  3. 6 Way wall touch switch
25 Posts 13 Posters 23.5k Views 16 Watching
  • D
    Dirk_H
    I also built a 6way wall switch. It does not have lights but is battery powered and very well documented. It is kind of rocket science because it has a 3d printed housing and a self etched pcb but maybe it helps anyway at least for the (very easy) source code:
    http://forum.mysensors.org/topic/1018/
    ferpandoF 1 Reply Last reply
    • V
      V
      Vince
      This looks very nice. Love the led to see what's still on
      • D Dirk_H
        ferpandoF
        ferpandoF
        ferpando
        @Dirk_H
        Yes I saw it before and served as inspiration.
        Now I'm making a more compact version with a custom PCB.
        I'm new to smc so let's see how it goes :-)
        • V Vince
          ferpandoF
          ferpandoF
          ferpando
          @Vince
          I left some light in the leds because when it's dark/night, you can still find the buttons.
          Now it has 2 leds per button, but the plan is to use an RGB led so it can be further customized.
          • DidiD
            DidiD
            Didi
            Is there a chance that you can share your full setup? I like your wall touch switch very much. :smile:
            • DidiD Didi
              ferpandoF
              ferpandoF
              ferpando
              @Didi
              YesI will when I have the second version ready.
              This is a bit messy :-)
              I'll keep you posted
              DidiD 2 Replies Last reply
              • DidiD
                DidiD
                Didi
                @ferpando
                Thank you
                • ferpandoF ferpando
                  @Didi
                  DidiD
                  DidiD
                  Didi
                  @ferpando said:
                  @Didi
                  Any news?
                  • G
                    G
                    gizzmo
                    Still no update? I would love to see the hardware setup
                      @Didi
                      DidiD
                      DidiD
                      Didi
                      What´s up did you clean your project?
                      • J
                        J
                        jemish
                        Hello sir, have any update?
                        we are waiting for your new updates.
                        Thank you
