  3. My Slim 2AA Battery Node
498 Posts 71 Posters 604.7k Views 69 Watching
  • Tom71T
    Tom71T
    Tom71
    Did anybody tested this board with an ATSHA204A on A2? The ATSHA204A works with 2.0 to 5.5 V.
    KeifruK 1 Reply Last reply
    • Tom71T Tom71
      KeifruK
      KeifruK
      Keifru
      @Tom71
      • siodS
        siodS
        siod
        ok guys, I finally set up my first sensor and it´s communicating well. I´ve attached two reed switch which work fine, only my temp snesor DHT11 doesn´t work. Are there any known issues with this sensor?
        // Define Node ID
        #define MY_NODE_ID 1
        //Kontaktschalter
        //Tempsensor
        #define CHILD_ID_HUM 3
        #define CHILD_ID_TEMP 4
        //Kontaktschalter
        Bounce debouncer1 = Bounce();
        Bounce debouncer2 = Bounce();
        int oldValueReed1=-1;
        int oldValueReed2=-1;
        //tempsensor
        DHT dht;
        float lastTemp;
        float lastHum;
        boolean metric = true;
        //Messages
        // Kontaktschalter
        //TempMessage
          //Tempsensor
        // Setup Kontaktschalter 1
          pinMode(BUTTON1_PIN,INPUT);
            // Activate internal pull-up
        // Setup Kontaktschalter 2
          pinMode(BUTTON2_PIN,INPUT);
          debouncer1.interval(5);
          debouncer2.interval(5);
          //Tempsensor
          //Kontakstschalter 1
          debouncer1.update();
          // Get the update value
             // Send in the new value
             oldValueReed1 = valueReed1;
          //Kontakstschalter 2
          debouncer2.update();
             oldValueReed2 = valueReed2;
         //Tempsensor
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            Serial.print("T: ");
          if (isnan(humidity)) {
              lastHum = humidity;
              Serial.print("H: ");
              Serial.println(humidity);
        still learning...
        rsachocR m26872M 2 Replies Last reply
        • siodS siod
          // Define Node ID
          //Kontaktschalter
          //Tempsensor
          //Kontaktschalter
          //tempsensor
          DHT dht;
          float lastTemp;
          float lastHum;
          //Messages
          // Kontaktschalter
          //TempMessage
            //Tempsensor
            //Tempsensor
           //Tempsensor
              if (!metric) {
                lastHum = humidity;
          rsachocR
          rsachocR
          rsachoc
          @siod my understanding was that the voltage which is provided by the slim node wouldn't be suitable for the DHT11 and DHT22, as they require a minimum of 3.3v. There is some discussion here on the DHT22, which I understand has the same voltage requirements as the DHT11.
          • siodS siod
            // Define Node ID
            //Kontaktschalter
            //Tempsensor
            //Kontaktschalter
            //tempsensor
            DHT dht;
            float lastTemp;
            float lastHum;
            //Messages
            // Kontaktschalter
            //TempMessage
              //Tempsensor
              //Tempsensor
             //Tempsensor
                if (!metric) {
                  lastHum = humidity;
            m26872M
            m26872M
            m26872
            • siodS
              siodS
              siod
              wrote on last edited by siod
              #288
              Oh man, one problem solved, next just comes up...
              edit2: I measured 0,02 Ampere consumption, isn´t that too much?
              still learning...
              m26872M 1 Reply Last reply
              • siodS siod
                m26872M
                m26872M
                m26872
                • siodS
                  siodS
                  siod
                  OK thx for the hint, I guess I will just add a third AA battery, that should solve my problem...
                  still learning...
                  • siodS siod
                    meddie
                    @siod
                    Greets Eddie
                    • siodS
                      siodS
                      siod
                      #292
                      I really don't want to spam this thread...
                      Edit : ah ok, the arduino is going to regulate down to 3.3v... Then I cant use 3AAs :(
                      still learning...
                      rsachocR 1 Reply Last reply
                      • siodS siod
                        rsachocR
                        rsachocR
                        rsachoc
                        @siod I was in much the same position as you, but the simple suggestion is to use the SI7021, as per this thread. Otherwise, the links in the other thread are for the 5v builds.
                        • siodS
                          siodS
                          siod
                          I wasn't aware that the nrf24l01 is so sensitive to voltage higher than 1.9v. I would like to have a sensor design to which I can add different sensors, just for the purpose I need it right now. So most sensors need 3.3v or 5v and I have to decide if I use 3v cells, which are more expensive or use step up / step down regulators which will drain my batteries. I just want to keep the flexibility to add any sort of sensor to my board... What would you suppose to do, also I think I am not the only one who faces those problems. Of course I am a beginner and still have a lot to learn but I also just want to finish this project as I am working on it for a very long time now...
                          still learning...
                            meddie
                            when you are gonna to use some power up/down converter, them will need more power, so your battery will be faster empty.
                            • siodS siod
                              m26872M
                              m26872M
                              m26872
                              wrote on last edited by m26872
                              #296
                              • GertSandersG
                                GertSandersG
                                GertSanders
                                • siodS
                                  siodS
                                  siod
                                  OK guys, thanks for the explanation. In this case I need to buy new temp sensors...
                                  I just think the next time I encounter problems is, when I try to setup a new sensor node with attached pir motion sensor... I will read the data sheet of it first and look out for power consumption :)
                                  still learning...
                                  • ahmedadelhosniA
                                    ahmedadelhosniA
                                    ahmedadelhosni
                                    Is there any motion sensor that work on 3.3 V ? I tried powering the below one with 3.3 but it was acting crazy and keeps reporting motions.
                                      m26872M
                                      m26872M
                                      m26872
                                      • m26872M m26872
                                        ahmedadelhosniA
                                        ahmedadelhosniA
                                        ahmedadelhosni
                                        @m26872 yeah I know you have a topic but actually was concerned with door and window sensors that time and forgot to check it again when I needed it :)
                                        • A
                                          arnoldg
                                          I can't program my slim node through ISP, is there a reason it isn't working.
                                          But it can't find the node.
                                          it doesn't recognise the avr.
                                          This is the error i get:
                                          this check.
                                          avrdude done. Thank you.
