  3. FHEM
  4. Not getting Node ID assigned
Scheduled Pinned Locked Moved FHEM
11 Posts 3 Posters 7.5k Views 2 Watching
  • bigalB Offline
    bigalB Offline
    bigal
    I have an 8MHz 3.3V Pro Mini Arduino with a NRF24l01 connected to a Olimex A10 (Debian Lime). I have set the Serial gateway to run at 57600 and also created a gateway in Fhem.
    /dev/ttyUSB0@57600 with auotocreate set to 1 and requestAck set to 1.
    I ran all the Fhem updates.
    I have a simple Battery Monitor Node with no Sensor IDs just the battery level. But I cannot see the battery level in the log.
    I only get this message:
    2016.02.11 10:51:53 3: MYSENSORS: ignoring internal-msg from unknown radioId 254, childId 255 for I_BATTERY_LEVEL
    Isn't Fhem supposed to Auto Add Nodes? What am I doing wrong?
    • bigalB Offline
      bigalB Offline
      bigal
      I still can't work this out. If i turn on inclusion-mode on the serial gateway I always get NODE ID 254 assigned. And if I add a second node it shares the same node id and I end up with attributes for many sensor type all in the same node. It lways gets named MYSENSOR_254. Pulling my hair out for 5 days now... can anyone help?
      • hekH Offline
        hekH Offline
        Did you try asking for help over at the FHEM forum?
        • bigalB Offline
          bigalB Offline
          bigal
          I will try. I did Google searches but mostly answers are in German.
          • bigalB bigal
            M Offline
            M Offline
            m26872
            wrote on last edited by m26872
            @bigal
            Use MySensors v1.4.2 in your gateway? I only use Ethernet (W5100) gateway so I can't test, but MySensors v1.5 and later isn't supported by Fhem yet AFAIK.
            Tried static Node IDs?
            Post your fhem.cfg, or at least the relevant parts.
            bigalB 1 Reply Last reply
            • M m26872
              @bigal
              bigalB Offline
              bigalB Offline
              bigal
              wrote on last edited by bigal
              Aha! I thought it might have been a gateway issue. Yes of course I am running ver 1.5 so I will try v1.4.2 and report back how it goes!
              In the meantime here are my configs.
              I have loaded the UV node information into Fhem but it still will not recognize the node.
              Here is my Fhem config.
              attr global userattr cmdIcon devStateIcon devStateStyle icon sortby webCmd widgetOverride
              attr global autoload_undefined_devices 1
              attr global logfile ./log/fhem-%Y-%m.log
              attr global modpath .
              attr global motd SecurityCheck:\
              WEB,WEBphone,WEBtablet has no associated allowed device with basicAuth.\
              telnetPort has no associated allowed device with password/globalpassword.\
              Restart FHEM for a new check if the problem is fixed,\
              or set the global attribute motd to none to supress this message.\
              attr global statefile ./log/fhem.save
              attr global updateInBackground 1
              attr global verbose 3
              define telnetPort telnet 7072 global
              define WEB FHEMWEB 8083 global
              define WEBphone FHEMWEB 8084 global
              attr WEBphone stylesheetPrefix smallscreen
              define WEBtablet FHEMWEB 8085 global
              attr WEBtablet stylesheetPrefix touchpad
              # Fake FileLog entry, to access the fhem log from FHEMWEB
              define Logfile FileLog ./log/fhem-%Y-%m.log fakelog
              define autocreate autocreate
              attr autocreate filelog ./log/%NAME-%Y.log
              define eventTypes eventTypes ./log/eventTypes.txt
              # Disable this to avoid looking for new USB devices on startup
              define initialUsbCheck notify global:INITIALIZED usb create
              define gateway MYSENSORS /dev/ttyUSB0@57600
              attr gateway autocreate 1
              attr gateway first-sensorid 10
              attr gateway icon it_wireless_dcf77
              attr gateway stateFormat connection
              define UVSensor MYSENSORS_DEVICE 10
              attr UVSensor IODev gateway
              attr UVSensor mapReading_uv 0 uv
              attr UVSensor mode node
              attr UVSensor version 1.2
              And a standard UV mysensor Arduino code (no mods).
               * Version 1.0 - epierre
               * Contribution: bulldoglowell, gizmocuz
               * Arduino UVM-30A
               * Index table taken from: http://www.elecrow.com/sensors-c-111/environment-c-111_112
              /uv-sensor-moduleuvm30a-p-716.html
               * Because this table is pretty lineair, we can calculate a UVI with one decimal
               * Connect sensor:
               *   +   >>> 5V
               *   -   >>> GND
               *   out >>> A0
               * License: Attribution-NonCommercial-ShareAlike 3.0 Unported (CC BY-NC-SA 3.0)
              #define UV_SENSOR_ANALOG_PIN 0
              #define CHILD_ID_UV 0
              unsigned long SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
              MyMessage uvMsg(CHILD_ID_UV, V_UV);
              unsigned long lastSend =0;
              float uvIndex;
              float lastUV = -1;
              uint16_t uvIndexValue [12] = { 50, 227, 318, 408, 503, 606, 696, 795, 881, 976, 1079, 1170};
                gw.begin();
                gw.sendSketchInfo("UV Sensor", "1.2");
                gw.present(CHILD_ID_UV, S_UV);
                unsigned long currentTime = millis();
                uint16_t uv = analogRead(UV_SENSOR_ANALOG_PIN);// Get UV value
                if (uv>1170)
                  uv=1170;
                //Serial.print("UV Analog reading: ");
                //Serial.println(uv);
                int i;
                for (i = 0; i < 12; i++)
                  if (uv <= uvIndexValue[i])
                    uvIndex = i;
                //calculate 1 decimal if possible
                if (i>0) {
                  float vRange=uvIndexValue[i]-uvIndexValue[i-1];
                  float vCalc=uv-uvIndexValue[i-1];
                  uvIndex+=(1.0/vRange)*vCalc-1.0;
                //Serial.print("UVI: ");
                //Serial.println(uvIndex,2);
                //Send value to gateway if changed, or at least every 5 minutes
                if ((uvIndex != lastUV)||(currentTime-lastSend >= 5UL*60UL*1000UL)) {
                    lastSend=currentTime;
                    gw.send(uvMsg.set(uvIndex,2));
                    lastUV = uvIndex;
                gw.sleep(SLEEP_TIME);
              M 2 Replies Last reply
              • bigalB bigal
                 * Arduino UVM-30A
                 * Connect sensor:
                 *   +   >>> 5V
                 *   -   >>> GND
                 *   out >>> A0
                float uvIndex;
                float lastUV = -1;
                  gw.begin();
                  if (uv>1170)
                    uv=1170;
                  int i;
                      uvIndex = i;
                  if (i>0) {
                      lastUV = uvIndex;
                M Offline
                M Offline
                m26872
                @bigal (Please indent your code by 4 spaces or 'tab', it will then show up in nice black boxes in your forum posts.)
                • bigalB bigal
                   * Arduino UVM-30A
                   * Connect sensor:
                   *   +   >>> 5V
                   *   -   >>> GND
                   *   out >>> A0
                  float uvIndex;
                  float lastUV = -1;
                    gw.begin();
                    if (uv>1170)
                      uv=1170;
                    int i;
                        uvIndex = i;
                    if (i>0) {
                        lastUV = uvIndex;
                  M Offline
                  M Offline
                  m26872
                  @bigal Also, I think there can be issues with that particular UV-sensor sketch example. The gw.sleep() function stops timers and will make the millis() function hard to use.
                  • bigalB Offline
                    bigalB Offline
                    bigal
                    Not concerned with bugs in the UV Sketch as I will make my own sketches once I get the controller to recognize the nodes.
                    My plan is to adapt some code to make tank level sensors and an analog (not pulse based) kWh meter. Also planning to control some pumps, so those will be outputs.
                    So should I use Arduino 1.4.2 for compiling code for Gateway and all the nodes, yes?
                    • bigalB bigal
                      M Offline
                      M Offline
                      m26872
                      @bigal Only gateway. The nodes work fine on v1.5
                      • bigalB Offline
                        bigalB Offline
                        bigal
                        I just compiled the Gateway in the 1.4.2 Mysensors bundle. I compiled a LUX node and a Pressure node, but still no luck, I always get the nodes showing up as Node 254 and overwriting each other.
                        So seems my issue may not related to the Gateway Version.
