  2. Feature Requests
  3. Generic text variable type
Scheduled Pinned Locked Moved Feature Requests
13 Posts 4 Posters 6.7k Views 3 Watching
  • soifS
    soifS
    soif
    wrote on last edited by soif
    V_TEXT already exists in version 2.0 : see in the code, or in Doxygen ! :-p
    But because of the NRF24L01 limitation, the maximum payload size is 25 bytes!.
    This means that V_TEXT messages would be limited to 25 characters, which could be too short in some case.
    Maybe Mysensors could split longer V_TEXT in multiple messages when sending, then recomposing it when receiving ie:
    "Here is a sentence longer than 25 characters that should be splitted."
    Could be encoded into messages like this :
    1;0;0;47;Here is a sentence lon;1;4
    1;0;0;47;ger than 25 characters;2;4
    1;0;0;47; that should be splitt;3;4
    1;0;0;47;ed.;4;4
    Then it would be automatically decoded at the arrival.
    This way V_TEXT message would be limited to 23*255 characters (more than enought), without writing complicated code from the controllers or in the sketch !
    AWIA M 2 Replies Last reply
    • M medline2c
      I'm interesting about sending or receive text through a node for exemple to receive informations to write to a LCD or OLED screen... I've read about V_TEXT type but I don't found any example with text and LCD example or description, or idealy Build example... do you have ideas for How to do this ?
      (sorry, my engliish's very bad, I know... oups !)
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      @medline2c there are a few examples on the forum scrolling text
      • soifS soif
        1;0;0;47;ed.;4;4
        AWIA
        AWIA
        AWI
        @soif this has been discussed when the V_TEXT was introduced.
        • soifS
          soifS
          soif
          @AWI Thank you very much for poiting me to this interesting project.
          If it has been discussed, it has not been solved, wasn't it? I've read @John proposal, which sounds really similar to mine.
          Any progress or decision from the maintainers about this ?
            No, nothing has been done to the long-text thing.
            Long message (chunking) support should probably be implemented in a more general way (working for all V-types)
            • soifS soif
              1;0;0;47;ed.;4;4
              medline2c
              @soif
              It's great but I'am not in Version 2.0 but in V 1.5 API... how to update to 2.0, I don't found the link to do this ... or I don't understand something ?... could you say me ?
              Christophe
                medline2c
                An other question: I use Jeedom 2.0.1 ... do you know if Jeedom compatible with V_TEXT ?...
                  2.0.0.beta can be found here:
                  https://github.com/mysensors/Arduino/tree/development
                  I don't know much about what Jeedom supports unfortunately.
                    medline2c
                    Jeedom support only 1.5 Stable branch ... Do you confirm me that it isn't compatible with V-Text usage ... ? ;-(
                      V_TEXT became available after 1.5. So it will probably not show up any devices for S_INFO/V_TEXT.
                        medline2c
                        Thanks, I'll install a domoticz again to my NAS Synology... I don't have choice if I want to use V_TEXT... ;-)
                        So I don't know how to communique between Jeedom and Domoticz efficiantly, I'll search...
                        Great !...
