  3. Gas (Co2) sensors on batteries
24 Posts 4 Posters 14.8k Views 6 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    @arraWX I wonder in your setup how long you can run the Co2 sensor on 4 x 1.5V batteries. Assuming everything goes to sleep for 5-10mins and a Co2 measurement takes only 10 seconds.
    I have been trying to keep voltage at 3.3V (2 x 1.5V batteries) running booloader @ 8Mhz or below.
    • alexsh1A alexsh1
      @epierre There is a french company manufacturing a weather station called Netatmo. They manage to implement Co2 sensor battery powered. I wonder what Co2 sensor they have used. Do you know by any chance?
      epierreE
      epierreE
      epierre
      haem... http://www.aragonvalley.com/en/assessment-netatmo-weather-station/
      calibration has a cost, but too few found it useful to check if this was worth it... Many kickstarter propose readings of gases without calibration, they provide their own indexes... I've proved many times that you could be alarmed of too much gas just by restarting a sensor, or break a perfume bottle nearby and why would your CO2 raise so much ? only because there are many organic particles in the air, full stop.
      z-wave - Vera -> Domoticz
      • alexsh1A
        alexsh1A
        alexsh1
        @epierre - I understand, but paying $109 for a sensor is just ridiculous. I would spend on a node project about $10-20 per node and paying 10 times more for the sensor is just not right in my opinion.
        Anyway back to google searching for a reasonably priced alternative.
        How do you find mh-z14? Accurate?
        epierreE 1 Reply Last reply
        • alexsh1A alexsh1
          epierreE
          epierreE
          epierre
          sure cost can be an issue, but you get what you pay for in the end... people say netatmo expensive but they have chosen their quality level, as many kickstarters projects...
          MH-Z14 is very fine, you can see it on Davide Gironi posts where he compared both technology.
          cooking hacks has calibrated CO or O3 gas sensor $200 ...too much for me too...
          • epierreE
            epierreE
            epierre
            just a glimpse of where CookingHacks / libellium is now going: https://www.cooking-hacks.com/shop/sensors/gas
            • alexsh1A
              alexsh1A
              alexsh1
              @arraWX - how is your experiment with K-30 going? I am still searching for a good low current Co2 sensor....I am really puzzled that nothing is available even after a very extensive search.
              • A
                arraWX
                The circuit diagram that I posted above did not show communication lines between the K-30 and the sensebender. These are included here:
                However, I now realise that the K-30 and the sensebender cannot be connected this way because the sensebender (ATmega328P) digital inputs do not accept voltages higher than Vcc + 0.5V.
                Does anyone have a suggestion how this problem can be solved?
                @alexsh1 As you can see my experiments with powering the K-30 from batteries are not going that well...
                alexsh1A 1 Reply Last reply
                • A arraWX
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @arraWX OK, found an excellent sensor. The only problem is price - one has to pay for a precise sensor with ultra low power consumption.
                  Linearity:Nonlinear (% F.S.)
                  Sluggish:None (% F.S.)
                  Repeatability:Standard (% F.S.)
                  Sensitivity:High sensitivity
                  Drift:No
                  Resolution:High Resolution
                  MH-Z19-W01-GSS-COZIRCarbon dioxide sensor
                  Ultra-low-power carbon dioxide sensor
                  MH-Z19-W01-GSS-COZIR carbon dioxide sensor (hereinafter referred to as COZIR) COZIR is an ultra-low power consumption (3.5mW), high-precision carbon dioxide sensor, ideal for battery-powered portable instruments and equipment. Based on IR LED, detector technology and patented optical detection cavity, so COZIR become the lowest power NDIR sensor, optional temperature and humidity testing. GSS is carbon dioxide detection infrared LED leader in the field, COZIR GSS company is the third generation of products.
                  COZIR Ambient measurable range 0 ~ 2000PPM, 0 ~ 5000ppm and 0 to 1 percent, and is suitable for building control such as gardening and other occasions.
                  Ultra-low-power 3.5MW
                  Measuring range: 0 to 1%
                  Low noise measurement (<10PPM)
                  3.3V power supply
                  peak current is only 33 mA
                  Temperature and humidity output optional
                  http://s.aliexpress.com/bMz6ZRBZ
                  korttomaK 1 Reply Last reply
                  • alexsh1A alexsh1
                    Drift:No
                    3.3V power supply
                    korttomaK
                    korttomaK
                    korttoma
                    @alexsh1 at that prize you could buy a few Netatmo additional indoor modules. Might be that the sensor you suggested would be allot more accurate though.
                    • Tomas
                    • korttomaK korttoma
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @korttoma Yes, I know what you are saying, but Netatmo is not precise. I have MH-Z14 showing 750ppm and Netatmo 1100ppm, for example. I think Netatmo is using index.
                      All I can say that a calibrated low power CO2 sensor is very expensive. Probably for a home use you do not need to know the exact number. Personally, I have MH-Z14 - it is reasonably expensive and very accurate.
                      • korttomaK
                        korttomaK
                        korttoma
                        I have a MH-Z14 on the way with the slow boat from china, looking forward to testing it.
                        • Tomas
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @korttoma I got mine a month ago from China. I think it can be used with batteries, but it has to be something like 18650 3000mAh to last longer.
                          • alexsh1A alexsh1
                            korttomaK
                            korttomaK
                            korttoma
                            @alexsh1 I was not planing on using it on batteries'. I now have an MQ-2 sensor in the ventilation fresh air intake to detect smoke but it has proven to be unreliable so I thought id try the MH-Z14 instead. Sometimes smoke comes in through the ventilation an then I want it to turn off automatically.
                            • Tomas
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @korttoma I think we are going the same way. I was not able to relay on my MQ135 and decided to order something more reliable.
                              • korttomaK
                                korttomaK
                                korttoma
                                I received my MH-Z14 yesterday hocked it up on a breadboard to test it and it seems to be working as expected. Now I need a more permanent setup so I can test and compare to a Netatmo indoor module. I may add an SI7021 to the same node.
                                • Tomas
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @korttoma I'll be adding BMP180 shortly as I need pressure and temperature to make a conversion.
