  3. OpenHAB
  4. openHAB binding
openHAB binding
89 Posts 30 Posters 74.9k Views 33 Watching
  • andredtsA andredts
    @bkl Great work, much better than using rules. For me it worked on the first try. I will be very happy to test what I can.
    Just one question, can we only read sensors, or can we interact, as in a relay switch? I tried to use V_LIGHT to add a light switch and got this log "Binding configuration of type 'mysensors' of item ‘Relay‘ could not be parsed correctly.
    org.openhab.model.item.binding.BindingConfigParseException: Invalid Type: V_LIGHT"
    andredtsA
    andredtsA
    andredts
    Hi, made some more test, and saw that bidding suggests that I use V_STATUS, so I did. Now I can see the change in the relay status and I can even turn it OFF by the OH inteface, but I can´t turn it ON. Maybe I can´t turn it on because I use inverted logic, where High is OFF, does any off that makes sense?
    bklB 1 Reply Last reply
    • T
      ted
      Tested on openhab 1.8. works very well. Thanks!
        bklB
        bklB
        bkl
        @andredts
        Can you try and post the sketch you are using? Or are you using the RelayWithButtonActuator Example?
        I don't thing that the inverted logic should have anything to do with it.
        andredtsA 1 Reply Last reply
        • bklB bkl
          @andredts
          andredtsA
          andredtsA
          andredts
          @bkl
          Hi, I´m using the MultiRelayButton 0.9b sketch, that I found here in the forum:
          0_1456141716367_Bot_es_relays.ino
          If you like I can try RelayWithButtonActuator Example, but I like the other better because it works when the server is down, no aka from server to make the state change.
            @bkl
            bklB
            bklB
            bkl
            @andredts
            It was a bug in the code. If you download the new jar then it should be fixed.
            andredtsA 2 Replies Last reply
            • bklB bkl
              @andredts
              andredtsA
              andredtsA
              andredts
              @bkl
              Thanks, I will give it a try and return to you with feedback.
              • bklB bkl
                @andredts
                andredtsA
                andredtsA
                andredts
                @bkl
                Working beautifully. I have three relay and three switches on the arduino, and no matter how fast I press them I got no miss command. Thanks
                I got one bug, but I think it is Openhab's, when I changed the item file with Openhab running and the switch in the user interface got inverted ON-OFF and OFF-ON.
                • andredtsA
                  andredtsA
                  andredts
                  wrote on last edited by andredts
                  Today I was testing Motion and Door sensors. Motion worked as expected, but the door sensor only works if it's set in OH as a "switch" item(on and off feedback), if you set it as a "contact"(open/closed) item you get the log: " No item configured for "5;1;V_TRIPPED". I have used the example sketch for the sensor
                  N bklB 2 Replies Last reply
                    N
                    N
                    nikos1671
                    @andredts I also notice this with the door sensors. Normal the item must be contact and not switch.
                      bklB
                      bklB
                      bkl
                      @andredts
                      Thanks for the feedback, this is now fixed.
                      • bklB bkl
                        @andredts
                        andredtsA
                        andredtsA
                        andredts
                        @bkl
                        Thank you for your great work. Happy to help with what I can.
                        Already tested and fully abandoned rules for setting up OpenHab with Mysensors.
                        Next I will try a analogic read, based on the dust sensor.
                          @bkl
                          andredtsA
                          andredtsA
                          andredts
                          @andredts
                          Using this bidding for 15 days, with 3 relay, a Micro Sensebender, Humidity, Motion and Water level (base on dust sensor). And everything is working great.
                          Thanks again.
                          • Pavel HrudkaP
                            Pavel HrudkaP
                            Pavel Hrudka
                            Hi.
                            I just added your binding and I am very happy for it because I have spent quite some time to figure out, how do I integrate mySensors in to Openhab.
                            My setup
                            RPI2
                            did apt-get update && apt-get upgrade
                            OpenHab (openHAB runtime has been started (v1.8.1))
                            I have NRF24L01+ connected directly to RPI using SPI.
                            I am running PiGatewaySerial service and Iam able to see communication when i do
                            sudo cat /dev/ttyMySensorsGateway
                            for example
                            7;255;3;0;15;0
                            7;255;0;0;17;1.5.4
                            7;255;3;0;6;0
                            7;255;3;0;11;Humidity
                            7;255;3;0;12;1.0
                            7;0;0;0;7;
                            7;1;0;0;6;
                            My problem is that openHab is unable to access /dev/ttyMySensorsGateway
                            I see error in my logs
                            2016-03-11 23:30:11.288 [ERROR] [.o.b.m.internal.gateway.Serial] - Unable to find Serial port '/dev/ttyMySensorsGateway'
                            java.lang.NullPointerException: null
                                    at org.openhab.binding.mysensors.internal.gateway.Serial.write(Serial.java:82) ~[na:na]
                                    at org.openhab.binding.mysensors.internal.MySensorsBinding.execute(MySensorsBinding.java:178) ~[na:na]
                                    at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:156) ~[na:na]
                                    at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173) ~[na:na]
                            I found @BastienVH post and modified /etc/init.d/openhab JAVA_ARGS_DEFAULT section and added at the end of defintion
                             -Dgnu.io.rxtx.SerialPorts=/dev/ttyMySensorsGateway"
                            and restarted service
                            Sadly, there was no change.
                            Please can you help?
                            Thank you.
                            • Pavel HrudkaP Pavel Hrudka
                              Hi.
                              My setup
                              RPI2
                              for example
                              7;255;3;0;15;0
                              7;255;0;0;17;1.5.4
                              7;255;3;0;6;0
                              7;255;3;0;12;1.0
                              7;0;0;0;7;
                              7;1;0;0;6;
                              Thank you.
                              andredtsA
                              andredtsA
                              andredts
                              @Pavel-Hrudka
                              I use RP2 with internal serial connected directly to ATmega328 chip. So it is also a unconventional serial. And for that to work I had to put the line " -Dgnu.io.rxtx.SerialPorts=/dev/ttyMySensorsGateway" on my start.sh file, before the line that has ".jar"
                              Hope it helps
                                Hi.
                                My setup
                                RPI2
                                for example
                                7;255;3;0;15;0
                                7;255;0;0;17;1.5.4
                                7;255;3;0;6;0
                                7;255;3;0;12;1.0
                                7;0;0;0;7;
                                7;1;0;0;6;
                                Thank you.
                                andredtsA
                                andredtsA
                                andredts
                                @Pavel-Hrudka
                                On my last post I miss lid you, copping your own line, but actually to use raspberry internal serial you have to add to Openhab's start.sh "-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 " before the line with the ".jar" because the serial got to start before you run the biddings.
                                Hope it helps.
                                • Pavel HrudkaP
                                  Pavel HrudkaP
                                  Pavel Hrudka
                                  Hi thank you.
                                  I solved my issue, but when I wanted to update my post, the thread was locked.
                                  Here in this post its said that I should create link to virtual port like this
                                  sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                                  Pointing OpenHab binding to this port solved my problem.
                                  I did try to add command line parameter to /init.d script for OpenHab but that did not work.
                                  Cheers.
                                  Pavel
                                  • FrancoisF
                                    FrancoisF
                                    Francois
                                    Hi I am new to openHAB how do you configure a relay node? I do see the node in the logs but the relay don't what to switch on or off. I have my temp and humidity sensors working already.
                                    18:38:50.450 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor sensor found (Dimmable device of some kind): node-id=95, sensor-id=0 with type S_DIMMER
                                     * Example item: 95;0;V_STATUS             - Binary status. (on/off)
                                     * Example item: 95;0;V_PERCENTAGE         - Percentage value. 0-100 (%)
                                     * Example item: 95;0;V_WATT               - Watt value for power meters
                                    Regards
                                    Francois
                                    • Mark JeffordM
                                      Mark JeffordM
                                      Mark Jefford
                                      Quick question, trying to integrate the mysprinkler project into openhab.
                                      getting stuck using V_VAR1-3 i need to somehow export out a runtime variable to the remote ardunio... any idea how i can get the V_VAR1-3 to output something that is not binary? i.e a runtime of 5 min for sprinklers...
                                      i have the triggering working, just can't configure the runtime.
                                      any help appreciated.. will do a guide if it get it working :)
                                      • Harry GomezH
                                        Harry GomezH
                                        Harry Gomez
                                        I recently moved my OpenHab install from a Raspberry PI 2 to a Raspberry Pi 3 from wheezy to jessie and now the biding is not working. Everything was working perfectly with the previous install now i keep getting the following message, serial port exist and it works. I suspect it has do to with the change from wheezy to jessie but nothing i tries is working.
                                        2016-03-25 19:28:20 DEBUG o.o.b.m.i.MySensorsBinding[:96]- activate
                                        2016-03-25 19:28:20 ERROR o.o.b.m.i.gateway.Serial[:70]- Unable to find Serial port '/dev/ttyUSB0'
                                        [ 3137.417846] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
                                        [ 3137.520958] usb 1-1.5: New USB device found, idVendor=1a86, idProduct=7523
                                        [ 3137.520979] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
                                        [ 3137.520992] usb 1-1.5: Product: USB2.0-Serial
                                        [ 3137.522050] ch341 1-1.5:1.0: ch341-uart converter detected
                                        [ 3137.525880] usb 1-1.5: ch341-uart converter now attached to ttyUSB0
                                        regards
                                        Harry
                                        • Harry GomezH Harry Gomez
                                          regards
                                          Harry
                                          ted
                                          @Harry-Gomez
                                          From https://github.com/openhab/openhab/wiki/Serial-Binding
                                          If you are using non standard serial ports you have to adapt start.sh to have the serial port included. the java command line should then include the following parameters:
                                          whereas ttyAMA0 is the path to your serial port. Please be aware to change all scripts you might use for startup (debug, automatic start in linux,...)
                                          Harry GomezH 1 Reply Last reply
