          In the image here I used a standard socket, but cut away the middle "bridge" to allow mounting the decoupling capacitors.
          https://www.openhardware.io/uploads/568faa0cbaba42246aa57103/image/IMG_7527.jpg
          In the image below I use the strips BartE mentioned:
          https://www.openhardware.io/uploads/568faa0cbaba42246aa57103/image/IMG_7686.jpg
          More images and details are here:
          https://www.openhardware.io/view/5/Battery-based-atmega328p-sensor-no-SMD
          • rmtuckerR
            rmtuckerR
            rmtucker
            I am pulling out what hair i have left.
            All i am getting is this:-
            find parent
            send: 253-253-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
            find parent
            find parent
            find parent
            find parent
            find parent
            Init complete, id=253, parent=255, distance=255
            Battery:3.161 Batt%:90 Temperature:21.73C Humidity:56%
            find parent
            • sundberg84S
              sundberg84S
              Node 253 tries to connect and fint its way to the gateway (find parent) but doesnt get any respons.
              Do you have a working gateway - what does the gateway log looks like?
              • rmtuckerR
                rmtuckerR
                rmtucker
                Yes the gateway has been working fine.
                I will connect the gateway back up to the computer and see what it is saying and let you know.
                • GertSandersG
                  GertSandersG
                  GertSanders
                  Which controller are you using?
                  • rmtuckerR
                    rmtuckerR
                    rmtucker
                    Sorry Guys seems the aerial was not tight enough on the Gateway,All working great now.
                    • rmtuckerR
                      rmtuckerR
                      rmtucker
                      Hmm thats a little worrying,Both sensors are not enclosed sitting in fresh air next to each other.
                      10% away from each other seems a lot.
                      I am awaiting a delivery of more SI7021 sensors let's see where that takes us??
                      0_1454372709451_Screenshot from 2016-02-02 00:21:23.jpg
                      • G
                        G
                        gloob
                        Are these identical sensors?
                        I have 10 sensebender micros with a SI7021 sensor and they show completely the same values.
                        • rmtuckerR
                          rmtuckerR
                          rmtucker
                          No
                          One is an si7021 running on the board in this thread.
                          The other is a HTU21D running on a pro micro that i already had set up and running.
                          • alexsh1A
                            alexsh1A
                            alexsh1
                            @GertSanders
                            I have been struggling to upload photos in the openhardware section of your node and I think it is better if we move our discussion here. Take a look at these:
                            This is my answer to the problem, but I think we can have a neater solution by having jumpers deciding on SDA/SDL pin out ?
                            • alexsh1A alexsh1
                              @GertSanders
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @alexsh1 There is indeed a better solution, the next version of this board will allow swapping the I2C data and clock pins :-)
                              alexsh1A rmtuckerR 2 Replies Last reply
                              • GertSandersG GertSanders
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @GertSanders
                                Other than that I have not been using the JST connector - this may save some space unless you want to leave it as a power backup. I never used the second row pins (behind the FTDI connection) and some of them are not accessible if using a sensor connected via I2C.
                                  @gloob There are two connections on the board to allow soldering the battery holder. Both the AA and AAA versions I use have the same pin spacing (seems standard), so you can use an AA battery holder as @alexsh1 does, or an AAA as I have.
                                  http://forum.mysensors.org/uploads/files/1446751714416-image.jpeg
                                  The red arrows show where the batteryholder pins should go. If you have individual AAA battery holders, then the pins surrounded by yellow circle are also used to connect the batteries in series. If the battery holder holds 2 batteries, then only the pins pointed to by red arrows are used.
                                  The PLUS sign next the the pin on the lower right of the above image is for the LED, the polarity of the pins from the battery is marked on the silkscreen of the bottom side. Looking at it from the top side, the pin above right is for Positive, the pin on below right is for Negative (or GND).
                                  Jumper J2 is to connect the IRQ pin from the NRF24 to pin 2 (INT0) of the atmega328. You could also use that to connect a switch between the top jumper pad (connected to pin 2) and the extra ground pin of C5, to use with a doorswitch. I have used this with the internal pull up, but that would not be very good for the battery-use. It is better to use a 1MOhm pull up resistor wich can also be connected using the extra hole connected to pin 2 and Vcc
                                  rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  #128
                                    rmtuckerR
                                    rmtuckerR
                                    rmtucker
                                    @GertSanders
                                    I have been running these boards for some time now and overall very easy and compact.
                                    And battery life on 2 AA batteries is years.
                                    But i still have problems with deadspots in the house etc.
                                    So i thought i would try changing the radio's to rfm69w and make another serial gateway with an rfm69hw.
                                    I have received some of the hallard nrf to rfm adapter boards which i believe can be plugged straight in
                                    What i would like to know is,Would it be ok to use one of these boards as a serial gateway with an ftdi adapter?
                                    I am using the board barebones with no external crystal etc at 8mhz.(would this be a problem for a gateway?).
                                    This would save on a lot of wiring (Level shifters etc).
                                    alexsh1A 1 Reply Last reply
                                    • rmtuckerR rmtucker
                                      @GertSanders
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @rmtucker I'm using rfm69w with @GertSanders board (I think it is v1-1) via the same adapter you ordered. You need to solder IRQ pad in order for the board to work with rfm69. I tried to compile both a gateway and a sensor code and it worked. No need to have a crystal if you have the right bootloader on atmega328p. With or without crystal does not matter for radio. Radio has got its own crystal
                                      rmtuckerR 1 Reply Last reply
                                      • alexsh1A alexsh1
                                        rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        Wonderful just what I wanted too hear.
                                        But could you elaborate on the irq soldering?
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @rmtucker just check out how to connect rfm69 to atmega328. @GertSanders luckily designed the board to be universal- there is a solder pad to connect D2 to IRQ, which you need to solder to use rfm69
