  3. Universal wireless sensor board w/NRF24l01+ and ESP8266 socket - ceech board
board
41 Posts 9 Posters 27.0k Views 4 Watching
  • C
    C
    ceech
    They are extra. Enjoy.
      shabba
      wrote on last edited by shabba
      EDITED
      Nevermind!!
      "- with CE and CSN pins connected to digital pins 7 and 8 (you must update MyConfig.h with these values). There is a 4.7uF capacitor connected across Vin and GND of the port"
      AWIA 1 Reply Last reply
      • S shabba
        EDITED
        Nevermind!!
        AWIA
        AWIA
        AWI
        @shabba You do not need to update MyConfig.h. Just instantiate MySensor with the right parameters (default is 9, 10).
        // PIN Radio
        #define RADIO_CE_PIN    7       // radio chip enable
        #define RADIO_SS_PIN    8      // CS SS serial select
        MySensor gw(RADIO_CE_PIN, RADIO_SS_PIN);
        • epierreE
          epierreE
          epierre
          I'm trying mine... any idea why the gateway doesn't receive it at 20cm distance ?
          req node id
          send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
          sensor started, id 255
          req node id
          req node id
          req node id
          req node id
          z-wave - Vera -> Domoticz
          • epierreE
            epierreE
            epierre
            @ceech sorry seems the radio was dead ...
            • epierreE
              epierreE
              epierre
              @ceech I have an issue on a board (lipo+solar) where when I put the programmer it works, when I remove it and leave it on battery it doesn't... battery is 94%, I checked sensors get the energy.. but no more radio it seems, an idea ?
              C 1 Reply Last reply
              • epierreE epierre
                C
                C
                ceech
                @epierre It is probably a loose contact on the battery connector. Try using a multimeter and check the important connections.
                • epierreE
                  epierreE
                  epierre
                  @ceech can you point me to the wirings ? thanks,
                  • epierreE epierre
                    C
                    C
                    ceech
                    @epierre Which board are you using?
                    • epierreE
                      epierreE
                      epierre
                      on this one this is the lipo+solar.
                      On the other thread, I mistakenly ordered the "standard" version through mysensor website, and had no time till now to test this out... so bard both weren't proposed...
                      • epierreE epierre
                        C
                        C
                        ceech
                        wrote on last edited by ceech
                        #29
                        @epierre The battery is connected with the marked trace:
                        It goes to the switch an over to the voltage regulator:
                        You should measure battery voltage along those lines with respect to the GND. On the other side of the voltage regulator there should be 3V3.
                        On the side note -- you can use those boards that you've mentioned on the other thread to charge the battery. No problem.
                        epierreE 1 Reply Last reply
                        • C ceech
                          epierreE
                          epierreE
                          epierre
                          #30
                          thanks, but I should not have mixed both, my issue is with the other one.
                          • epierreE epierre
                            C
                            C
                            ceech
                            #31
                            @epierre The one with LTC4067 or the one with LTC4079? It's probably the one with LTC4067.
                            Here, this is the battery path to the charger:
                            and then to the voltage regulator:
                            • epierreE
                              epierreE
                              epierre
                              #32
                              on the LCT4067, I have 4.17 , on the battery, VCC/GND gives 1.608, same on programmer pin. But this is correct with the programmer, so I get I have an issue from the battery circuit voltage transformation.
                              on the standard one LTC4079, voltages are correct, 4.17 on Vin/GND, 3.3 on VCC/GND
                              • epierreE epierre
                                C
                                C
                                ceech
                                @epierre It's either the LTC4067, or the voltage regulator. Can you send me the board back?
                                I'll repair it and send you back.
                                • epierreE
                                  epierreE
                                  epierre
                                  hello fine, also I wanted to try the thermopile so there will be more on return ;-)
                                  In the meanwhile, how can I have my solar panel on the LTC4079 ? can the lithium charger do the trick ?
                                  • epierreE epierre
                                    C
                                    C
                                    ceech
                                    @epierre I've received the board and repaired it. I had to replace the battery management IC. The LTC4067. The output was fried. I also replaced the voltage regulator while I was at it.
                                    • epierreE
                                      epierreE
                                      epierre
                                      @ceech thanks a lot, any idea why this would happen ?
                                      what kind of bluetooth module are you using ? I've managed nothing good with the HC-05, maybe faulty hard to know.
                                      • C
                                        C
                                        ceech
                                        There are current limiters on input and output side. So short circuit is out of the question. Maybe overvoltage on the input side.
                                        Yes, that's HC-05. Just use it as a serial monitor. It's the same.
                                        • N
                                          N
                                          nunver
                                          @ceech for the solar panel and lipo version, could you let me know what type of battery and panel I shoulld buy? Also, is there a tutorial for usage of that version? I am new in solar panel and cahrging batteries. Thanks
