  3. My own board (50mm x 30mm)
133 Posts 22 Posters 122.0k Views 21 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    #111
    @Carl-H To use the board with AA batteries you do NOT need to place the AMS1117. But you will need to short the jumper "BAT" which you will find on the same surface as the AMS1117 if you want to feed the NRF24 with the same power.
    The batteries are connected to the Vcc power line. The NRF24 is connected to the 3V3 power line. There is no interconnection, unless you use the AMS1117 or you short the jumper "BAT".
    The AT24C's are optional. If you do plan to use them, you will also need to place the I2C pull resistors and you will need to short the jumpers RSCL and RSDA. These two jumpers connect the pull-up resistors to the SCL and SDA lines.
    If you use a sensor connected to the pins SCL/SDA of the extension connector you sometimes have no need for pull-ups as the sensor itself has them.
    The jumpers SCL-SDA and SDA-SCL are there to allow switching the signals of the SCL/SDA pins on the extension connector. The jumper closest to the board edge is for the pin on the very edge of the connector, the jumper close to the ATSHA is for the second pin. Without shorting these two jumpers, the pins on the extension connector have no function.
    Some sensor-boards have a SDA-SCL-GND-3V3 connector, others have a SCL-SDA-GND-3V3 pattern. The jumpers are there to be able to use both types.
    • Carl HC
      Carl HC
      Carl H
      Thanks for your clear explication! I have another question, where is the FTDI port ?
      • GertSandersG
        GertSandersG
        GertSanders
        @Carl-H It is part of the expansion connector.
        I added more info on the OpenHardware.io site.
        • rmtuckerR
          rmtuckerR
          rmtucker
          wrote on last edited by rmtucker
          #114
          Ok my boards arrived from DirtyPCB.
          A couple of questions:-
          1.I am not using NR2 (The radio socket that protrudes),Also i am using the internal osc and not the xtal.
          So can i leave out C9,NR2 Socket,C5,C6,Xtal ?
          2.What are C2,C3 doing.
          The socket for the cpu i have fitted will not let me squeeze them in.
          Should i solder them in underneath or can they be left out?
          • BartEB
            BartEB
            BartE
            @mtucker
            1. Yes you are right about leaving out these components, but if you use NR1 i should leave out C8 and keep C9 (mount the decouple C's as close to the decouple component as possible)
            2. these components are for decoupling the uP. You can mount them at the bottom, do not leave the out.
              I used a tip from earlier in this forum thread for gaining a little bit more space when using these
            Cheerz
            • GertSandersG
              GertSandersG
              GertSanders
              #116
              @BartE answered perfectly. You can leave out C5,C6 and XTAL if you use the internal oscillator. C9 is for the NRF24, no matter if you use NR1 or nR2 socket. And yes, you only need 1 socket, so if you use NR1, no need to add NR2 (and vice versa).
              Socket NR2 is for the longer (and power amplified) radio with external antenna, NR1 was intended for the standard NRF24L01+ with PCB antenna.
              C2 decouples AVCC (the analog power input), just as C1 decouples the VCC (digital) power input. C3 stabilises the analog reference input. If you do not use the analog->digital conversion, you could skip C3 as well.
              I also do not use standard 28 pin sockets, but strip sockets just like BartE.
              In the image here I used a standard socket, but cut away the middle "bridge" to allow mounting the decoupling capacitors.
              https://www.openhardware.io/uploads/568faa0cbaba42246aa57103/image/IMG_7527.jpg
              In the image below I use the strips BartE mentioned:
              https://www.openhardware.io/uploads/568faa0cbaba42246aa57103/image/IMG_7686.jpg
              More images and details are here:
              https://www.openhardware.io/view/5/Battery-based-atmega328p-sensor-no-SMD
              • rmtuckerR
                rmtuckerR
                rmtucker
                I am pulling out what hair i have left.
                All i am getting is this:-
                find parent
                send: 253-253-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                find parent
                find parent
                find parent
                find parent
                find parent
                Init complete, id=253, parent=255, distance=255
                Battery:3.161 Batt%:90 Temperature:21.73C Humidity:56%
                find parent
                • sundberg84S
                  sundberg84S
                  Node 253 tries to connect and fint its way to the gateway (find parent) but doesnt get any respons.
                  Do you have a working gateway - what does the gateway log looks like?
                  • rmtuckerR
                    rmtuckerR
                    rmtucker
                    Yes the gateway has been working fine.
                    I will connect the gateway back up to the computer and see what it is saying and let you know.
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      Which controller are you using?
                      • rmtuckerR
                        rmtuckerR
                        rmtucker
                        Sorry Guys seems the aerial was not tight enough on the Gateway,All working great now.
                        • rmtuckerR
                          rmtuckerR
                          rmtucker
                          Hmm thats a little worrying,Both sensors are not enclosed sitting in fresh air next to each other.
                          10% away from each other seems a lot.
                          I am awaiting a delivery of more SI7021 sensors let's see where that takes us??
                          0_1454372709451_Screenshot from 2016-02-02 00:21:23.jpg
                          • G
                            G
                            gloob
                            Are these identical sensors?
                            I have 10 sensebender micros with a SI7021 sensor and they show completely the same values.
                            • rmtuckerR
                              rmtuckerR
                              rmtucker
                              No
                              One is an si7021 running on the board in this thread.
                              The other is a HTU21D running on a pro micro that i already had set up and running.
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                @GertSanders
                                I have been struggling to upload photos in the openhardware section of your node and I think it is better if we move our discussion here. Take a look at these:
                                This is my answer to the problem, but I think we can have a neater solution by having jumpers deciding on SDA/SDL pin out ?
                                • alexsh1A alexsh1
                                  @GertSanders
                                  GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @alexsh1 There is indeed a better solution, the next version of this board will allow swapping the I2C data and clock pins :-)
                                  alexsh1A rmtuckerR 2 Replies Last reply
                                  • GertSandersG GertSanders
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @GertSanders
                                    Other than that I have not been using the JST connector - this may save some space unless you want to leave it as a power backup. I never used the second row pins (behind the FTDI connection) and some of them are not accessible if using a sensor connected via I2C.
                                      @gloob There are two connections on the board to allow soldering the battery holder. Both the AA and AAA versions I use have the same pin spacing (seems standard), so you can use an AA battery holder as @alexsh1 does, or an AAA as I have.
                                      http://forum.mysensors.org/uploads/files/1446751714416-image.jpeg
                                      The red arrows show where the batteryholder pins should go. If you have individual AAA battery holders, then the pins surrounded by yellow circle are also used to connect the batteries in series. If the battery holder holds 2 batteries, then only the pins pointed to by red arrows are used.
                                      The PLUS sign next the the pin on the lower right of the above image is for the LED, the polarity of the pins from the battery is marked on the silkscreen of the bottom side. Looking at it from the top side, the pin above right is for Positive, the pin on below right is for Negative (or GND).
                                      Jumper J2 is to connect the IRQ pin from the NRF24 to pin 2 (INT0) of the atmega328. You could also use that to connect a switch between the top jumper pad (connected to pin 2) and the extra ground pin of C5, to use with a doorswitch. I have used this with the internal pull up, but that would not be very good for the battery-use. It is better to use a 1MOhm pull up resistor wich can also be connected using the extra hole connected to pin 2 and Vcc
                                      rmtuckerR
                                      rmtuckerR
                                      rmtucker
                                      #128
                                        rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        @GertSanders
                                        I have been running these boards for some time now and overall very easy and compact.
                                        And battery life on 2 AA batteries is years.
                                        But i still have problems with deadspots in the house etc.
                                        So i thought i would try changing the radio's to rfm69w and make another serial gateway with an rfm69hw.
                                        I have received some of the hallard nrf to rfm adapter boards which i believe can be plugged straight in
                                        What i would like to know is,Would it be ok to use one of these boards as a serial gateway with an ftdi adapter?
                                        I am using the board barebones with no external crystal etc at 8mhz.(would this be a problem for a gateway?).
                                        This would save on a lot of wiring (Level shifters etc).
                                        alexsh1A 1 Reply Last reply
                                        • rmtuckerR rmtucker
                                          @GertSanders
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @rmtucker I'm using rfm69w with @GertSanders board (I think it is v1-1) via the same adapter you ordered. You need to solder IRQ pad in order for the board to work with rfm69. I tried to compile both a gateway and a sensor code and it worked. No need to have a crystal if you have the right bootloader on atmega328p. With or without crystal does not matter for radio. Radio has got its own crystal
                                          rmtuckerR 1 Reply Last reply
