  3. Other Controller get disconnected when sending any command to the Eth. Gateway (v2.0)
13 Posts 3 Posters 4.6k Views 4 Watching
    Hmm.. good that I write comments sometimes... :)
    Well... Obviously I didn't find any good way to do it. If you can find a way, please pursue it.
    • soifS
      soifS
      soif
      wrote on last edited by soif
      Yep, comments are often useful when we are not that lazy to include them :-D
      BTW I've found a topic telling about modifying the Eth library to get the Source IP, and being then able to support multiple clients. I don't know if it really helps.
      Also found this where the guy says that W5100 supports 4 sockets (so max 4 clients) but the Eth lib can NOT distinguish them if they are on the same port (might be a a workaround, to open 4 port instead of one, ie 5003,5004,5005,5006). He's finally submitted a patch against the Eth lib to allow 4 different sockets on the same port.... But the more interesting seems to be a comment by "Gene" who has posted complete sketch showing how to connect multiple telnet clients . Here is his code:
      /* exampleMultiTelnetServer.ino */
       *  Created: May 21, 2015
       *  Created by Gene Reeves to demonstrate how the W5100 eithenet handles multiple connections
       *  using a single server object instance.
       *  once the sketch is loaded on your arduino and you see the start up banner display in the
       *  Serial Monitor, fire up your favorite telnet client and connect a few instances.
       *  from the serial monitor you can send text to one or all clients. Use '*" for the ID to send
       *  to all, otherwise use the ID you wish to send to, using this format to send,
       *   "ID:TEDXT_TO_SEND".  That should make everything as clear as mud  :-)
       *  Dependencies:
       *  uses LinkedList class from here https://github.com/ivanseidel/LinkedList
       *  to store list of connected clients.
       *  uses StringStream class from here https://gist.github.com/cmaglie/5883185
       *  Not sure why this was not a part of the StringObject to start with..
       *  uses elapsedMillis class from here http://playground.arduino.cc/Code/ElapsedMillis
       *  much improved version (for Teensy brand mcu's) here https://www.pjrc.com/teensy/td_timing_elaspedMillis.html
       *  Unless I am mistaken, I beleive this code was originated by Paul Stoffregen of www.pjrc.com
       *  If you are not famialar with Paul or his Teensy microcontroller, you would do yourself a
       *  solid to spend some time reviewing his code and you can't beat the Teensy 3.1 for
       *  price/performance/support!!!
       *  Teensy 3.1 - 32bit-ARM  mcu @ 72MHz (overclockable to 168MHz) w/ 256K flash / 64K ram / USB
       *  for under $20.  https://www.pjrc.com/teensy/index.html
       *  BTW, I am in no way affilaited with Paul or PJRC, I just think he built an awesome mcu.
      #include <LinkedList.h>
      #include <elapsedMillis.h>
      #include <StringStream.h>
      #include <Arduino.h>
      #include <EthernetUdp.h>
      #include <EthernetServer.h>
      #include <EthernetClient.h>
      #include <Ethernet.h>
      #include <Dns.h>
      #include <Dhcp.h>
      #include <IPAddress.h>
      #include <Server.h>
      #include <Client.h>
      /*  DEFINES  */
      /*  Change the following to suite your environment.  */
      #define TELNET_SERVER_PORT 23
      #define TELNET_SERVER_MAC 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
      #define TELNET_SERVER_IP 192, 168, 1, 177
      #define TELNET_SERVER_GATEWAY 192, 168, 1, 1
      #define TELNET_SERVER_NETMASK 255, 255, 255, 0
      #define SERIAL_BAUD 115200
      #define WELCOME_BANNER_STRING "Welcome to MultiTelnetServer.\r\nType 'exit' to disconnect\r\n"
      #define GOODBYE_BANNER_STRING "Come Back Again,   Goodbye.."
      #define APP_BANNER_STRING "\r\n\r\n\tMultiTelnetServer Example\r\n  This example application strives to\r\ndemonstrate using the Wiznet W5x00\r\nEthernet Shield's Arduino library usage\r\nwhen serving mulitple concurrent\r\nconnects using a single 'server object'\r\ninstance."
      #define SERVER_LISTENING_STRING "\tServer Listening on"
       *  This is required to add RemoteIP, RemotePort support to the EthernetClient class
       *  I stole it from here http://forum.arduino.cc/index.php?topic=210857.0
      //namespace ethernet_fix
        #include <utility/w5100.h>
        template<typename Tag, typename Tag::type M>
        struct AccessMember{
          friend typename Tag::type get(Tag){ return M; }
        struct EthernetClient_Socket{
          typedef uint8_t EthernetClient::*type;
          friend type get(EthernetClient_Socket);
        template struct AccessMember < EthernetClient_Socket, &EthernetClient::_sock > ;
        IPAddress RemoteIP(EthernetClient &c){
          byte remoteIP[4];
          W5100.readSnDIPR(c.*get(EthernetClient_Socket()), remoteIP);
          return (remoteIP);
        uint16_t RemotePort(EthernetClient &c){
          return W5100.readSnDPORT(c.*get(EthernetClient_Socket()));
      //} // namespace "ethernet_fix"
       *  EthernetClientEx - Because there is still no RemoteIP or RemotePort
       *  properties built in to th current EthernetClient!!
      class EthernetClientEx :
        public EthernetClient
      protected:
        uint8_t _sock; // hack to get access to socket #
      public:
        EthernetClientEx(const EthernetClient &orig) : EthernetClient(orig) {}
        IPAddress remoteIP() { return RemoteIP((EthernetClient &)(*this)); }
        int16_t remotePort() { return RemotePort((EthernetClient &)(*this)); }
        bool isSameSock(const EthernetClientEx &c) { return (_sock == c._sock); }
       *  ClientItem is class to wrap EthernetClient for storage on linked list
       *  we will use it to add a ts (millis at connection time) and an index.
      class ClientItem
      public:
        unsigned long timestamp;
        int index;
        size_t recv_cnt;
        String recv_buffer;
        EthernetClientEx *client;
        ClientItem() { timestamp = millis(); index = -1; client = (EthernetClientEx *)false; }
        virtual ~ClientItem() { delete client; /* release memory */}
        unsigned long elapsed(void) { unsigned long ts = millis(); return (ts - timestamp); }
       *  ClientList is linkedlist for storing connected clients.
       *  For now, we'll just use it to store our clients, but should
       *  expand this close to include testing all clients for disconnects,
       *  testing all clients for pending recv data and sending data
       *  to all connected clients.
      class LinkedClientList :
        public LinkedList<ClientItem*> //ClientList;
      public:
        //EthernetServer *server;
        ClientItem *getClientItem(int idx)
          for (ListNode<ClientItem *> *n = root;n;n=n->next)
            if (n->data->index == idx)
              return n->data;
          return (ClientItem *)0;
        bool exists(const EthernetClientEx &ece)
          for (ListNode<ClientItem *> *n = root; n; n = n->next)
            if (n->data->client->isSameSock(ece))
              return true;
          return false;
        void drop(int idx)
          ClientItem *cli;
          int real_idx = -1;
          int ci = 0;
            if (n->data->index != idx)
              ci++;
              cli = n->data;
              real_idx = ci;
          if (real_idx != -1)
            if (cli->client->connected())
              cli->client->stop();
            cli->index = -1;
            remove(real_idx);
        size_t send(const String &s, int idx)
          size_t ret = 0;
          ClientItem * cli = getClientItem(idx);
          if (cli)
            ret = cli->client->print(s);
            cli->client->flush();
          return ret;
        size_t send2All(const String &s)
          size_t ret = 0;
            ret += n->data->client->print(s);
            n->data->client->flush();
          return ret;
      LinkedClientList ClientList;
      // Enter a MAC address and IP address for your controller below.
      // The IP address will be dependent on your local network.
      // gateway and subnet are optional:
      byte mac[] = { TELNET_SERVER_MAC };
      IPAddress ip(TELNET_SERVER_IP);
      IPAddress gateway(TELNET_SERVER_GATEWAY);
      IPAddress subnet(TELNET_SERVER_NETMASK);
      // buffer to hold input from console
      StringStream con_buffer("");
      // telnet defaults to port 23
      EthernetServer server(TELNET_SERVER_PORT);
      /* forward's */
      void server_check_new_connections(void);
      void server_check_client_recv(void);
      int server_accept(EthernetClientEx *enetcli);
      bool clientExists(const EthernetClientEx &c);
      bool test_for_cmd(const String &itm, const String &src);
      size_t console_recv(void);
      void proc_line(StringStream &ss);
      size_t client_recv(ClientItem *cli);
      void client_disconnecting(ClientItem *cli);
      void client_disconnected(ClientItem *cli);
      size_t send_to(int idx, const String &str);
      size_t send_to_all(const String &str);
        /* add setup code here */
        // reserve some space for input buffer
        con_buffer.reserve(256);
        // Open serial communications and wait for port to open:
        Serial.begin(SERIAL_BAUD);
        delay(3000);  // 3 second delay for Serial to connect.
        pinMode(10, OUTPUT);
        digitalWrite(10, HIGH);
        pinMode(4, OUTPUT);
        digitalWrite(4, HIGH);
        // initialize the ethernet device
        Ethernet.begin(mac, ip, gateway, subnet);
        server.begin();
        // Print "App Banner" and "Server Listening" notice.
        Serial.println(F(APP_BANNER_STRING));
        Serial.println(F(SERVER_LISTENING_STRING));
        Serial.print(F("\t\t"));
        Serial.print(ip);
        Serial.print(':');
        Serial.println(TELNET_SERVER_PORT);
        Serial.println(F("\r\n\r\n"));
        /* add main program code here */
        // check for any new clients
        server_check_new_connections();
        // give up a timeslice
        yield();
        // check to see if any of the clients
        // have recv data pending
        if (ClientList.size() > 0)
          server_check_client_recv();
        yield();
        // check to see if console has any
        // pending recv data.
        if (Serial.available())
          console_recv();
        yield();
        size_t ret = 0;
        int c = 0;
        while ((c = Serial.read()) >= 0)
          if (c == 10)
            proc_line(con_buffer);
            con_buffer = String("");
            con_buffer.begin();
            continue;
          if (c != 13)
            con_buffer += (char)c;
            ret++;
        return ret;
        //  Console input should be in the for of
        //  "ID:string_literal"
        //  where:
        //    ID is client index to send to or "*" (all)
        //    string_literal is string to send
        // check to ensure 2nd char is a ":"
        if ((ss.length() < 3) || (ss.charAt(1) != ':'))
          Serial.print(F("Invalid Console Input \""));
          Serial.print(ss);
          Serial.print(F("\"\r\nPlease use the following format:\r\n\t"));
          Serial.println(F("\"ID:string_literal\"\r\n"));
          Serial.flush();
          return;
        int idx = -1;
        Serial.print(F(" first char is '"));
        Serial.print(ss.charAt(0));
        Serial.print(F("',  "));
        if (ss.charAt(0) != '*')
          idx = ss.parseInt();
        Serial.print(F("idx="));
        Serial.print(idx);
        Serial.print(F(", indexOf(':')="));
        Serial.println(ss.indexOf(':'));
        ss = ss.substring(1 + ss.indexOf(':'));
        ss += F("\r\n");
        if (idx < 0)
          ClientList.send2All(ss);
          //send_to_all(ss);
          ClientList.send(ss, idx);
      size_t console_print_connected_count(void)
        size_t ret =
          Serial.print(F("\t\t")) +
          Serial.print(ClientList.size()) +
          Serial.println(F(" connected client(s).\r\n"));
        Serial.flush();
        return ret;
        String tst(src);
        tst.toLowerCase();
        return tst.startsWith(itm);
        EthernetClient obj = server.available();
        if (obj)
          // convert to EthernetClientEx
          EthernetClientEx new_client(obj);
          // is it a new connection?
          if (!ClientList.exists(new_client))
            // accept new connection
            server_accept((EthernetClientEx *)&new_client);
            // send welcome banner
            new_client.println(F(WELCOME_BANNER_STRING));
            new_client.flush();
        // add itm to list
        ClientItem *itm = new ClientItem();
        itm->timestamp = millis();
        itm->index = ClientList.size();
        itm->client = new EthernetClientEx((*enetcli));
        ClientList.add(itm);
        // print notice on console
        Serial.print(F("Accepted new connection ("));
        Serial.print(itm->index);
        Serial.print(F(") from "));
        Serial.print(enetcli->remoteIP());
        Serial.print(':');
        Serial.println(enetcli->remotePort());
        Serial.println();
        Serial.flush();
        // print connected count
        console_print_connected_count();
        // return items index
        return itm->index;
        if (ClientList.size() == 0) return;
        ClientItem *itm;
        for (int idx = ClientList.size() - 1; idx >= 0; idx--)
          itm = ClientList.get(idx);
          if (itm->client->connected()==0)
            client_disconnected(itm);
            continue;
          if (itm->client->available())
            size_t rc = client_recv(itm);
            if (rc > 0)
              // echo to Serial port
              Serial.print(F("Client #"));
              Serial.print(F(" sent \""));
              Serial.print(itm->recv_buffer);
              Serial.println('\"');
              Serial.flush();
            // rc will == 0 if nothing received
            // rc will == -1 if client entered "exit"
          yield();
        int c;
        EthernetClientEx *cIn = (EthernetClientEx *)cli->client;
        cli->recv_buffer = "\0";
        cli->recv_cnt = 0;
        while ((c = cIn->read()) >= 0)
          cli->recv_buffer += (char)c;
          cli->recv_cnt++;
        // check to see if they typed "exit"
        if (test_for_cmd(String(F("exit")), cli->recv_buffer))
          client_disconnecting(cli);
          delay(1); // give up timeslice
          Serial.print(F("called client->stop() for #")); Serial.println(cli->index); Serial.flush();
          return -1;
        return cli->recv_cnt;
        Serial.print(cli->index);
        Serial.println(F(" is disconnecting."));
        // send Goodbye Banner
        send_to(cli->index, String(F(GOODBYE_BANNER_STRING)));
        Serial.flush();
        delay(1);
        Serial.print(F(" was connected for "));
        Serial.print(cli->elapsed() / 1000);
        Serial.print(F(" seconds, and has disconnected."));
        Serial.flush();
        // remove from list of clients
        ClientList.drop(cli->index);
        (*cli) = (*(ClientItem *)(unsigned long)0);
        // this causes seg fault ??
        //delete cli;
        return ClientList.send(str, idx);
        return ClientList.send2All(str);
      Bingo ? Sounds good?
      Again, sorry my C++ knowledge is very limited...
      HTH
        Looks good, but unfortunately I don't have the time to pursue this one at the moment.
        • soifS
          soifS
          soif
          Happy if i could have helped you to save you some time to find a way for implementing a solution.
          Let us know when you'd made some progress ;-)
          • soifS
            soifS
            soif
            BTW would you mind if I opened an issue at GH about this, linking to this topic, to help you and others developpers to have a reminder at the right place.
            And maybe another C++ hero would see it, and start working on it! :-p
              Sure, do that.
              • soifS
                soifS
                soif
                Issue #398 opened at GitHub.
                Now seeking for a C++ hero ! :-p :-p :-p
                HTH
                petewillP 1 Reply Last reply
                • soifS soif
                  HTH
                  petewillP
                  petewillP
                  petewill
                  @soif I'm no good at C++ so I can't help there :(
                  I was wondering if you have had your Ethernet gateway crash at all while connecting two controllers? I have been experimenting with Domoticz (my primary controller is Vera) and my Ethernet gateway crashes about every other day. I usually have to power cycle the gateway to get it to come back (sometimes the reset button works). I had previously run the MYSController for many days without issue (but that was when I was on 1.4.1). Just curious if you are getting the same results since you have a similar setup to me. What is the other controller you are trying to connect?
                  My setup is a little different from yours as I'm using Node-red on a Pi to connect to the Ethernet gateway (Domoticz thinks it's looking at a serial connection so I haven't noticed the disconnect messages like you).
                  • soifS
                    soifS
                    soif
                    My GW don't crash while the second controller get a connection, it just throw away the previous connection.
                    I've tested this with MYS v1.51, 1.54 and 2.0beta.
                    My two controllers are :
                    • Domoticz (primary)
                    • a simple telenet connection from the terminal
                    You can check this by having one controller connected, then from a terminal console type :
                      telnet IP_OF_THE_GW 5003
                    It will launch a telnet session an you will see the GW messages scrolling, but when you send any characters (ie just hit return), boom, the first connected controller is immediately disconnected.
                    • soifS soif
                      petewillP
                      petewillP
                      petewill
                      Interesting. My Vera and Node-red must constantly be disconnecting each other. This could be a great clue as to what's going on with my gateway crashing. The strange thing is the myscontroller worked so well before...
