  3. Gas (Co2) sensors on batteries
24 Posts 4 Posters 14.8k Views 6 Watching
  • epierreE
    epierreE
    epierre
    I did not manage to get the Senseair K-30 CO2 so I cannot tell for it. I would guess that all this is a good approch, given this fits with the sensor's maker datasheet.
    I use my mh-z14 inside, so I've not tested on batteries, if I would make it outside I would use the ceech board with a 4000mAH LiPo and 1W solar panel which has proved to be the best configuration so far ! I have a barometric, uv and lux working this way for nearly one year yet and it is surviving the winter so far ! I guess a lower LiPo would do the job too but I feared the loss of light in winter.
    z-wave - Vera -> Domoticz
    • alexsh1A
      alexsh1A
      alexsh1
      @epierre Interesting. I see why you'd want to use ceech board outside, but I have the following setup:
      http://forum.mysensors.org/topic/1901/my-own-board-50mm-x-30mm/95
      I have several of these nodes as well as one sensebender in 3D printed boxes. Some of them are in the rooms and one next to the circuit breakers box in the cupboard . Currently, I have them measuring hum/temp/pressure (SI7021, BMP180 and BME280), but I'd like to add Co2 measurement and uv/lux as well (SI1145 + BH1750).
      By the way Senseair K-30 is not good - voltage is 4.5 to 14.0 V DC and I have from 1.6 to 3.1 V.
      epierreE 1 Reply Last reply
      • alexsh1A alexsh1
        epierreE
        epierreE
        epierre
        the ceech has built in lipo/li-on and solar panel and all the led removed ;-)
        yes hard for a step-up ... or you can have an alternate powering, two li-on in parallel e.g. but it would harder to load.
        senseair is hard to obtain outside soime countries, currently to France I did find no way to get it.
        • alexsh1A
          alexsh1A
          alexsh1
          @epierre There is a french company manufacturing a weather station called Netatmo. They manage to implement Co2 sensor battery powered. I wonder what Co2 sensor they have used. Do you know by any chance?
          korttomaK epierreE 2 Replies Last reply
          • alexsh1A alexsh1
            korttomaK
            korttomaK
            korttoma
            @alexsh1 the Co2 sensors in the Netatmo modules are the main reason I got the Netatmo system in the first place. The price is high but the performance is accordingly.
            Anyhow I'm surprised that no one has opened a Netatmo indoor module to see whats inside. The only info I could find is that they use some kind of optical sensor.
            • Tomas
            • alexsh1A
              alexsh1A
              alexsh1
              @korttoma I have Netatmo myself and yes it is a good premium product. The problem comes if you want to add a new module - it is a whopping Euro 60 or around that. I have MQ-135 with mysensors for probably around Euro 10-12 and it is working really well with Domoticz and push notifications. Why paying more? Besides, I like building and programing things myself.
              OK, I found an interesting module - http://www.co2meter.com/products/cozir-5-100-co2-sensor
              Ultra-low power: 3.3V, 3.5mW
              Peak current only 33mA
              If I find it on aliexpress, this could be a good sensor for a battery powered node.
              PS I just saw prices: COZIR 100% CO2 for $109.00! Crazy! Back to my search...
              • alexsh1A
                alexsh1A
                alexsh1
                @arraWX I wonder in your setup how long you can run the Co2 sensor on 4 x 1.5V batteries. Assuming everything goes to sleep for 5-10mins and a Co2 measurement takes only 10 seconds.
                I have been trying to keep voltage at 3.3V (2 x 1.5V batteries) running booloader @ 8Mhz or below.
                • alexsh1A alexsh1
                  epierreE
                  epierreE
                  epierre
                  haem... http://www.aragonvalley.com/en/assessment-netatmo-weather-station/
                  calibration has a cost, but too few found it useful to check if this was worth it... Many kickstarter propose readings of gases without calibration, they provide their own indexes... I've proved many times that you could be alarmed of too much gas just by restarting a sensor, or break a perfume bottle nearby and why would your CO2 raise so much ? only because there are many organic particles in the air, full stop.
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    @epierre - I understand, but paying $109 for a sensor is just ridiculous. I would spend on a node project about $10-20 per node and paying 10 times more for the sensor is just not right in my opinion.
                    Anyway back to google searching for a reasonably priced alternative.
                    How do you find mh-z14? Accurate?
                    • alexsh1A alexsh1
                      epierreE
                      epierreE
                      epierre
                      sure cost can be an issue, but you get what you pay for in the end... people say netatmo expensive but they have chosen their quality level, as many kickstarters projects...
                      MH-Z14 is very fine, you can see it on Davide Gironi posts where he compared both technology.
                      cooking hacks has calibrated CO or O3 gas sensor $200 ...too much for me too...
                      • epierreE
                        epierreE
                        epierre
                        just a glimpse of where CookingHacks / libellium is now going: https://www.cooking-hacks.com/shop/sensors/gas
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          @arraWX - how is your experiment with K-30 going? I am still searching for a good low current Co2 sensor....I am really puzzled that nothing is available even after a very extensive search.
                          • A
                            arraWX
                            The circuit diagram that I posted above did not show communication lines between the K-30 and the sensebender. These are included here:
                            However, I now realise that the K-30 and the sensebender cannot be connected this way because the sensebender (ATmega328P) digital inputs do not accept voltages higher than Vcc + 0.5V.
                            Does anyone have a suggestion how this problem can be solved?
                            @alexsh1 As you can see my experiments with powering the K-30 from batteries are not going that well...
                            alexsh1A 1 Reply Last reply
                            • A arraWX
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @arraWX OK, found an excellent sensor. The only problem is price - one has to pay for a precise sensor with ultra low power consumption.
                              Linearity:Nonlinear (% F.S.)
                              Sluggish:None (% F.S.)
                              Repeatability:Standard (% F.S.)
                              Sensitivity:High sensitivity
                              Drift:No
                              Resolution:High Resolution
                              MH-Z19-W01-GSS-COZIRCarbon dioxide sensor
                              Ultra-low-power carbon dioxide sensor
                              MH-Z19-W01-GSS-COZIR carbon dioxide sensor (hereinafter referred to as COZIR) COZIR is an ultra-low power consumption (3.5mW), high-precision carbon dioxide sensor, ideal for battery-powered portable instruments and equipment. Based on IR LED, detector technology and patented optical detection cavity, so COZIR become the lowest power NDIR sensor, optional temperature and humidity testing. GSS is carbon dioxide detection infrared LED leader in the field, COZIR GSS company is the third generation of products.
                              COZIR Ambient measurable range 0 ~ 2000PPM, 0 ~ 5000ppm and 0 to 1 percent, and is suitable for building control such as gardening and other occasions.
                              Ultra-low-power 3.5MW
                              Measuring range: 0 to 1%
                              Low noise measurement (<10PPM)
                              3.3V power supply
                              peak current is only 33 mA
                              Temperature and humidity output optional
                              http://s.aliexpress.com/bMz6ZRBZ
                              korttomaK 1 Reply Last reply
                              • alexsh1A alexsh1
                                Drift:No
                                3.3V power supply
                                korttomaK
                                korttomaK
                                korttoma
                                @alexsh1 at that prize you could buy a few Netatmo additional indoor modules. Might be that the sensor you suggested would be allot more accurate though.
                                • Tomas
                                • korttomaK korttoma
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @korttoma Yes, I know what you are saying, but Netatmo is not precise. I have MH-Z14 showing 750ppm and Netatmo 1100ppm, for example. I think Netatmo is using index.
                                  All I can say that a calibrated low power CO2 sensor is very expensive. Probably for a home use you do not need to know the exact number. Personally, I have MH-Z14 - it is reasonably expensive and very accurate.
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    I have a MH-Z14 on the way with the slow boat from china, looking forward to testing it.
                                    • Tomas
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @korttoma I got mine a month ago from China. I think it can be used with batteries, but it has to be something like 18650 3000mAh to last longer.
                                      • alexsh1A alexsh1
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        @alexsh1 I was not planing on using it on batteries'. I now have an MQ-2 sensor in the ventilation fresh air intake to detect smoke but it has proven to be unreliable so I thought id try the MH-Z14 instead. Sometimes smoke comes in through the ventilation an then I want it to turn off automatically.
                                        • Tomas
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @korttoma I think we are going the same way. I was not able to relay on my MQ135 and decided to order something more reliable.
