  3. Universal wireless sensor board w/NRF24l01+ and ESP8266 socket - ceech board
board
41 Posts 9 Posters 27.0k Views 4 Watching
  • C
    C
    ceech
    Yes, it can. If you are willing to try, I can send you one board and you can test that if you are up for it. Just post the code here, when you make it work. Send me a message and we can discuss it further if you like.
      shabba
      I just want to confirm a few things before I buy :
      1. What is needed to programme this? Can it be done via an FTDI board?
      2. What bootloader is on it?
      3. Besides a sensor and radio (and power) nothing else needs to be added/soldered right?
      • C
        C
        ceech
        wrote on last edited by ceech
        @shabba
        1. Yes, it can. With FTDI or similar board. It is the same process as with Arduino Pro mini.
        2. Which is also the bootloader - Arduino Pro or Pro Mini (ATmega328, 8MHz, 3.3V)
        3. Nothing else is needed.
          shabba
          Thanks. Ordered a couple.
            shabba
            I'm having a slow day so bear with me :-)
            Where do I connect the LEDs? Also what is the name of the white sockets? I want to google procedure for adding wire to the plug part.
            Many thanks :)
              shabba
              Warning to others : I blew a radio by connecting a 5V programmer. There seems to be no protection from USB power to the radio.
              • C
                C
                ceech
                I'm sorry to hear that. Is there something I can do?
                The LEDs have solder jumpers next to them. The top one has one to the left, and the bottom one has one to the right. Just pour solder so that both parts of the jumper get connected.
                The white connector is Japan Solderless Terminal or JST. I believe it is a XH series with 0.1 inch spacing. The way I connect the wire is I bend the longer ears with pliers over the isolated wire and use solder iron to solder the shorter ears to the stripped wire.
                  shabba
                  wrote on last edited by shabba
                  I see the LEDs and understand now. I had got some loose in the shipping packet and thought I had to solder them onto the board.
                  • C
                    C
                    ceech
                    They are extra. Enjoy.
                      shabba
                      EDITED
                      Nevermind!!
                      "- with CE and CSN pins connected to digital pins 7 and 8 (you must update MyConfig.h with these values). There is a 4.7uF capacitor connected across Vin and GND of the port"
                      AWIA 1 Reply Last reply
                      • S shabba
                        EDITED
                        Nevermind!!
                        AWIA
                        AWIA
                        AWI
                        @shabba You do not need to update MyConfig.h. Just instantiate MySensor with the right parameters (default is 9, 10).
                        // PIN Radio
                        #define RADIO_CE_PIN    7       // radio chip enable
                        #define RADIO_SS_PIN    8      // CS SS serial select
                        MySensor gw(RADIO_CE_PIN, RADIO_SS_PIN);
                        • epierreE
                          epierreE
                          epierre
                          I'm trying mine... any idea why the gateway doesn't receive it at 20cm distance ?
                          req node id
                          send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
                          sensor started, id 255
                          req node id
                          req node id
                          req node id
                          req node id
                          z-wave - Vera -> Domoticz
                          • epierreE
                            epierreE
                            epierre
                            @ceech sorry seems the radio was dead ...
                            • epierreE
                              epierreE
                              epierre
                              @ceech I have an issue on a board (lipo+solar) where when I put the programmer it works, when I remove it and leave it on battery it doesn't... battery is 94%, I checked sensors get the energy.. but no more radio it seems, an idea ?
                              C 1 Reply Last reply
                              • epierreE epierre
                                C
                                C
                                ceech
                                @epierre It is probably a loose contact on the battery connector. Try using a multimeter and check the important connections.
                                • epierreE
                                  epierreE
                                  epierre
                                  @ceech can you point me to the wirings ? thanks,
                                  • epierreE epierre
                                    C
                                    C
                                    ceech
                                    @epierre Which board are you using?
                                    • epierreE
                                      epierreE
                                      epierre
                                      on this one this is the lipo+solar.
                                      On the other thread, I mistakenly ordered the "standard" version through mysensor website, and had no time till now to test this out... so bard both weren't proposed...
                                      • epierreE epierre
                                        C
                                        C
                                        ceech
                                        #29
                                        @epierre The battery is connected with the marked trace:
                                        It goes to the switch an over to the voltage regulator:
                                        You should measure battery voltage along those lines with respect to the GND. On the other side of the voltage regulator there should be 3V3.
                                        On the side note -- you can use those boards that you've mentioned on the other thread to charge the battery. No problem.
                                        epierreE 1 Reply Last reply
                                        • C ceech
                                          epierreE
                                          epierreE
                                          epierre
                                          #30
                                          thanks, but I should not have mixed both, my issue is with the other one.
