  3. WiFi gateway, MQTT, openhab
10 Posts 5 Posters 4.9k Views 3 Watching
  • M Offline
    M Offline
    moskovskiy82
    I have finished building a wifi gateway as instructed. Now facing a simple problem as it seems a small lack of documentation is in there.
    Sensors transmit data via nrf24 to the wifi gateway. Which than encapsulates it into some tcp-ip and sends it straight to the network?
    So to make this work with openhab i need some intermidiate translator which will receive the data and transfer it into MQTT which openhab can understand?
    Can this translator be installed onto the same system as openhab? Any plans onto bringing MQTT into the wifi esp code?
    • dakkyD Offline
      dakkyD Offline
      dakky
      http://www.mysensors.org/controller/openhab
      OpenHab support only Serial GW or mqtt. So this leaves you to 3 options:
      1. Use the serial GW: connect your arduino GW directly to yout openhab host (raspi?)
      2. Use the Mqtt sketch: In this setup the arduino serves as mqtt broker
      3. Use the mqtt CLIENT sketch: IN this setup, your arduino acts as mqtt client and delivers message (sensors values and commands) to an external mqtt broker
      I personally prefer option 3:
      • easier to debug (read messages directly on the broker)
      • more flexible, u can send 3dparty messages to the broker (from scripts, hardware which supports mqtt etc) and deliver them to openhab
      Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
      Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
      Software: MySensors 2.0development
      • M Offline
        M Offline
        moskovskiy82
        Well 3 seems the way to go than..
        So all i need to do is compile (with options in the sketch changed) and upload the sketch to ESP8266?
        Sketch:
        • dakkyD Offline
          dakkyD Offline
          dakky
          wrote on last edited by dakky
          I did not use wlan module (see my signature), but should be the same + wlan settings.
          And, of course, setup an external mqtt broker. I used mosquitto, simple apt-get get foo on the openhab host.
          @hek posted a howto:
          http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway
          • M Offline
            M Offline
            moskovskiy82
            Well the 3rd otion compiled just nicely. The only problem is that as an MQTT client - the gateway doesn't assign any Node ID.
            I think this can be overcome by hardcoding the ID's for every sensor.
            I wonder if we will see some mysensors binding in openhab or a proper MQTT+ESP gateway with NODE ID assignment in the near future
            KukulinK 1 Reply Last reply
            • M moskovskiy82
              KukulinK Offline
              KukulinK Offline
              Kukulin
              Hi, is there any guide how to hardcode IDs for Node and sensors?
              My MQTT client gateway is talking to Mosquitto broker, my DHT sensor is talking to gateway but I never get correct data from sensor even if it measure and always send same information - see log from debug :
              Starting sensor (RNNNA-, 2.0.0-beta)
              Radio init successful.
              req id
              req id
              send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=fail:
              req id
              req id
              req id
              Init complete, id=255, parent=0, distance=1
              req id
              T: 28.30
              req id
              H: 80.70
              and same time log from MQTT gateway client:
              HHQA8~hl,|.i:p0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
              scandone
              state: 0 -> 2 (b0)
              .state: 2 -> 3 (0)
              state: 3 -> 5 (10)
              add 0
              aid 8
              pm open phy_2,type:2 0 0
              cnt
              connected with KAKV005, channel 2
              ip:192.168.1.210,mask:255.255.255.0,gw:192.168.1.1
              .IP: 192.168.1.210
              IP: 192.168.1.210
              0;255;3;0;9;MQTT connected
              0;255;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
              0;255;3;0;9;Sending message on topic: mg1-out/255/255/3/0/3
              • KukulinK Offline
                KukulinK Offline
                Kukulin
                Hi, it is fixed, I'm just blind. I did not see how to initialize mysensors in development branch example. I switched to master branch and can set gw.begin(NULL,nodeID);
                Can someone explain me how to do same for humidity sketch in development branch?
                D 1 Reply Last reply
                • KukulinK Kukulin
                  Dwalt
                  #define MY_NODE_ID xx
                  • KukulinK Offline
                    KukulinK Offline
                    Kukulin
                    Thank you.
                    • kklickerK Offline
                      kklickerK Offline
                      kklicker
                      Hi. I know this topic is a few months old now, but I'm wondering if you were able to accomplish what you wanted to do. I have a wifi gateway set up and would like to do something similar but with Home Genie as the broker running on a Raspberry PI. Did you have to modify the MQTT Client code much to fit your needs? I'm new to MySensors, but I've been researching topics as much as possible before I dive into the code. Can you point me to the version of the client code that worked for you? I would appreciate any help or tips as I am eager to set up several sensors around the house and perhaps a relay to control a garage door. Thanks.
