  3. OpenHAB
  4. openHAB binding
openHAB binding
89 Posts 30 Posters 75.3k Views 33 Watching
  • bklB bkl
    @andredts
    Can you try and post the sketch you are using? Or are you using the RelayWithButtonActuator Example?
    I don't thing that the inverted logic should have anything to do with it.
    andredtsA
    andredtsA
    andredts
    @bkl
    Hi, I´m using the MultiRelayButton 0.9b sketch, that I found here in the forum:
    0_1456141716367_Bot_es_relays.ino
    If you like I can try RelayWithButtonActuator Example, but I like the other better because it works when the server is down, no aka from server to make the state change.
    bklB 1 Reply Last reply
    • andredtsA andredts
      @bkl
      bklB
      bklB
      bkl
      @andredts
      It was a bug in the code. If you download the new jar then it should be fixed.
      andredtsA 2 Replies Last reply
      • bklB bkl
        @andredts
        andredtsA
        andredtsA
        andredts
        @bkl
        Thanks, I will give it a try and return to you with feedback.
        • bklB bkl
          @andredts
          andredtsA
          andredtsA
          andredts
          @bkl
          Working beautifully. I have three relay and three switches on the arduino, and no matter how fast I press them I got no miss command. Thanks
          I got one bug, but I think it is Openhab's, when I changed the item file with Openhab running and the switch in the user interface got inverted ON-OFF and OFF-ON.
          • andredtsA
            andredtsA
            andredts
            wrote on last edited by andredts
            Today I was testing Motion and Door sensors. Motion worked as expected, but the door sensor only works if it's set in OH as a "switch" item(on and off feedback), if you set it as a "contact"(open/closed) item you get the log: " No item configured for "5;1;V_TRIPPED". I have used the example sketch for the sensor
            N bklB 2 Replies Last reply
              N
              N
              nikos1671
              @andredts I also notice this with the door sensors. Normal the item must be contact and not switch.
                bklB
                bklB
                bkl
                @andredts
                Thanks for the feedback, this is now fixed.
                andredtsA 1 Reply Last reply
                • bklB bkl
                  @andredts
                  andredtsA
                  andredtsA
                  andredts
                  @bkl
                  Thank you for your great work. Happy to help with what I can.
                  Already tested and fully abandoned rules for setting up OpenHab with Mysensors.
                  Next I will try a analogic read, based on the dust sensor.
                    @bkl
                    andredtsA
                    andredtsA
                    andredts
                    @andredts
                    Using this bidding for 15 days, with 3 relay, a Micro Sensebender, Humidity, Motion and Water level (base on dust sensor). And everything is working great.
                    Thanks again.
                    • Pavel HrudkaP
                      Pavel HrudkaP
                      Pavel Hrudka
                      Hi.
                      I just added your binding and I am very happy for it because I have spent quite some time to figure out, how do I integrate mySensors in to Openhab.
                      My setup
                      RPI2
                      did apt-get update && apt-get upgrade
                      OpenHab (openHAB runtime has been started (v1.8.1))
                      I have NRF24L01+ connected directly to RPI using SPI.
                      I am running PiGatewaySerial service and Iam able to see communication when i do
                      sudo cat /dev/ttyMySensorsGateway
                      for example
                      7;255;3;0;15;0
                      7;255;0;0;17;1.5.4
                      7;255;3;0;6;0
                      7;255;3;0;11;Humidity
                      7;255;3;0;12;1.0
                      7;0;0;0;7;
                      7;1;0;0;6;
                      My problem is that openHab is unable to access /dev/ttyMySensorsGateway
                      I see error in my logs
                      2016-03-11 23:30:11.288 [ERROR] [.o.b.m.internal.gateway.Serial] - Unable to find Serial port '/dev/ttyMySensorsGateway'
                      java.lang.NullPointerException: null
                              at org.openhab.binding.mysensors.internal.gateway.Serial.write(Serial.java:82) ~[na:na]
                              at org.openhab.binding.mysensors.internal.MySensorsBinding.execute(MySensorsBinding.java:178) ~[na:na]
                              at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:156) ~[na:na]
                              at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173) ~[na:na]
                      I found @BastienVH post and modified /etc/init.d/openhab JAVA_ARGS_DEFAULT section and added at the end of defintion
                       -Dgnu.io.rxtx.SerialPorts=/dev/ttyMySensorsGateway"
                      and restarted service
                      Sadly, there was no change.
                      Please can you help?
                      Thank you.
                      • Pavel HrudkaP Pavel Hrudka
                        Hi.
                        My setup
                        RPI2
                        for example
                        7;255;3;0;15;0
                        7;255;0;0;17;1.5.4
                        7;255;3;0;6;0
                        7;255;3;0;12;1.0
                        7;0;0;0;7;
                        7;1;0;0;6;
                        Thank you.
                        andredtsA
                        andredtsA
                        andredts
                        @Pavel-Hrudka
                        I use RP2 with internal serial connected directly to ATmega328 chip. So it is also a unconventional serial. And for that to work I had to put the line " -Dgnu.io.rxtx.SerialPorts=/dev/ttyMySensorsGateway" on my start.sh file, before the line that has ".jar"
                        Hope it helps
                          Hi.
                          My setup
                          RPI2
                          for example
                          7;255;3;0;15;0
                          7;255;0;0;17;1.5.4
                          7;255;3;0;6;0
                          7;255;3;0;12;1.0
                          7;0;0;0;7;
                          7;1;0;0;6;
                          Thank you.
                          andredtsA
                          andredtsA
                          andredts
                          @Pavel-Hrudka
                          On my last post I miss lid you, copping your own line, but actually to use raspberry internal serial you have to add to Openhab's start.sh "-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 " before the line with the ".jar" because the serial got to start before you run the biddings.
                          Hope it helps.
                          • Pavel HrudkaP
                            Pavel HrudkaP
                            Pavel Hrudka
                            Hi thank you.
                            I solved my issue, but when I wanted to update my post, the thread was locked.
                            Here in this post its said that I should create link to virtual port like this
                            sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                            Pointing OpenHab binding to this port solved my problem.
                            I did try to add command line parameter to /init.d script for OpenHab but that did not work.
                            Cheers.
                            Pavel
                            • FrancoisF
                              FrancoisF
                              Francois
                              Hi I am new to openHAB how do you configure a relay node? I do see the node in the logs but the relay don't what to switch on or off. I have my temp and humidity sensors working already.
                              18:38:50.450 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor sensor found (Dimmable device of some kind): node-id=95, sensor-id=0 with type S_DIMMER
                               * Example item: 95;0;V_STATUS             - Binary status. (on/off)
                               * Example item: 95;0;V_PERCENTAGE         - Percentage value. 0-100 (%)
                               * Example item: 95;0;V_WATT               - Watt value for power meters
                              Regards
                              Francois
                              • Mark JeffordM
                                Mark JeffordM
                                Mark Jefford
                                Quick question, trying to integrate the mysprinkler project into openhab.
                                getting stuck using V_VAR1-3 i need to somehow export out a runtime variable to the remote ardunio... any idea how i can get the V_VAR1-3 to output something that is not binary? i.e a runtime of 5 min for sprinklers...
                                i have the triggering working, just can't configure the runtime.
                                any help appreciated.. will do a guide if it get it working :)
                                • Harry GomezH
                                  Harry GomezH
                                  Harry Gomez
                                  I recently moved my OpenHab install from a Raspberry PI 2 to a Raspberry Pi 3 from wheezy to jessie and now the biding is not working. Everything was working perfectly with the previous install now i keep getting the following message, serial port exist and it works. I suspect it has do to with the change from wheezy to jessie but nothing i tries is working.
                                  2016-03-25 19:28:20 DEBUG o.o.b.m.i.MySensorsBinding[:96]- activate
                                  2016-03-25 19:28:20 ERROR o.o.b.m.i.gateway.Serial[:70]- Unable to find Serial port '/dev/ttyUSB0'
                                  [ 3137.417846] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
                                  [ 3137.520958] usb 1-1.5: New USB device found, idVendor=1a86, idProduct=7523
                                  [ 3137.520979] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
                                  [ 3137.520992] usb 1-1.5: Product: USB2.0-Serial
                                  [ 3137.522050] ch341 1-1.5:1.0: ch341-uart converter detected
                                  [ 3137.525880] usb 1-1.5: ch341-uart converter now attached to ttyUSB0
                                  regards
                                  Harry
                                  • Harry GomezH Harry Gomez
                                    regards
                                    Harry
                                    ted
                                    @Harry-Gomez
                                    From https://github.com/openhab/openhab/wiki/Serial-Binding
                                    If you are using non standard serial ports you have to adapt start.sh to have the serial port included. the java command line should then include the following parameters:
                                    whereas ttyAMA0 is the path to your serial port. Please be aware to change all scripts you might use for startup (debug, automatic start in linux,...)
                                    Harry GomezH 1 Reply Last reply
                                    • T ted
                                      @Harry-Gomez
                                      Harry GomezH
                                      Harry GomezH
                                      Harry Gomez
                                      I tried that but it did not work - this is how part of the /etc/init.d/openhab looks - any other ideas - i did not needed this with the RPi2 and wheezy
                                      JAVA_ARGS_DEFAULT="-Dosgi.clean=true
                                      -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0
                                      -Declipse.ignoreApp=true
                                      -Dosgi.noShutdown=true
                                      -Djetty.port=${HTTP_PORT}
                                      -Dopenhab.configfile="${OPENHAB_CONF_DIR}/configurations/openhab.cfg"
                                      -Dopenhab.configdir="${OPENHAB_CONF_DIR}/configurations"
                                      -Dopenhab.logdir="${OPENHAB_LOG_DIR}"
                                      -Dsmarthome.userdata="${OPENHAB_USER_DATA_DIR}"
                                      -Djetty.home="${OPENHAB_DIR}"
                                      -Djetty.port.ssl=${HTTPS_PORT}
                                      -Djetty.config="${OPENHAB_CONF_DIR}/jetty"
                                      -Djetty.logs="${OPENHAB_LOG_DIR}"
                                      -Djetty.rundir="${OPENHAB_DIR}"
                                      -Dfelix.fileinstall.dir="${OPENHAB_DIR}/addons"
                                      -Dfelix.fileinstall.filter=.*\.jar
                                      -Djava.library.path="${OPENHAB_DIR}/lib"
                                      -Djava.security.auth.login.config="${OPENHAB_CONF_DIR}/login.conf"
                                      -Dorg.quartz.properties="${OPENHAB_CONF_DIR}/quartz.properties"
                                      -Dequinox.ds.block_timeout=240000
                                      -Dequinox.scr.waitTimeOnBlock=60000
                                      -Dfelix.fileinstall.active.level=4
                                      -Djava.awt.headless=true
                                      -jar ${LAUNCHER}
                                      -configuration ${OPENHAB_WORKSPACE_DIR}
                                      -data ${OPENHAB_WORKSPACE_DIR}
                                      -console ${TELNET_PORT}"
                                        -jar ${LAUNCHER}
                                        ted
                                        @Harry-Gomez
                                        What if you modify start.sh and start openhab from console? I'm not a linux expert; could it be that the usb driver was initiated after /etc/init.d is processed ?
                                        Harry GomezH zeblongZ 2 Replies Last reply
                                        • T ted
                                          @Harry-Gomez
                                          Harry GomezH
                                          Harry GomezH
                                          Harry Gomez
                                          @ted
                                          Thank worked with change to openhab.sh - I had to put -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0 at the begining to be able to work. I'm not sure why it would workthere and not on the /etc/init.d/openhab. Also there is not start.sh when you install using apt-get it is named opendhab.sh
                                          Thanks!!
