  3. My Slim 2AA Battery Node
498 Posts 71 Posters 604.7k Views 69 Watching
  • siodS
    siodS
    siod
    ok guys, I finally set up my first sensor and it´s communicating well. I´ve attached two reed switch which work fine, only my temp snesor DHT11 doesn´t work. Are there any known issues with this sensor?
    // Define Node ID
    #define MY_NODE_ID 1
    //Kontaktschalter
    //Tempsensor
    #define CHILD_ID_HUM 3
    #define CHILD_ID_TEMP 4
    //Kontaktschalter
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce();
    int oldValueReed1=-1;
    int oldValueReed2=-1;
    //tempsensor
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    //Messages
    // Kontaktschalter
    //TempMessage
      //Tempsensor
    // Setup Kontaktschalter 1
      pinMode(BUTTON1_PIN,INPUT);
        // Activate internal pull-up
    // Setup Kontaktschalter 2
      pinMode(BUTTON2_PIN,INPUT);
      debouncer1.interval(5);
      debouncer2.interval(5);
      //Tempsensor
      //Kontakstschalter 1
      debouncer1.update();
      // Get the update value
         // Send in the new value
         oldValueReed1 = valueReed1;
      //Kontakstschalter 2
      debouncer2.update();
         oldValueReed2 = valueReed2;
     //Tempsensor
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    still learning...
    rsachocR m26872M 2 Replies Last reply
    • siodS siod
      // Define Node ID
      //Kontaktschalter
      //Tempsensor
      //Kontaktschalter
      //tempsensor
      DHT dht;
      float lastTemp;
      float lastHum;
      //Messages
      // Kontaktschalter
      //TempMessage
        //Tempsensor
        //Tempsensor
       //Tempsensor
          if (!metric) {
            lastHum = humidity;
      rsachocR
      rsachocR
      rsachoc
      @siod my understanding was that the voltage which is provided by the slim node wouldn't be suitable for the DHT11 and DHT22, as they require a minimum of 3.3v. There is some discussion here on the DHT22, which I understand has the same voltage requirements as the DHT11.
      • siodS siod
        // Define Node ID
        //Kontaktschalter
        //Tempsensor
        //Kontaktschalter
        //tempsensor
        DHT dht;
        float lastTemp;
        float lastHum;
        //Messages
        // Kontaktschalter
        //TempMessage
          //Tempsensor
          //Tempsensor
         //Tempsensor
            if (!metric) {
              lastHum = humidity;
        m26872M
        m26872M
        m26872
        • siodS
          siodS
          siod
          wrote on last edited by siod
          #288
          Oh man, one problem solved, next just comes up...
          edit2: I measured 0,02 Ampere consumption, isn´t that too much?
          still learning...
          m26872M 1 Reply Last reply
          • siodS siod
            m26872M
            m26872M
            m26872
            • siodS
              siodS
              siod
              OK thx for the hint, I guess I will just add a third AA battery, that should solve my problem...
              still learning...
              • siodS siod
                meddie
                @siod
                Greets Eddie
                • siodS
                  siodS
                  siod
                  #292
                  I really don't want to spam this thread...
                  Edit : ah ok, the arduino is going to regulate down to 3.3v... Then I cant use 3AAs :(
                  still learning...
                  rsachocR 1 Reply Last reply
                  • siodS siod
                    rsachocR
                    rsachocR
                    rsachoc
                    @siod I was in much the same position as you, but the simple suggestion is to use the SI7021, as per this thread. Otherwise, the links in the other thread are for the 5v builds.
                    • siodS
                      siodS
                      siod
                      I wasn't aware that the nrf24l01 is so sensitive to voltage higher than 1.9v. I would like to have a sensor design to which I can add different sensors, just for the purpose I need it right now. So most sensors need 3.3v or 5v and I have to decide if I use 3v cells, which are more expensive or use step up / step down regulators which will drain my batteries. I just want to keep the flexibility to add any sort of sensor to my board... What would you suppose to do, also I think I am not the only one who faces those problems. Of course I am a beginner and still have a lot to learn but I also just want to finish this project as I am working on it for a very long time now...
                      still learning...
                        meddie
                        when you are gonna to use some power up/down converter, them will need more power, so your battery will be faster empty.
                        • siodS siod
                          m26872M
                          m26872M
                          m26872
                          wrote on last edited by m26872
                          #296
                          • GertSandersG
                            GertSandersG
                            GertSanders
                            • siodS
                              siodS
                              siod
                              OK guys, thanks for the explanation. In this case I need to buy new temp sensors...
                              I just think the next time I encounter problems is, when I try to setup a new sensor node with attached pir motion sensor... I will read the data sheet of it first and look out for power consumption :)
                              still learning...
                              • ahmedadelhosniA
                                ahmedadelhosniA
                                ahmedadelhosni
                                Is there any motion sensor that work on 3.3 V ? I tried powering the below one with 3.3 but it was acting crazy and keeps reporting motions.
                                  m26872M
                                  m26872M
                                  m26872
                                  • m26872M m26872
                                    ahmedadelhosniA
                                    ahmedadelhosniA
                                    ahmedadelhosni
                                    @m26872 yeah I know you have a topic but actually was concerned with door and window sensors that time and forgot to check it again when I needed it :)
                                    • A
                                      arnoldg
                                      I can't program my slim node through ISP, is there a reason it isn't working.
                                      But it can't find the node.
                                      it doesn't recognise the avr.
                                      This is the error i get:
                                      this check.
                                      avrdude done. Thank you.
                                      • A arnoldg
                                        this check.
                                        arnoldg
                                        When i use a ziff programming board, the avr is programmeble. so usbasp is working.
                                        • W
                                          W
                                          wergeld
                                          Finally got my v2 (red) boards in. Ended up with 30 of them. Will start wiring them up this week!
