  3. How to assign static node ID?
8 Posts 4 Posters 6.2k Views 4 Watching
  • G Offline
    G Offline
    George Whitehouse
    Gday,
    I have the MQTT Client gateway running and the existing nodes are ok however a new motion sensor node I just built does not seem to be working.
    Could someone let me know how you set a static node ID.
    Regards,
    George
    • mfalkviddM Offline
      gw.begin(NULL, 5) sets the node id to 5
      • G Offline
        G Offline
        George Whitehouse
        Ok thanks for that.
        Where should I put that code in the sketch?
        Cheers,
          Replace your current gw.begin
          • G Offline
            G Offline
            George Whitehouse
            I am looking at the development version of the MotionSensor sketch and can not seem to find a gw.begin
            Regards,
            George
            • S Offline
              Use #define MY_NODE_ID 10 (where 10 is your ID).
              Example: https://github.com/mysensors/Arduino/blob/7ee39509ebaf05900db0f4cf6af8eaad2b970d30/libraries/MySensors/examples/OregonSensorDecode/OregonSensorDecode.ino
              G 1 Reply Last reply
              • S sundberg84
                G Offline
                G Offline
                George Whitehouse
                @sundberg84 Fantastic thanks for that it worked perfectly.
                Cheers,
                George
                • G Offline
                  G Offline
                  GertSanders
                  Here are the defines I put in my sketches for the development library:
                  //#define MY_NODE_ID 1
                  //#define MY_PARENT_ID 0
                  // Possible values for Arduino IDE: 9600, 19200, 38400, 57600, 74880, 115200, 230400, 250000
                  // The last three values are only possible if the mcu works at 16Mhz or more, not possible for 8MHz operation.
                  //#define MY_BAUD_RATE 57600
                  //#define MY_RADIO_NRF24
                  // Enable serial gateway
                  //#define MY_GATEWAY_SERIAL
                  //#define MY_REPEATER_FEATURE
                  // Flash leds on rx/tx/err
                  //#define MY_LEDS_BLINKING_FEATURE
                  // Set blinking period
                  // Enable inclusion mode
                  //#define MY_DEFAULT_ERR_LED_PIN 5  // Error led pin
                  //#define MY_DEFAULT_TX_LED_PIN  7  // the PCB, on board LED
                  // possible values: RF24_PA_LOW (is default on gateway), RF24_PA_MED, RF24_PA_HIGH, RF24_PA_MAX (is default on nodes)
                  // RF channel for the sensor net, 0-127. Channel 76 is the default in all library examples
                  //#define MY_RF24_CHANNEL     76
                  //RF24_250KBPS for 250kbs (default), RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
                  //#define MY_RF24_DATARATE      RF24_250KBPS
