  3. MyController.org
  4. How do you Purge Node Data?
Scheduled Pinned Locked Moved MyController.org
8 Posts 3 Posters 3.3k Views 3 Watching
  • bigalB
    bigalB
    bigal
    I have a problem loading the plot for a node which contains battery level data.I get a script debug screen popup. I assume it does not like some data in there. I have been doing some grass roots hacking with a Node so maybe the battery level data gout out of range. Anyway I figure if there is a way to purge the data it might start working again. I already tried deleting the node but the data is still there when the node gets auto added.
    • mfalkviddM
      Which controller are you using?
      bigalB 1 Reply Last reply
        bigalB
        bigalB
        bigal
        Operating System Windows 8.1
        Architecture amd64
        User working directory C:\Arduino\mycontroller-standalone-0.0.2-alpha5-bundle\mycontroller\bin
        • mfalkviddM
          (Moving category from general discussion to Mycontroller.org)
          • J
            J
            jkandasa
            @mfalkvidd Thank you.
            @bigal this is know issues. Which is addressed in 0.0.3-alpha1 release. There is no purging option. however implemented aggregation for batter level also. It will keep minimal data.
            • J jkandasa
              bigalB
              bigalB
              bigal
              Do you have an idea for release of that new ver?
              Also I will have a go at installing on an Olimex with A10 CPU.
              Linux lime03 3.4.67+ #4 PREEMPT Sat Dec 14 15:12:10 EET 2013 armv7l GNU/Linux
              Any advice on how to do this?
              J 1 Reply Last reply
              • bigalB bigal
                J
                J
                jkandasa
                @bigal I'm writing documentation for this new release. once it done will be available for public. May be in couple of days, if everything goes on time.
                For MyController java 1.8, at least 40 MB memory and 30 MB disk space needed. There is no other requirement.
                New version is up and running in demo server. You can visit http://demo.mycontroller.org to explore more about this release.
                • bigalB
                  bigalB
                  bigal
                  Ok thanks,
                  New version demo running well. Nice to see the Dashboard!
                  I will wait for the 0.3 Alpha release.
                  Regards,
                  Al
