  3. Signing - Problem with size?
10 Posts 4 Posters 3.8k Views 3 Watching
  • markushM Offline
    markushM Offline
    markush
    trying to activate signing, first attempt in software. I have this configuration used:
    MyConfig.h:
    #define MY_SIGNING_FEATURE
    #define MY_HMAC_KEY 0x........
    and in my gateway sketch (based on the example EthernetGateway from the lib):
    MySigningAtsha204Soft signer;
    MySensor gw(transport, hw, signer);
    Should be enough or? But when i try to compuile i get the errors:
    Sketch too big.....
    Sketch uses 35,106 bytes (108%) of program storage space. Maximum is 32,256 bytes.
    Now? Any Ideas?
    Markus
    • mfalkviddM Offline
      Hi @markush, welcome to the MySensors forum!
      The code is too big to fit the flash memory in your Arduino. See this comment for what affects code size http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors/226
      If you post your sketch we could probably help you analyze it (remember to remove the hmac key first)
      • markushM Offline
        markushM Offline
        markush
         * Version 1.0 - Henrik EKblad
         * COMPILING WIZNET (W5100) ETHERNET MODULE
         * > Edit MyConfig.h in (libraries\MySensors\) to enable softspi (remove // before "#define SOFTSPI").
         * COMPILING ENC28J60 ETHERNET MODULE
         * > Use Arduino IDE 1.5.7 (or later)
         * > Disable DEBUG in Sensor.h before compiling this sketch. Othervise the sketch will probably not fit in program space when downloading.
         * > Remove Ethernet.h include below and include UIPEthernet.h
         * > Remove DigitalIO include
         * Note that I had to disable UDP and DHCP support in uipethernet-conf.h to reduce space. (which means you have to choose a static IP for that module)
         * VERA CONFIGURATION:
         * LED purposes:
        #define NO_PORTB_PINCHANGES
        #include <DigitalIO.h>     // This include can be removed when using UIPEthernet module
        #include <MySigningNone.h>
        #include <MyTransportRFM69.h>
        #include <MyTransportNRF24.h>
        #include <MyHwATMega328.h>
        #include <MyParserSerial.h>
        #include <stdarg.h>
        #include <PinChangeInt.h>
        #include "GatewayUtil.h"
        // Use this if you have attached a Ethernet ENC28J60 shields
        // #include <UIPEthernet.h>
        // Use this for WizNET W5100 module and Arduino Ethernet Shield
        #include <Ethernet.h>
        #define RADIO_CE_PIN        5  // radio chip enable
        #define RADIO_SPI_SS_PIN    6  // radio SPI serial select
        #define RADIO_ERROR_LED_PIN 7  // Error led pin
        #define RADIO_TX_LED_PIN    9  // the PCB, on board LED
        //MyTransportRFM69 transport;
        //MySigningNone signer;
        //MySigningAtsha204 signer;
        // Hardware profile
        MyHwATMega328 hw;
        #ifdef WITH_LEDS_BLINKING
        MySensor gw(transport, hw, signer, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
        #define IP_PORT 5003        // The port you want to open
        IPAddress myIp (192, 168, 10, 200);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
        byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };  // DEAD BEEF FEED
        // a R/W server on the port
        EthernetServer server = EthernetServer(IP_PORT);
        // handle to open connection
        EthernetClient client = EthernetClient();
        char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
        int inputPos = 0;
        bool sentReady = false;
        void output(const char *fmt, ... ) {
           va_list args;
           va_start (args, fmt );
           va_end (args);
           Serial.print(serialBuffer);
           server.write(serialBuffer);
          Ethernet.begin(mac, myIp);
          // Add interrupt for inclusion button to pin
          PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
          // give the Ethernet interface a second to initialize
          delay(1000);
          server.begin();
          checkInclusionFinished();
          // if an incoming client connects, there will be
          // bytes available to read via the client object
          EthernetClient newclient = server.available();
          // if a new client connects make sure to dispose any previous existing sockets
          if (newclient) {
              if (client != newclient) {
               client.stop();
               client = newclient;
               output(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
           if (client) {
             if (!client.connected()) {
               client.stop();
             } else if (client.available()) {
               // read the bytes incoming from the client
               char inChar = client.read();
               if (inputPos<MAX_RECEIVE_LENGTH-1) {
                 // if newline then command is complete
                 if (inChar == '\n') {
                   Serial.println("Finished");
                    // a command was issued by the client
                    // we will now try to send it to the actuator
                    inputString[inputPos] = 0;
                    // echo the string to the serial port
                    Serial.print(inputString);
                    parseAndSend(gw, inputString);
                    // clear the string:
                    inputPos = 0;
                   // add it to the inputString:
                   inputString[inputPos] = inChar;
                   inputPos++;
                 inputPos = 0;
          Try commenting out the rfm69 include and see if that helps.
          The code for the ENC28J60 requires quite a lot of space, so you might not be able to fit that and signing at the same time.
          The code in the MySensos dev branch is smaller, so you could try using the dev branch instead if removing rfm69 isn't enough.
            I think you can remove the include for MySigningAtsha204 as well, you only need the MySigningAtsha204Soft.
            • markushM Offline
              markushM Offline
              markush
              Thank you! I would try it tomorrow. At the moment i use MySensor lib 1.5.4 and Arduino IDE 1.6.7.
              Should i try MySensor Lib 2.0 beta?
              • S Offline
                Hi!
                2.0 are much smaller in size (20% i think i read somewhere) so this could also be something to try if your sketch is to big... dont know how signing has evolved in 2.0 though.
                • markushM Offline
                  markushM Offline
                  markush
                  @mfalkvidd
                  I have removed the includes as you recommended, did not help. Can't understand! :question:
                  I will try the dev branch.
                  Thanks! Will report the result.
                  • A Offline
                    A Offline
                    Anticimex
                    Signing on dev looks quite different from a personalization perspective. Please read on that here. That said, it is also much easier to manage, and the entire library takes much less space.
                    Soft signing on master with a ethernet gw will not fit as master looks currently and on a AtMega328.
                    • markushM markush
                      @mfalkvidd
                      The compiler only includes code that is actually used. Since you weren't using the parts you removed, the compiler probably already had excluded the code. How well the exclusion works depends on how the code was written. Seems like the MySensors code is written in a way that is nice to the compiler.
                      12.1k
