  3. Is it possible to turn 5v pro mini into unregulated for low power use?
regulatorlow powerpro mini
4 Posts 3 Posters 2.8k Views 3 Watching
  • D Offline
    drock1985
    I have a pro mini that I ordered by accident; a 5v version. Is it possible to remove the regulator (either temporarily or permanently) so that I could power it from 2x 1.5v NIMH batteries, for low power uses?
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • V Offline
      V Offline
      vil1driver
      hi,
      look at the store
      DC-DC Step Up Boost Module 5V
      • mfalkviddM Offline
        The mcu is clocked at 16MHz on the 5V version and is not rated for 3.3V at that speed (see the datasheet). You could change the chrystal or change the fuses to run on the internal oscillator.
        I'm not sure if there are any other obstacles.
        If you want a challenge, you've got one :-) I would just order an 3.3V Arduino and save the 5V for another project.
        D 1 Reply Last reply
          drock1985
          My Projects
          2 Door Chime Sensor
