  3. Using mqttGateway2.pl for Serial to MQTT on RaspberryPI
31 Posts 6 Posters 12.4k Views 6 Watching
  • aaron832A
    aaron832A
    aaron832
    Thanks it works great! On my forked version I just updated the script to contain the latest protocol definitions.
    • aaron832A aaron832
      @aaron832 good to hear!
      I had some issues today after a reboot of my server. Seemed like nothing was coming in at first through the serial gateway. Restarted a few times and looked at the serial output and then it started working suddenly... Fishy...
      Anyway, if you create a pull request I can merge your changes, if you like.
      • aaron832A
        aaron832A
        aaron832
        Done. I am a little confused about getting subscriptions working with your script. If a node should be receiving a message from the gateway... should it perform a one time request() or should the subscription be manually added to the /var/run/mqttMySensors/.... subscription file? I guess the confusion being a node that although it might receive a message from a gateway... it may not necessarily ask for it specifically.
          @aaron832 The idea is that a node subscribes to events automatically once it has requested a value once.
          The MySensors' MQTT implementation (for the ethernet gateway) will just subscribe to all events for a sensor once the sensor presents itself to the gateway. This is probably a more convenient implementation, but I just implemented it differently originally.
          aaron832A 1 Reply Last reply
          • YveauxY Yveaux
            aaron832A
            aaron832A
            aaron832
            @Yveaux I see. Well I added the request() call to my sensor and the perl script is picking it up. However, it is not able to write to the serial device I guess?
            20160201-12:14:57 RX: [105;4;2;0;2; ] fr=105 ci=004 c=C_REQ st=V_LIGHT noack -> Subscribe to '/mySensors/105/4/V_LIGHT'
            20160201-12:14:57 [Subscribe '/mySensors/105/4/V_LIGHT']
            20160201-12:14:57 TX: [105;4;1;0;2;0 ] fr=105 ci=004 c=C_SET st=V_LIGHT noack '0' -> Publish to gateway '/mySensors/105/4/V_LIGHT':'0'
            EV: error in callback (ignoring): Filehandle GEN0 opened only for input at /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2/AnyEvent/Handle.pm line 966.
            20160201-12:14:58 [105;255;3;0;15;]
            pi@raspi-hab:~ $ ls -la /dev/ttyMySensorsGateway
            lrwxrwxrwx 1 root root 10 Feb 1 12:14 /dev/ttyMySensorsGateway -> /dev/pts/2
            pi@raspi-hab:~ $ ls -la /dev/pts/2
            crw-rw---- 1 root tty 136, 2 Feb 1 12:14 /dev/pts/2
            pi@raspi-hab:~ $ ps -ealf | grep mq
            4 S root 17624 7825 0 80 0 - 1650 poll_s 12:14 pts/0 00:00:00 sudo ./mqttGateway2.pl --serial /dev/ttyMySensorsGateway
            4 S root 17631 17624 0 80 0 - 3815 SyS_ep 12:14 pts/0 00:00:01 /usr/bin/perl -w? ./mqttGateway2.pl --serial /dev/ttyMySensorsGateway
            0 S pi 17941 13671 0 80 0 - 1065 pipe_w 12:20 pts/4 00:00:00 grep --color=auto mq
            • aaron832A
              aaron832A
              aaron832
              I figure it has something to do with this line from http://cpansearch.perl.org/src/COOK/Device-SerialPort-1.04/SerialPort.pm
              # a handle object for ioctls: read-only ok
              $self->{HANDLE} = new_from_fd IO::Handle ($self->{FD}, "r");
              • hoegaarden_bierH
                hoegaarden_bierH
                hoegaarden_bier
                I am having the same problem when sending the response back to the node over MQTT.
                My mqttGateway2.pl crashes and gets in a infinite loop:
                Anyone got a sollution for this problem?
                20160216-21:38:05 TX: [10;10;1;0;24;1 ] fr=010 ci=010 c=C_SET st=V_VAR1 noack '1' -> Publish to gateway '/mySensors/10/10/V_VAR1':'1'
                20160216-21:38:05 Exception: Filehandle GEN0 opened only for input at /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2/AnyEvent/Handle.pm line 966.
                20160216-21:38:05 Restarting...
                20160216-21:38:05 .
                20160216-21:38:05 .
                20160216-21:38:05 trying to restore subscriptions
                20160216-21:38:05 Restoring previous subscriptions:
                20160216-21:38:05 Exception: Filehandle GEN0 opened only for input at /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2/AnyEvent/Handle.pm line 2308.
                • hoegaarden_bierH hoegaarden_bier
                  20160216-21:38:05 .
                  20160216-21:38:05 .
                  AnyEvent seems to crash. I run the script using Perl 5.14.2 on 64-bit Ubuntu; you seem to run at an ARM platform...
                  Probably there's the catch.
                  Can you try on an Intel Linux system?
                  • hoegaarden_bierH
                    hoegaarden_bierH
                    hoegaarden_bier
                    thanks for the response, unfortunately I am running the Openhab on my raspberry so switching to linux is not an option....
                    • aaron832A
                      aaron832A
                      aaron832
                      wrote on last edited by aaron832
                      @hoegaarden_bier I have the same setup (raspberry pi running openhab with a radio). Two of the different methods for getting Raspberry Pi Gateway sensor serial data to Openhab have failed me. One being the perl script mentioned here. Still haven't figured out why it won't work (fully) under a raspberry pi environment. The other option is having openhab read from serial rather than MQTT as mentioned here: http://forum.mysensors.org/topic/655/serial-gateway-connection-to-openhab/32 However, I have noticed that openhab will run the "Item Arduino received update" rule in parrallel when receiving serial messages in short succession. This causes the parrallel rule to overwrite the currently running rules' variable and it becomes a problem. Its also pretty messy and would require you to update your openhab rules on any mysensor updates.
                      Not to mention, the Serial Gateway you are likely running on your raspberry pi is for opensensor 1.4 (i think) and it going to be completely left in the dust as soon as 2.0 comes around I think.
                      If you dare, you can follow my project here: ~~https://github.com/aaron832/Arduino/tree/raspberry-gateway-MQTT~~ (Edit: See Newer Version Below)
                      Basically I took an updated Raspberry PI serial gateway and updated it to include MQTT.
                      Just run 'make' under libraries/MySensors and run libraries/MySensors/examples_RPi/PiGatewayMQTT
                      I am currently looking at getting this stuff onto the develop branch so that it will be around with 2.0
                      • Artur MajA
                        Artur MajA
                        Artur Maj
                        Thanks aaron832 for the gateway.
                        While running make all from under libraries/MySensors I am getting:
                        examples_RPi/PiGatewayMQTT.cpp:42:23: fatal error: mosquitto.h: No such file or directory
                        compilation terminated.
                        Makefile:102: recipe for target 'examples_RPi/PiGatewayMQTT.o' failed
                        make: *** [examples_RPi/PiGatewayMQTT.o] Error 1
                        Can you help?
                        • Artur MajA
                          Artur MajA
                          Artur Maj
                          OK, I had to install mosquitto libraries: sudo apt-get install libmosquitto-dev . All compiled fine. It is always good to ask.
                          • Artur MajA Artur Maj
                            aaron832A
                            aaron832A
                            aaron832
                            @Artur-Maj You also have the option of going towards a prototype 2.0 branch that is being worked on. Doing this, you will be able to get support and updates in the future.
                            My branch is here: https://github.com/aaron832/Arduino/tree/feature/MQTTSupport
                            Perform "make mqtt" under Arduino/libraries/MySensors
                            You can change any mqtt settings by uncommenting lines in Arduino/libraries/MySensors/examples_RPi/PiGateway.cpp
                            The format MQTT messages are as follows:
                            From MySensors to Openhab: mygateway1-out/node/sensor/command/ack/dataType
                            From OpenHab to MySensors: mygateway1-in/node/sensor/command/ack/dataType
                            There is still more work to be done, but it works at least as well as the previous version.
                            Artur MajA 2 Replies Last reply
                              Artur MajA
                              Artur MajA
                              Artur Maj
                              @aaron832 Thanks I will do that. In fact I am connecting MySensors to eventghost not OpenHab but the ide MQTT is the same.
                                Artur MajA
                                Artur MajA
                                Artur Maj
                                @aaron832 While running make all from libraries/MySensors I am getting errors like that:
                                examples_RPi/PiGateway.o: In function transportSendWrite(unsigned char, MyMessage&)': /home/artur/Arduino-feature-MQTTSupport/libraries/MySensors/./core/MyTransportNRF24.cpp:102: undefined reference to RF24::powerUp()'
                                /home/artur/Arduino-feature-MQTTSupport/libraries/MySensors/./core/MyTransportNRF24.cpp:103: undefined reference to RF24::stopListening()' /home/artur/Arduino-feature-MQTTSupport/libraries/MySensors/./core/MyTransportNRF24.cpp:104: undefined reference to RF24::openWritingPipe
                                and continues....
                                I have installed : https://github.com/TMRh20/RF24.
                                What I am doing wrong?
                                • aaron832A
                                  aaron832A
                                  aaron832
                                  Try typing
                                  "uname -m"
                                  into your console (that hosts the gateway). If it does not say
                                  "armv6l" or "armv7l" (edit: correction)
                                  then the Makefile will not include -lrf24-bcm in the LDFLAGS (libraries include). If this is the problem then what hardware are you making the gateway on?
                                  Artur MajA 1 Reply Last reply
                                    Try typing
                                    "uname -m"
                                    Artur MajA
                                    Artur MajA
                                    Artur Maj
                                    @aaron832 It says armv7l. Please, note it is not armv71 the last character is small "L" not 1 (one). This is raspberry pi 2 with ubuntu mate 15.10. I am going to edit Makefile replacing armv71 with armv7l and see what's happening. Thanks again.
                                    • C
                                      C
                                      cingolanifede
                                      Hi, i tried to make the script work but i couldnt. did anybody make it work? I used the serial gateway option, installed all the libraries.
                                      . thankspi@raspberrypi:/ $ sudo ./mqttGateway2.pl --serial /dev/ttyUSB0
                                      Subroutine main::inet_aton redefined at /usr/share/perl/5.20/Exporter.pm line 66.
                                      at ./mqttGateway2.pl line 42.
                                      given is experimental at ./mqttGateway2.pl line 267.
                                      when is experimental at ./mqttGateway2.pl line 269.
                                      when is experimental at ./mqttGateway2.pl line 270.
                                      when is experimental at ./mqttGateway2.pl line 271.
                                      when is experimental at ./mqttGateway2.pl line 272.
                                      Smartmatch is experimental at ./mqttGateway2.pl line 313.
                                      Smartmatch is experimental at ./mqttGateway2.pl line 332.
                                      given is experimental at ./mqttGateway2.pl line 400.
                                      when is experimental at ./mqttGateway2.pl line 402.
                                      when is experimental at ./mqttGateway2.pl line 411.
                                      Name "main::fh" used only once: possible typo at ./mqttGateway2.pl line 207.
                                      can't create /var/run/mqttMySensors/Gateway__dev_ttyUSB0: No existe el fichero o el directorio at ./mqttGateway2.pl line 452.
                                      What does it means?
                                      • C
                                        C
                                        cingolanifede
                                        @Yveaux Keep on getting this error
                                        • C cingolanifede
                                          What does it means?
                                          This path doesn't exist. Create it, or change the path.
                                          All others are warnings, due to an incompatible perl version you're using.
                                          C 1 Reply Last reply
