  3. MyController.org
  4. beta testers required for MyController 0.0.3-alpha1 release
Scheduled Pinned Locked Moved MyController.org
mycontroller.org
55 Posts 10 Posters 19.8k Views 9 Watching
  • tekkaT
    tekkaT
    tekka
    Very nice and clean GUI. Good job!
      mvader
      I'll beta test.
      • W
        W
        Werwolfx
        hi
        @mvader said:
        I'll beta test.
        +1 and i want beta test this release
        • W
          W
          Werwolfx
          very nice update!
          i see demo page and i found one not good moment/
          if i add to the dashboard and click another link? my changes are broken =( and i not see the confirmation dialog about i lost all changes/
          may be you add this confirmation?
          sorry for my english. i am from Russia
          J 1 Reply Last reply
            A Former User
            +1 I want to beta test!
            • W Werwolfx
              very nice update!
              J
              J
              jkandasa
              @Werwolfx said:
              very nice update!
              Yes, will be good to add confirmation to notify user. will add it thank you!
              • C
                C
                cdr
                do donators get priority? :)
                • C cdr
                  J
                  J
                  jkandasa
                  Sure, I have PM the link.
                  • W
                    W
                    Werwolfx
                    wrote on last edited by Werwolfx
                    very nice update!
                    short install instructions:
                    0)stop old version if installed, backup it
                    1)copy this beta to a server
                    2)chmod +x bin/start.sh and stop.sh
                    3)open conf/mycontroller.properties and edit ip/port settings
                    4)bin/start.sh
                    5)open url in your browser, protocol https!
                    6)login admin/admin
                    7)see buteful interface
                    • After change the default admin password, mycontroller not logoff me and i not work in the interface.
                      after logoff and logon myself from new password i can use again
                    • in Resources-Sensors not sorting for Node EUI. May be you add sorting to click on header table names ?
                    • not found RAW message send =( may be you add to dashboard button, in button configuration set raw message, if user press to the button, message send to node. is good functional for release to custom message nodes and one of more steps to mycontroller can smart home system
                      May be add a REST API for send RAW message to other NODEs
                    where I can post comments / suggestions to use this beta version?
                      A Former User
                      On the "Sensors and variables mapping" page.
                      The page number controller dosent work, you are only able to see the first page.
                      Excellent work
                      Goran
                      • J
                        J
                        jkandasa
                        @Werwolfx @goranrad Thank you very much to spend time to test MyController.org.
                        I will fix the issues reported here as soon as.
                        @Werwolfx
                        I have added fix for this. Once we changed the password will redirect to login page automatically.
                        as per our current design Node EUI not supported for sorting on this page. we may implement it later. we are not going to give sorting option of each tab. in this case it looks bit odd if we put it on table header and nice widget already available with patternfly for sorting. So we are using it separately. in the recent build Node EUI was removed from sorting options.
                        Yes, I removed, was assuming no one is using it. Sure, I will add it again.
                        for now we do not have page to give feedback or comments. But for issues kindly use https://github.com/mycontroller-org/mycontroller/issues
                        • T
                          Tag
                          Can i test release 0.0.3 please? :smiley:
                          WOW!! this is really cool stuff!!!
                          Got a serial gateway with 2 wireless sensors running,
                          Sensor 1:
                          -Humidity
                          -Temperature (DHT22)
                          -Lightlevel (DHT22)
                          Sensor 2:
                          -Temperature (BMP085)
                          -Airpressure (BMP085)
                          -Outside temperature (with NTC)
                          Keep up the good work!!!!
                          • R
                            R
                            robosensor
                            Sorry, seems like I broken demo site by entering " ` " in temperature field of sensor :worried:
                            Now getVariables returns 500 error with message:
                            errorMessage:"java.lang.NumberFormatException: For input string: "`""
                            • R robosensor
                              J
                              J
                              jkandasa
                              It is not a problem. Thank you to made this. We have to fix this one also :smile:
                              Thanks again!
                              • J
                                J
                                jkandasa
                                Thanks again!
                                Fixed. Yet to implement number validation in front end
                                • R
                                  R
                                  robosensor
                                  wrote on last edited by robosensor
                                  Please also escape all information that demo user enters :) Just an example: I entered html in forecast sensor data in dashboard and this html is rendered in resources/logs section: http://demo.mycontroller.org/#/resources/logs/
                                  The same thing in node names in groups: http://demo.mycontroller.org/#/resources/groups/map/list/1
                                  • R robosensor
                                    J
                                    J
                                    jkandasa
                                    Thank you! I will fix issues!
                                    • T
                                      Tag
                                      gui is looking great!,
                                      have been playing with the software and found the following:
                                      in resources/nodes, all my nodes (mysensors 15,x) are shown as "down" while they are sending data...is this a setup issue?
                                      and for the weather forcast only N/A is shown and not the value from the sensor.....
                                      rest looks great! really like the dashboard feature!
                                      • T Tag
                                        J
                                        J
                                        jkandasa
                                        Thank you for the report and allocated time to test MyController.
                                        MyConttroller was looking I_HEARTBEAT_RESPONSE. From your question I understand that we should make up when we receive any message from node. I will work on it.
                                        These are all the weather station mapping icons from https://erikflowers.github.io/weather-icons/
                                                  value:"day-sunny",
                                                  value:"day-cloudy",
                                                  value:"day-thunderstorm",
                                                  value:"na",
                                                  value:"na",
                                                  value:"na",
                                        Source:https://github.com/mycontroller-org/mycontroller/blob/development/src/main/package/www/services/common_services.js#L286
                                        we have to update this mapping based on our community members feedback.
                                        Thank you!
                                        • A
                                          anarro
                                          +1 I want to beta test, (and if you want.. colaborate to translate at lenguage Spanish..)
                                          Good job!
