  3. New nrf24l01+ smd
New nrf24l01+ smd
39 Posts 9 Posters 20.6k Views 9 Watching
  • G GertSanders
    @AWI No problem, this board is making its way to me via the mail now (was shipped from OSH Park last wednesday).
    I'm hoping to test it coming week.
    This board one is a one-trick pony. It is based on @m26872's concept of a very narrow board, but in my case I just need it to handle 2 magnetic switches. So pull-up resistors and connection for two contacts (normally closed) is provided (on the pins that allow hardware wake up from power down), and nothing else. No crystal, just minimal power decoupling and a led. No FTDI adapter or ISP. And of course only connection for the SMD version of the NRF24.
    While that was being made at OSH Park I prepared a second design, but this one is still in movement (not ordered yet), measurements are in mm:
    It is certainly not a Sensebender, as it lacks ATSHA204A, SI7021 and SPIFlash, but it does have FTDI interface and optional pull-ups on D2 and D3. It is my first try at SMD, with 0805 size components (I need to be able to hand solder them).
    The objective is to make a working sensor board as flat as possible. At the moment is is even smaller then the CR2032 batteryholder I was planning to use. A possibility is that I go for a two board approach using this "flat node" and a second board to hold a CR1632 (a holder for this smaller battery is in the image above, Keystone Technologies model 3013).
    To be continued ...
    alexsh1A Offline
    alexsh1A Offline
    alexsh1
    This is what I was looking for as I need a small board for a reed switch. Please keep us posted about your testing
    G 1 Reply Last reply
    • M Offline
      M Offline
      meddie
      i like the first layou. Its just pretty narrow. ideal for housing in a cable duct. if there will be an atsha204, a flash modul and a battery sensor this would be the perfect node.
      • alexsh1A Offline
        alexsh1A Offline
        alexsh1
        Y A 2 Replies Last reply
        • alexsh1A alexsh1
          Y Offline
          Y Offline
          @alexsh1 those pliers seem to be the wrong size.... :smirk:
          alexsh1A 1 Reply Last reply
          • alexsh1A Offline
            alexsh1A Offline
            alexsh1
            @Yveaux yeah, I know - I placed an order today for a new set of cutters on Amazon
            • alexsh1A alexsh1
              A Offline
              A Offline
              AWI
              @alexsh1 don't mount it in the wrong direction...
              • A AWI
                alexsh1A Offline
                alexsh1A Offline
                alexsh1
                @AWI you mean nrf24l01+? I have to check what the best fit is given I'll have a few wires
                • alexsh1A alexsh1
                  A Offline
                  A Offline
                  AWI
                  @alexsh1 this is what I did. Mount it in the same direction as the original
                  • Y Yveaux
                    alexsh1A Offline
                    alexsh1A Offline
                    alexsh1
                    @Yveaux are these much better now? ;)))
                    Y 1 Reply Last reply
                    • A AWI
                      alexsh1A Offline
                      alexsh1A Offline
                      alexsh1
                      @AWI Now I see what you mean! Thanks for heads up - really appreciated it. This is the first time I'm dealing with this transceiver in SMD
                      • alexsh1A alexsh1
                        Y Offline
                        Y Offline
                        @alexsh1 much less of a challenge :satisfied:
                        • alexsh1A alexsh1
                          G Offline
                          G Offline
                          GertSanders
                          @alexsh1 My very narrow board was built and tested today. It works fine, I posted info on the hardware forum.
                          I must say I feel pity for this sliver of plastic and metal ...
                          • G GertSanders
                            alexsh1A Offline
                            alexsh1A Offline
                            alexsh1
                            Excellent! I ordered your narrow board a few days ago as I thought it would be very useful.
                            One thing I can tell for sure - cutters are really well built. They are made in Japan and electrostatic safe. Most important they are not big as the ones I had before.
                            • SweebeeS Offline
                              SweebeeS Offline
                              Sweebee
                              ordered the pro mini shields and I'm not disappointed :) As small as you can get:
                              • SweebeeS Sweebee
                                Y Offline
                                Y Offline
                                @Sweebee Very nice indeed!
                                I'm very surprised btw that you're using 2xAA to power the PIR. Will it work reliably (no false detections), even when the batteries are running out?
                                I use 2xAA to power Pro Mini + nRF and an extra AA to power the PIR. This way the supply to the PIR will stay > 3V over time.
                                SweebeeS 1 Reply Last reply
                                • Y Yveaux
                                  SweebeeS Offline
                                  SweebeeS Offline
                                  Sweebee
                                  @Yveaux the pirs work fine if you only have interrupts with CHANGE. I don't use a sleep timer. If you wake it up every minute or so its unreliable yes. but only with interrupts from the pir it works fine. I have 10 pirs like this. Oldest one is from march 2015 and still running.
                                  Y alexsh1A 2 Replies Last reply
                                  • SweebeeS Sweebee
                                    Y Offline
                                    Y Offline
                                    @Sweebee Consider yourself lucky then! I have the same issues decribed here when powering using 2xAA.
                                    I ditched the step-up converter as it introduces too much noise and reduces battery life. The 3xAA solution seems to work reliably though.
                                    • SweebeeS Sweebee
                                      alexsh1A Offline
                                      alexsh1A Offline
                                      alexsh1
                                      @Sweebee
                                      You have an excellent setup - I ordered those adapter as well at oshpark.
                                      @Yveaux has got a point - I have been struggle to build a reliable PIR on 2xAA batteries. I have just started building it now. 1 year battery life and counting is impressive.
                                      @Sweebee Would you care to share your code? Maybe there is anything there which gives us some clues though I believe this is more a hardware issue.
                                      • alexsh1A alexsh1
                                        @Sweebee
                                        Y Offline
                                        Y Offline
                                        Agree. Apparently @Sweebee made modifications to the PIR (mainly to move some capacitors, judging from the photos) but maybe you did some more to improve battery life/stability?
                                        • SweebeeS Offline
                                          SweebeeS Offline
                                          Sweebee
                                          I removed the left capacitor since it's not needed in 3.3v hack. And I moved the right one because otherwise it didn't fit into the case.
                                          My sketch:
                                          #include <readVcc.h>
                                          // ********** CONFIG **********************************
                                              #define NODE_ID AUTO          // ID of node
                                              #define CHILD_ID 1            // ID of sensor
                                              #define PIR_PIN 3             // Pin connected to the PIR
                                              #define MIN_V 2000            // empty voltage (0%)
                                              #define MAX_V 3200            // full voltage (100%)
                                          MySensor node;
                                          int oldBatteryPcnt;
                                          int sentValue;
                                          int forceSend = 0;
                                            node.begin(NULL, NODE_ID, false);
                                            node.sendSketchInfo("PIR Sensor", "1.2");
                                            node.present(CHILD_ID, S_MOTION);
                                            pinMode(PIR_PIN, INPUT);
                                            digitalWrite(PIR_PIN, HIGH);
                                            // Get PIR
                                            int value = digitalRead(PIR_PIN); // Get value of PIR
                                            if (value != sentValue) { // If status of PIR has changed
                                              resend(msg.set(value), 5); // Send PIR status to gateway
                                              sentValue = value;
                                            // Send batterylevel
                                            sendBattery();
                                            node.sleep(PIR_PIN-2, CHANGE);
                                          // FUNCTIONS
                                          void sendBattery() // Send battery percentage to GW
                                            forceSend++;
                                            int batteryPcnt = min(map(readVcc(), MIN_V, MAX_V, 0, 100), 100); // Get VCC and convert to percentage
                                            if (batteryPcnt != oldBatteryPcnt || forceSend >= 20) { // If battery percentage has changed
                                              node.sendBatteryLevel(batteryPcnt); // Send battery percentage to gateway
                                              oldBatteryPcnt = batteryPcnt;
                                              forceSend = 0;
                                          void resend(MyMessage &msg, int repeats) // Resend messages if not received by GW
                                            int repeat = 0;
                                            int repeatDelay = 0;
                                            boolean ack = false;
                                            while ((ack == false) and (repeat < repeats)) {
                                              if (node.send(msg)) {
                                                ack = true;
                                                ack = false;
                                                repeatDelay += 100;
                                              repeat++;
                                              delay(repeatDelay);
                                          Y M 2 Replies Last reply
