  3. New nrf24l01+ smd
New nrf24l01+ smd
39 Posts 9 Posters 21.4k Views 9 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    @Yveaux yeah, I know - I placed an order today for a new set of cutters on Amazon
    • alexsh1A alexsh1
      AWIA
      AWIA
      AWI
      @alexsh1 don't mount it in the wrong direction...
      alexsh1A 1 Reply Last reply
      • AWIA AWI
        alexsh1A
        alexsh1A
        alexsh1
        @AWI you mean nrf24l01+? I have to check what the best fit is given I'll have a few wires
        AWIA 1 Reply Last reply
        • alexsh1A alexsh1
          AWIA
          AWIA
          AWI
          @alexsh1 this is what I did. Mount it in the same direction as the original
          • YveauxY Yveaux
            @alexsh1 those pliers seem to be the wrong size.... :smirk:
            alexsh1A
            alexsh1A
            alexsh1
            @Yveaux are these much better now? ;)))
            • AWIA AWI
              alexsh1A
              alexsh1A
              alexsh1
              @AWI Now I see what you mean! Thanks for heads up - really appreciated it. This is the first time I'm dealing with this transceiver in SMD
              • alexsh1A alexsh1
                @alexsh1 much less of a challenge :satisfied:
                • alexsh1A alexsh1
                  @GertSanders said:
                  This board one is a one-trick pony. It is based on @m26872's concept of a very narrow board, but in my case I just need it to handle 2 magnetic switches.
                  This is what I was looking for as I need a small board for a reed switch. Please keep us posted about your testing
                  GertSandersG
                  GertSandersG
                  GertSanders
                  @alexsh1 My very narrow board was built and tested today. It works fine, I posted info on the hardware forum.
                  I must say I feel pity for this sliver of plastic and metal ...
                  • GertSandersG GertSanders
                    alexsh1A
                    alexsh1A
                    alexsh1
                    Excellent! I ordered your narrow board a few days ago as I thought it would be very useful.
                    One thing I can tell for sure - cutters are really well built. They are made in Japan and electrostatic safe. Most important they are not big as the ones I had before.
                    • SweebeeS
                      SweebeeS
                      Sweebee
                      ordered the pro mini shields and I'm not disappointed :) As small as you can get:
                      • SweebeeS Sweebee
                        @Sweebee Very nice indeed!
                        I'm very surprised btw that you're using 2xAA to power the PIR. Will it work reliably (no false detections), even when the batteries are running out?
                        I use 2xAA to power Pro Mini + nRF and an extra AA to power the PIR. This way the supply to the PIR will stay > 3V over time.
                        SweebeeS 1 Reply Last reply
                        • YveauxY Yveaux
                          SweebeeS
                          SweebeeS
                          Sweebee
                          @Yveaux the pirs work fine if you only have interrupts with CHANGE. I don't use a sleep timer. If you wake it up every minute or so its unreliable yes. but only with interrupts from the pir it works fine. I have 10 pirs like this. Oldest one is from march 2015 and still running.
                          YveauxY alexsh1A 2 Replies Last reply
                          • SweebeeS Sweebee
                            @Sweebee Consider yourself lucky then! I have the same issues decribed here when powering using 2xAA.
                            I ditched the step-up converter as it introduces too much noise and reduces battery life. The 3xAA solution seems to work reliably though.
                            • SweebeeS Sweebee
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @Sweebee
                              You have an excellent setup - I ordered those adapter as well at oshpark.
                              @Yveaux has got a point - I have been struggle to build a reliable PIR on 2xAA batteries. I have just started building it now. 1 year battery life and counting is impressive.
                              @Sweebee Would you care to share your code? Maybe there is anything there which gives us some clues though I believe this is more a hardware issue.
                              • alexsh1A alexsh1
                                @Sweebee
                                Agree. Apparently @Sweebee made modifications to the PIR (mainly to move some capacitors, judging from the photos) but maybe you did some more to improve battery life/stability?
                                • SweebeeS
                                  SweebeeS
                                  Sweebee
                                  I removed the left capacitor since it's not needed in 3.3v hack. And I moved the right one because otherwise it didn't fit into the case.
                                  My sketch:
                                  #include <readVcc.h>
                                  // ********** CONFIG **********************************
                                      #define NODE_ID AUTO          // ID of node
                                      #define CHILD_ID 1            // ID of sensor
                                      #define PIR_PIN 3             // Pin connected to the PIR
                                      #define MIN_V 2000            // empty voltage (0%)
                                      #define MAX_V 3200            // full voltage (100%)
                                  MySensor node;
                                  int oldBatteryPcnt;
                                  int sentValue;
                                  int forceSend = 0;
                                    node.begin(NULL, NODE_ID, false);
                                    node.sendSketchInfo("PIR Sensor", "1.2");
                                    node.present(CHILD_ID, S_MOTION);
                                    pinMode(PIR_PIN, INPUT);
                                    digitalWrite(PIR_PIN, HIGH);
                                    // Get PIR
                                    int value = digitalRead(PIR_PIN); // Get value of PIR
                                    if (value != sentValue) { // If status of PIR has changed
                                      resend(msg.set(value), 5); // Send PIR status to gateway
                                      sentValue = value;
                                    // Send batterylevel
                                    sendBattery();
                                    node.sleep(PIR_PIN-2, CHANGE);
                                  // FUNCTIONS
                                  void sendBattery() // Send battery percentage to GW
                                    forceSend++;
                                    int batteryPcnt = min(map(readVcc(), MIN_V, MAX_V, 0, 100), 100); // Get VCC and convert to percentage
                                    if (batteryPcnt != oldBatteryPcnt || forceSend >= 20) { // If battery percentage has changed
                                      node.sendBatteryLevel(batteryPcnt); // Send battery percentage to gateway
                                      oldBatteryPcnt = batteryPcnt;
                                      forceSend = 0;
                                  void resend(MyMessage &msg, int repeats) // Resend messages if not received by GW
                                    int repeat = 0;
                                    int repeatDelay = 0;
                                    boolean ack = false;
                                    while ((ack == false) and (repeat < repeats)) {
                                      if (node.send(msg)) {
                                        ack = true;
                                        ack = false;
                                        repeatDelay += 100;
                                      repeat++;
                                      delay(repeatDelay);
                                  YveauxY M 2 Replies Last reply
                                  • SweebeeS Sweebee
                                    My sketch:
                                    MySensor node;
                                    int oldBatteryPcnt;
                                    int sentValue;
                                    int forceSend = 0;
                                      // Get PIR
                                        sentValue = value;
                                      sendBattery();
                                    // FUNCTIONS
                                      forceSend++;
                                        forceSend = 0;
                                      int repeat = 0;
                                          ack = true;
                                          ack = false;
                                          repeatDelay += 100;
                                        repeat++;
                                        delay(repeatDelay);
                                    #35
                                    @Sweebee Only real difference I see compared to my sketch is that I'm using a timeout when sleeping, so the watchdog stays enabled while sleeping.
                                    According to the datasheet, the AtMega power consumption is roughly 4.7uA vs 0.6uA in powerdown mode with/without watchdog enabled:
                                    This is a significant difference, but when including the PIR & nRF in the total power consumption it is only a small part.
                                    • SweebeeS Sweebee
                                      My sketch:
                                      MySensor node;
                                      int oldBatteryPcnt;
                                      int sentValue;
                                      int forceSend = 0;
                                        // Get PIR
                                          sentValue = value;
                                        sendBattery();
                                      // FUNCTIONS
                                        forceSend++;
                                          forceSend = 0;
                                        int repeat = 0;
                                            ack = true;
                                            ack = false;
                                            repeatDelay += 100;
                                          repeat++;
                                          delay(repeatDelay);
                                      Maciej Kulawik
                                      @Sweebee I see in the sketch, that you are enabling internal pull-up on PIR input. This means, that if PIR is not detecting movement and its output is set to zero, this pull-up resistor consumes 60uA (in the best case).
                                      • M Maciej Kulawik
                                        SweebeeS
                                        SweebeeS
                                        Sweebee
                                        @Maciej-Kulawik in my calculations it is 6uA. The pirs use around 15-20 uA in sleep.
                                        • SweebeeS Sweebee
                                          Maciej Kulawik
                                          @Sweebee Depending on value of these pull-up resistors. I have read that they have about 50k, so with vcc=3v you will get 60u.
