  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 452.5k Views 35 Watching
  • paqorP
    paqorP
    paqor
    I've read about. It sounds interesting.
    I stand a little hard with the development. Is there a skit for MQ135.h and MYSENSORS?
    I will test this afternoon.
    • HeinzH
      HeinzH
      Heinz
      Hi @paqor,
      I wrote a little sketch which you could use as a start, it uses the MQ135 library.
      I also used a timer library, but this could be replaced by a simple sleep, too.
      RZERO should be changed when calibrating the sensor, this can be done at compile-time or during runtime by sending the value to the sensor via the gateway.
      Unfortunately I could not test the sketch yet, but it should help you getting started.
      If you have a second sensor which provides humidity and temperature then you can also get the corrected ppm from the library,...
      good luck!
      MQ135 MySensor
      A0      white
      D0      black
      GND     brown
      5V      red
      #include <MQ135.h>
      #include "Timer.h"
      Timer timer;
      // 30 seconds
      #define TEMP_UPDATE_INTERVAL 30000
      // MQ135
      #define CHILD_ID_CO2 0
      #define CHILD_ID_R0 1
      #define CO2_SENSOR_ANALOG_PIN 0
      /// Calibration resistance at atmospheric CO2 level
      #define RZERO 300.0
      #define EEPROM_R0 0
      MQ135 gasSensor = MQ135(CO2_SENSOR_ANALOG_PIN, RZERO);
      int lastC02;
      float lastR0;
      // MySensor
      MyMessage msgCO2(CHILD_ID_CO2, V_VAR1);
      MyMessage msgR0(CHILD_ID_R0, V_VAR1);
          gw.sendSketchInfo("MQ135 Sensor", "1.0");
          gw.present(CHILD_ID_CO2, S_AIR_QUALITY);
          gw.present(CHILD_ID_R0, S_CUSTOM);
          uint8_t R02 = gw.loadState(EEPROM_R0);
          // get R0 from EEPROM
          float R0 = R02 * 2;
      	// do a plausibility check
          if (R0 > 1.0 && R0 < 400.0)
              Serial.print(F("Setting R0 from EEPROM: "));
              Serial.print(F("Setting default R0: "));
              R0 = RZERO;
          Serial.print(R0);
          Serial.println(F(""));
          gasSensor.setR0(R0);
          timer.every(TEMP_UPDATE_INTERVAL, timerHandler);
      bool MQ135Changed()
          bool changed = false;
          lastR0 = gasSensor.getRZero();
          Serial.print(F("R0: "));
          Serial.println(lastR0);
              float ppm = gasSensor.getPPM();
              Serial.print(F("CO2 ppm: "));
              Serial.print(ppm);
              int roundedPpm = (int)ppm;
              Serial.print(F(" --> "));
              Serial.println(roundedPpm);
              if (roundedPpm != lastC02)
                  lastC02 = roundedPpm;
                  changed = true;
          return changed;
      void timerHandler()
          bool airQualityChanged = MQ135Changed();
          if (airQualityChanged)
              gw.send(msgCO2.set(lastC02));
              gw.send(msgR0.set(lastR0, 2));
          timer.update();
      // Gets the R0 value from the gw passes ot to the lib and stores it into the EEPROM.
      void incomingMessage(const MyMessage& message)
          Serial.println(F("Incoming Message:"));
          if (message.isAck())
          uint8_t sensor = message.sensor;
          if (sensor == CHILD_ID_R0)
              float R0 = message.getFloat();
              Serial.print(F("Incoming R0: "));
              Serial.print(R0);
              gw.saveState(EEPROM_R0, (uint8_t)(R0/2));
              gw.send(msgR0.set(R0, 2));
      • paqorP
        paqorP
        paqor
        wrote on last edited by paqor
        #126
        I have compiled from various sources themselves something. The result is https://gleisnetze.de/2015/12/25/das-erste-kleine-programm/ described herein. The most plausible values I received with the MQ135.h library. For that I have then added the transfer after MySensors / FHEM.
        • B
          B
          bhavika
          Hello
          In MiCS 2614 or in any gas sensor. what should be the value of R0... Because in datasheet they mentioned that value is measured in ambient condition. Any default value for that??
          epierreE 1 Reply Last reply
          • B bhavika
            Hello
            epierreE
            epierreE
            epierre
            @bhavika said:
            Hello
            The datasheed propose the "clean air calibration": "Sensing resistance in air R0 is measured under controlled ambient conditions, i.e. synthetic air at 23 ±5°C and 50 ± 10% RH. Sampling test."
            so you should go outside and mesure the defautl R0 value in your environment.
            z-wave - Vera -> Domoticz
            • HeinzH
              HeinzH
              Heinz
              MQ-135 with 10k results in a R0 of around 360 in my environment. So you could start experimenting with values around 300-500. I had to use a voltage regulator to get reliable values from the sensor.
              • epierreE
                epierreE
                epierre
                #130
                a little update on the MICS-6814:
                NO2: sensible
                CO: flat
                NH3 flat
                For the HCHO:
                sorry for the flat part, some arduino issues at this time
                • mfalkviddM
                  Welcome @betthorn, great to have you here.
                  • epierreE
                    epierreE
                    epierre
                    I have had some questions about converting from mg/m3 to ppm gases, here are the weight values and a proposed method:
                    NH3 17.03 g/mol
                    CO2 44.01
                    CO 28.01
                    H2S 34.08
                    NO2 46.01
                    NO 30.01
                    O3 48.00
                    C6H6 78.11
                    C7H8 92.14
                    you have:
                    NO2 50 μg/m3 gives 26,5868821 ppm
                    O3 27 μg/m3 = 0.027 mg/m3 -> (8,31441298,15)/(48101,325)*27=13,7617025 ppm
                    correct me if I'm wrong
                    • epierreE
                      epierreE
                      epierre
                      2016 is where IoT for gas sensors are moving to more maturity, Cooking Hacks / Libellium proposed so far Fibaro sensors, but are now proposing more pricey one that are calibrated.
                      See https://www.cooking-hacks.com/shop/sensors/gas
                      • epierreE
                        epierreE
                        epierre
                        CO2 with MH-Z14
                        NO2 MICS-6814
                        HCHO sensor
                        • B
                          B
                          bhavika
                          wrote on last edited by bhavika
                          #135
                          In MQ135 sensor's datasheet , which line on the curve is used to find out the concentration of benzene?
                          • B bhavika
                            epierreE
                            epierreE
                            epierre
                            MQ135 is sensitive to particle size, benzene is one of these. I rememer someone who used the chinese datasheet and found a chinese to translate it.
                            • supersjimmieS
                              supersjimmieS
                              supersjimmie
                              wrote on last edited by supersjimmie
                              #137
                              @epierre I am testing a stripped-down version of your code from your AirQuality-MQ135.ino. I stripped it to make it run just stand-alone.
                              What I don't understand is how to do the calibration. When I run it in outside environment (with 10k resistor), I get these values:
                              valr 223
                              Vrl / Rs / ratio:13387 / 20875.00 / 0.00
                              What would be the next step for calibration?
                              • supersjimmieS supersjimmie
                                valr 223
                                epierreE
                                epierreE
                                epierre
                                @supersjimmie replace MQ135_DEFAULTRO by your value 20875 in the sketch
                                supersjimmieS 1 Reply Last reply
                                • epierreE epierre
                                  supersjimmieS
                                  supersjimmieS
                                  supersjimmie
                                  #139
                                  @epierre Thanks, I thought it would be something like that, but that didn't work.
                                  I then got
                                  valr 242
                                  Vrl / Rs / ratio:5464 / 8520.00 / 0.00
                                  Nothing like around 400ppm.
                                  • epierreE
                                    epierreE
                                    epierre
                                    yes for the code must be updated, the value is the CO2 (or something else) detected above the 399 in atmosphere
                                      gw.send(msg.set(MQ135_DEFAULTPPM+(int)ceil(valAIQ)));
                                    • supersjimmieS
                                      supersjimmieS
                                      supersjimmie
                                      Thanks, but when calibrating something strange happens when I put the module outside:
                                      valr 270
                                      Vrl   / Rs       / ratio  / ppm
                                      61355 / 95673.00 / 0.00 / 399.00
                                      valr 265
                                      62928 / 98126.00 / 0.00 / 399.00
                                      valr 260
                                      64561 / 100673.00 / 0.00 / 399.00
                                      valr 256
                                      378 / 589.00 / 0.00 / 399.00
                                      valr 252
                                      1773 / 2764.00 / 0.00 / 399.00
                                      As you can see, the valr decreases slowly, but suddenly Vlr and Rs jump over.
                                      Vlr is the value of 'val', which is: uint16_t val = ((float)22000*(1023-valr)/valr);
                                      uint16_t is 16bit, so max 65535. It looks like my environment needs more than that?
                                      (in fact, your code defines the defaultro as 68550, which is also too much for a uint16?)
                                        valr 270
                                        valr 265
                                        valr 260
                                        valr 256
                                        valr 252
                                        epierreE
                                        epierreE
                                        epierre
                                        yes and this is why I did rewrite it to https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino but did not updated this one...
                                        • epierreE epierre
                                          supersjimmieS
                                          supersjimmieS
                                          supersjimmie
                                          #143
                                          @epierre I striped-down that AirQuality-Multiple_Gas_Sensor1_4.ino to use only MQ135.
                                          When used inside, the analogRead is 473, so a reasonble value.
                                          But the MQCalibration function returns 0. Which means the MQResistanceCalculation also returns 0.
                                          MQResistenceCalculation only does one calc:
                                          return (long)((long)(1024 * 1000 * (long)rl_value)/raw_adc-(long)rl_value);
                                          rl_value = float RL4 = 0.990
                                          raw_adc = 473 (measured as said above)
                                          (1024 * 1000 * 0.990) / 473 - 0.990 = 2142.266
                                          I checked that raw_adc is filled with the correct value (to be sure it is not lost somewhere).
                                          What looks to fix this, I changed everything to float . So:
                                          return (float)((float)(1024 .* 1000. * (float)rl_value)/raw_adc-(float)rl_value);
                                          Which can be simplyfied as:
                                          return ((1024 * 1000*rl_value)/raw_adc-rl_value);
                                          I went to float, because the function is created as float MQResistenceCalculation.
                                          This now gives some ppm values that are within a reasonable range (about 2000 here).
                                          Now I have to figure out how to do calibration on this method again...
