  3. OpenHAB
  4. openHAB binding
openHAB binding
89 Posts 30 Posters 75.0k Views 33 Watching
  • bklB bkl
    @andredts
    It was a bug in the code. If you download the new jar then it should be fixed.
    andredtsA
    andredtsA
    andredts
    @bkl
    Working beautifully. I have three relay and three switches on the arduino, and no matter how fast I press them I got no miss command. Thanks
    I got one bug, but I think it is Openhab's, when I changed the item file with Openhab running and the switch in the user interface got inverted ON-OFF and OFF-ON.
    • andredtsA
      andredtsA
      andredts
      wrote on last edited by andredts
      Today I was testing Motion and Door sensors. Motion worked as expected, but the door sensor only works if it's set in OH as a "switch" item(on and off feedback), if you set it as a "contact"(open/closed) item you get the log: " No item configured for "5;1;V_TRIPPED". I have used the example sketch for the sensor
      N bklB 2 Replies Last reply
      • andredtsA andredts
        N
        N
        nikos1671
        @andredts I also notice this with the door sensors. Normal the item must be contact and not switch.
          bklB
          bklB
          bkl
          @andredts
          Thanks for the feedback, this is now fixed.
          andredtsA 1 Reply Last reply
          • bklB bkl
            @andredts
            andredtsA
            andredtsA
            andredts
            @bkl
            Thank you for your great work. Happy to help with what I can.
            Already tested and fully abandoned rules for setting up OpenHab with Mysensors.
            Next I will try a analogic read, based on the dust sensor.
              @bkl
              andredtsA
              andredtsA
              andredts
              @andredts
              Using this bidding for 15 days, with 3 relay, a Micro Sensebender, Humidity, Motion and Water level (base on dust sensor). And everything is working great.
              Thanks again.
              • Pavel HrudkaP
                Pavel HrudkaP
                Pavel Hrudka
                Hi.
                I just added your binding and I am very happy for it because I have spent quite some time to figure out, how do I integrate mySensors in to Openhab.
                My setup
                RPI2
                did apt-get update && apt-get upgrade
                OpenHab (openHAB runtime has been started (v1.8.1))
                I have NRF24L01+ connected directly to RPI using SPI.
                I am running PiGatewaySerial service and Iam able to see communication when i do
                sudo cat /dev/ttyMySensorsGateway
                for example
                7;255;3;0;15;0
                7;255;0;0;17;1.5.4
                7;255;3;0;6;0
                7;255;3;0;11;Humidity
                7;255;3;0;12;1.0
                7;0;0;0;7;
                7;1;0;0;6;
                My problem is that openHab is unable to access /dev/ttyMySensorsGateway
                I see error in my logs
                2016-03-11 23:30:11.288 [ERROR] [.o.b.m.internal.gateway.Serial] - Unable to find Serial port '/dev/ttyMySensorsGateway'
                java.lang.NullPointerException: null
                        at org.openhab.binding.mysensors.internal.gateway.Serial.write(Serial.java:82) ~[na:na]
                        at org.openhab.binding.mysensors.internal.MySensorsBinding.execute(MySensorsBinding.java:178) ~[na:na]
                        at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:156) ~[na:na]
                        at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173) ~[na:na]
                I found @BastienVH post and modified /etc/init.d/openhab JAVA_ARGS_DEFAULT section and added at the end of defintion
                 -Dgnu.io.rxtx.SerialPorts=/dev/ttyMySensorsGateway"
                and restarted service
                Sadly, there was no change.
                Please can you help?
                Thank you.
                andredtsA 2 Replies Last reply
                • Pavel HrudkaP Pavel Hrudka
                  Hi.
                  My setup
                  RPI2
                  for example
                  7;255;3;0;15;0
                  7;255;0;0;17;1.5.4
                  7;255;3;0;6;0
                  7;255;3;0;12;1.0
                  7;0;0;0;7;
                  7;1;0;0;6;
                  Thank you.
                  andredtsA
                  andredtsA
                  andredts
                  @Pavel-Hrudka
                  I use RP2 with internal serial connected directly to ATmega328 chip. So it is also a unconventional serial. And for that to work I had to put the line " -Dgnu.io.rxtx.SerialPorts=/dev/ttyMySensorsGateway" on my start.sh file, before the line that has ".jar"
                  Hope it helps
                    Hi.
                    My setup
                    RPI2
                    for example
                    7;255;3;0;15;0
                    7;255;0;0;17;1.5.4
                    7;255;3;0;6;0
                    7;255;3;0;12;1.0
                    7;0;0;0;7;
                    7;1;0;0;6;
                    Thank you.
                    andredtsA
                    andredtsA
                    andredts
                    @Pavel-Hrudka
                    On my last post I miss lid you, copping your own line, but actually to use raspberry internal serial you have to add to Openhab's start.sh "-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 " before the line with the ".jar" because the serial got to start before you run the biddings.
                    Hope it helps.
                    • Pavel HrudkaP
                      Pavel HrudkaP
                      Pavel Hrudka
                      Hi thank you.
                      I solved my issue, but when I wanted to update my post, the thread was locked.
                      Here in this post its said that I should create link to virtual port like this
                      sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                      Pointing OpenHab binding to this port solved my problem.
                      I did try to add command line parameter to /init.d script for OpenHab but that did not work.
                      Cheers.
                      Pavel
                      • FrancoisF
                        FrancoisF
                        Francois
                        Hi I am new to openHAB how do you configure a relay node? I do see the node in the logs but the relay don't what to switch on or off. I have my temp and humidity sensors working already.
                        18:38:50.450 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor sensor found (Dimmable device of some kind): node-id=95, sensor-id=0 with type S_DIMMER
                         * Example item: 95;0;V_STATUS             - Binary status. (on/off)
                         * Example item: 95;0;V_PERCENTAGE         - Percentage value. 0-100 (%)
                         * Example item: 95;0;V_WATT               - Watt value for power meters
                        Regards
                        Francois
                        • Mark JeffordM
                          Mark JeffordM
                          Mark Jefford
                          Quick question, trying to integrate the mysprinkler project into openhab.
                          getting stuck using V_VAR1-3 i need to somehow export out a runtime variable to the remote ardunio... any idea how i can get the V_VAR1-3 to output something that is not binary? i.e a runtime of 5 min for sprinklers...
                          i have the triggering working, just can't configure the runtime.
                          any help appreciated.. will do a guide if it get it working :)
                          • Harry GomezH
                            Harry GomezH
                            Harry Gomez
                            I recently moved my OpenHab install from a Raspberry PI 2 to a Raspberry Pi 3 from wheezy to jessie and now the biding is not working. Everything was working perfectly with the previous install now i keep getting the following message, serial port exist and it works. I suspect it has do to with the change from wheezy to jessie but nothing i tries is working.
                            2016-03-25 19:28:20 DEBUG o.o.b.m.i.MySensorsBinding[:96]- activate
                            2016-03-25 19:28:20 ERROR o.o.b.m.i.gateway.Serial[:70]- Unable to find Serial port '/dev/ttyUSB0'
                            [ 3137.417846] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
                            [ 3137.520958] usb 1-1.5: New USB device found, idVendor=1a86, idProduct=7523
                            [ 3137.520979] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
                            [ 3137.520992] usb 1-1.5: Product: USB2.0-Serial
                            [ 3137.522050] ch341 1-1.5:1.0: ch341-uart converter detected
                            [ 3137.525880] usb 1-1.5: ch341-uart converter now attached to ttyUSB0
                            regards
                            Harry
                            • Harry GomezH Harry Gomez
                              regards
                              Harry
                              ted
                              @Harry-Gomez
                              From https://github.com/openhab/openhab/wiki/Serial-Binding
                              If you are using non standard serial ports you have to adapt start.sh to have the serial port included. the java command line should then include the following parameters:
                              whereas ttyAMA0 is the path to your serial port. Please be aware to change all scripts you might use for startup (debug, automatic start in linux,...)
                              Harry GomezH 1 Reply Last reply
                              • T ted
                                @Harry-Gomez
                                Harry GomezH
                                Harry GomezH
                                Harry Gomez
                                I tried that but it did not work - this is how part of the /etc/init.d/openhab looks - any other ideas - i did not needed this with the RPi2 and wheezy
                                JAVA_ARGS_DEFAULT="-Dosgi.clean=true
                                -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0
                                -Declipse.ignoreApp=true
                                -Dosgi.noShutdown=true
                                -Djetty.port=${HTTP_PORT}
                                -Dopenhab.configfile="${OPENHAB_CONF_DIR}/configurations/openhab.cfg"
                                -Dopenhab.configdir="${OPENHAB_CONF_DIR}/configurations"
                                -Dopenhab.logdir="${OPENHAB_LOG_DIR}"
                                -Dsmarthome.userdata="${OPENHAB_USER_DATA_DIR}"
                                -Djetty.home="${OPENHAB_DIR}"
                                -Djetty.port.ssl=${HTTPS_PORT}
                                -Djetty.config="${OPENHAB_CONF_DIR}/jetty"
                                -Djetty.logs="${OPENHAB_LOG_DIR}"
                                -Djetty.rundir="${OPENHAB_DIR}"
                                -Dfelix.fileinstall.dir="${OPENHAB_DIR}/addons"
                                -Dfelix.fileinstall.filter=.*\.jar
                                -Djava.library.path="${OPENHAB_DIR}/lib"
                                -Djava.security.auth.login.config="${OPENHAB_CONF_DIR}/login.conf"
                                -Dorg.quartz.properties="${OPENHAB_CONF_DIR}/quartz.properties"
                                -Dequinox.ds.block_timeout=240000
                                -Dequinox.scr.waitTimeOnBlock=60000
                                -Dfelix.fileinstall.active.level=4
                                -Djava.awt.headless=true
                                -jar ${LAUNCHER}
                                -configuration ${OPENHAB_WORKSPACE_DIR}
                                -data ${OPENHAB_WORKSPACE_DIR}
                                -console ${TELNET_PORT}"
                                  -jar ${LAUNCHER}
                                  ted
                                  @Harry-Gomez
                                  What if you modify start.sh and start openhab from console? I'm not a linux expert; could it be that the usb driver was initiated after /etc/init.d is processed ?
                                  Harry GomezH zeblongZ 2 Replies Last reply
                                  • T ted
                                    @Harry-Gomez
                                    Harry GomezH
                                    Harry GomezH
                                    Harry Gomez
                                    @ted
                                    Thank worked with change to openhab.sh - I had to put -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0 at the begining to be able to work. I'm not sure why it would workthere and not on the /etc/init.d/openhab. Also there is not start.sh when you install using apt-get it is named opendhab.sh
                                    Thanks!!
                                    • FrancoisF
                                      FrancoisF
                                      Francois
                                      wrote on last edited by Francois
                                      #32
                                      Hi what is the syntax for a relay in openhab using this binding?
                                      This in what I get in the log but the light do not switch on or off.
                                      2016-03-27 20:37:00.068 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
                                      2016-03-27 20:37:00.889 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command OFF
                                      2016-03-27 20:37:01.622 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
                                      2016-03-27 20:37:02.407 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command OFF
                                      2016-03-27 20:37:03.247 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
                                      This is the syntax that I am use and it is not working. Also try V_LIGHT without any luck.
                                      Switch LightSwitch_GF_Study	"Study Light  [%s]"				<light> 	(GF_Study)			{mysensors="41;1;V_BINARY"}
                                      andredtsA bklB 2 Replies Last reply
                                      • FrancoisF Francois
                                        andredtsA
                                        andredtsA
                                        andredts
                                        @Francois
                                        Hi, I use {mysensors="12;0;V_STATUS"}. Remember to give your node a ID, because OH does not give one.
                                          bklB
                                          bklB
                                          bkl
                                          Hi @Francois
                                          The syntax look OK.
                                          This is what i have working.
                                          Switch  Relay_10_0              "Relay 1"                       <none>                                  {mysensors="10;0;V_STATUS"}
                                          Try and turn on debug log for mysensors
                                          Add this to logback.xml
                                          <logger name="org.openhab.binding.mysensors" level="DEBUG" />
