  3. IRSensor
IRSensor
9 Posts 5 Posters 3.2k Views 4 Watching
  • foggyF
    foggyF
    foggy
    Hi All,
    I may have misunderstood the use case here.
    Following the build http://www.mysensors.org/build/ir
    I have connected only an IR Receive Sensor to Power 5V Grnd & Pin 8.
    IR Transmitter is not connected
    What I am trying to achieve is to press a button on a remote and then have domoticz act upon it through a script.
    The Sensor serial monitor appears to be telling me that it is communicating with the Gateway, at least I don't see "Fail" anywhere. I can also see reference to IRSensor in the Domoticz log. So far so good.
    A couple of questions
    However I don't appear to see any device in the Domoticz list that I can add. Have I missed a step?
    I can see that some of the code has been commented out. Do I need to uncomment some of this (or all of it) in order for it to decode the IR button. I notice that some of it has // and some of it has /.../ Not really sure if I am supposed to uncomment all of it or just some.
    Any help is greatly appreciated.
    Best Wishes.
    James.
    • TheoLT
      TheoLT
      TheoL
      Are you sure the IR sensor isn't broken? AdAfruit has a good tutorial on this link text
      • foggyF
        foggyF
        foggy
        Thank you. I don't think it is broken. If I press a key on the remote I can see some output in the serial monitor. I just don't see any device in domoticz.
        • D
          drock1985
          • Boots33B
            Boots33B
            Boots33
            Is the ir node not showing up in the mysensor gateway under the hardware settings tab?
            • foggyF
              foggyF
              foggy
              Yes - The gateway is shown under Hardware. I am using it with other nodes Temp sensors.
              I can also see the IR sensor in the Domoticz log
              2016-02-05 07:51:23.671 MySensors: Node: 14, Sketch Name: IR Sensor
              2016-02-05 07:51:23.702 MySensors: Node: 14, Sketch Version: 1.0
              I just can't find a device I can add.
              Best wishes.
              James.
              • sundberg84S
                sundberg84S
                Devices in Domoticz is not added until a correct first value is sent, its not enough with a presentation - is this the case?
                foggyF 1 Reply Last reply
                • sundberg84S sundberg84
                  foggyF
                  foggyF
                  foggy
                  @sundberg84
                  Thank you. I thought that might be the case. Hence my second original question
                  // Dumps out the decode_results structure.
                  // Call this after IRrecv::decode()
                  // void * to work around compiler issue
                  //void dump(void *v) {
                  //  decode_results *results = (decode_results *)v
                  /*void dump(decode_results *results) {
                    int count = results->rawlen;
                    if (results->decode_type == UNKNOWN) {
                      Serial.print("Unknown encoding: ");
                    else if (results->decode_type == NEC) {
                      Serial.print("Decoded NEC: ");
                    else if (results->decode_type == SONY) {
                      Serial.print("Decoded SONY: ");
                    else if (results->decode_type == RC5) {
                      Serial.print("Decoded RC5: ");
                    else if (results->decode_type == RC6) {
                      Serial.print("Decoded RC6: ");
                    else if (results->decode_type == PANASONIC) {
                      Serial.print("Decoded PANASONIC - Address: ");
                      Serial.print(results->panasonicAddress,HEX);
                      Serial.print(" Value: ");
                    else if (results->decode_type == JVC) {
                       Serial.print("Decoded JVC: ");
                    Serial.print(results->value, HEX);
                    Serial.print(" (");
                    Serial.print(results->bits, DEC);
                    Serial.println(" bits)");
                    Serial.print("Raw (");
                    Serial.print(count, DEC);
                    Serial.print("): ");
                    for (int i = 0; i < count; i++) {
                      if ((i % 2) == 1) {
                        Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
                      else {
                        Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
                      Serial.print(" ");
                    Serial.println("");
                  Can you advise what I should uncomment?
                  I presume once I have got the correct code from the serial monitor and running above. I can then enter it here
                    if (message.type==V_LIGHT) {
                       int incomingRelayStatus = message.getInt();
                       if (incomingRelayStatus == 1) {
                        irsend.send(NEC, 0x1EE17887, 32); // Vol up yamaha ysp-900
                        irsend.send(NEC, 0x1EE1F807, 32); // Vol down yamaha ysp-900
                       // Start receiving ir again...
                      irrecv.enableIRIn();
                  This will then allow Domoticz to create the device switch.
                  Thank you for any help you can give.
                  Best wishes.
                  James
                  • foggyF
                    foggyF
                    foggy
                    I thought I would close this. Just as well that my Google skills are better than my programming skills.
                    This sketch helped me out and resolved my issues.
                    https://www.domoticz.com/forum/viewtopic.php?f=42&t=7648&start=20#p53663
                    by gizmocuz. Thank you.
                    Best wishes.
                    James.
