  3. My Slim 2AA Battery Node
498 Posts 71 Posters 604.7k Views 69 Watching
  • m26872M m26872
    W
    W
    wergeld
    @m26872 Sounds good! Current status is "at board house." Getting twitchy waiting.
    D 1 Reply Last reply
    • W wergeld
      drock1985
      @wergeld
      My Projects
      2 Door Chime Sensor
      Washing Machine Monitor
      W 1 Reply Last reply
      • J
        J
        jacikaas
        Hello, I ordered it too yesterday :) Can't wait to step forward from my breadboards with a lot wires to PCB without wires :D
        • D drock1985
          @wergeld
          W
          W
          wergeld
          @drock1985 Right. I waited until a week after Chinese new year to order. Let the hangovers end and the trainstations empty . I am looking forward to finalizing my sensor network with cases as well. I have several old plastic/wood boxes lying around waiting for a less rats-nest setup.
          • siodS
            siodS
            siod
            wrote on last edited by siod
            #279
            now I finally set up my first sensor board, and, as expected, I don´t receive any data from it on my gateway :suspect:
            The sketch should run, but it doesn´t. Any ideas how to troubleshoot now?
            still learning...
            m26872M 1 Reply Last reply
            • siodS siod
              m26872M
              m26872M
              m26872
              @siod
              • Uno fuses and bootloader?
              • siodS
                siodS
                siod
                #281
                I just installed the NRF module at it´s desired place as well as the two capacitors and the resistors as described above. The crystal is only used for uploading the sketch to the Atmega328 chip, described here: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
                edit: I´ve re-read your first post and also this thread http://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5/2 ...
                Do I have to burn the bootloader using 1MHz or 8 MHz? I don´t get why this makes a difference, only that the batteries would drain faster the higher the MHz rate is.
                still learning...
                • siodS siod
                  m26872M
                  m26872M
                  m26872
                  wrote on last edited by m26872
                  #282
                  • Tom71T
                    Tom71T
                    Tom71
                    Did anybody tested this board with an ATSHA204A on A2? The ATSHA204A works with 2.0 to 5.5 V.
                    KeifruK 1 Reply Last reply
                    • Tom71T Tom71
                      KeifruK
                      KeifruK
                      Keifru
                      @Tom71
                      • siodS
                        siodS
                        siod
                        ok guys, I finally set up my first sensor and it´s communicating well. I´ve attached two reed switch which work fine, only my temp snesor DHT11 doesn´t work. Are there any known issues with this sensor?
                        // Define Node ID
                        #define MY_NODE_ID 1
                        //Kontaktschalter
                        //Tempsensor
                        #define CHILD_ID_HUM 3
                        #define CHILD_ID_TEMP 4
                        //Kontaktschalter
                        Bounce debouncer1 = Bounce();
                        Bounce debouncer2 = Bounce();
                        int oldValueReed1=-1;
                        int oldValueReed2=-1;
                        //tempsensor
                        DHT dht;
                        float lastTemp;
                        float lastHum;
                        boolean metric = true;
                        //Messages
                        // Kontaktschalter
                        //TempMessage
                          //Tempsensor
                        // Setup Kontaktschalter 1
                          pinMode(BUTTON1_PIN,INPUT);
                            // Activate internal pull-up
                        // Setup Kontaktschalter 2
                          pinMode(BUTTON2_PIN,INPUT);
                          debouncer1.interval(5);
                          debouncer2.interval(5);
                          //Tempsensor
                          //Kontakstschalter 1
                          debouncer1.update();
                          // Get the update value
                             // Send in the new value
                             oldValueReed1 = valueReed1;
                          //Kontakstschalter 2
                          debouncer2.update();
                             oldValueReed2 = valueReed2;
                         //Tempsensor
                          if (isnan(temperature)) {
                            lastTemp = temperature;
                            if (!metric) {
                            Serial.print("T: ");
                          if (isnan(humidity)) {
                              lastHum = humidity;
                              Serial.print("H: ");
                              Serial.println(humidity);
                        still learning...
                        rsachocR m26872M 2 Replies Last reply
                        • siodS siod
                          // Define Node ID
                          //Kontaktschalter
                          //Tempsensor
                          //Kontaktschalter
                          //tempsensor
                          DHT dht;
                          float lastTemp;
                          float lastHum;
                          //Messages
                          // Kontaktschalter
                          //TempMessage
                            //Tempsensor
                            //Tempsensor
                           //Tempsensor
                              if (!metric) {
                                lastHum = humidity;
                          rsachocR
                          rsachocR
                          rsachoc
                          @siod my understanding was that the voltage which is provided by the slim node wouldn't be suitable for the DHT11 and DHT22, as they require a minimum of 3.3v. There is some discussion here on the DHT22, which I understand has the same voltage requirements as the DHT11.
                          • siodS siod
                            // Define Node ID
                            //Kontaktschalter
                            //Tempsensor
                            //Kontaktschalter
                            //tempsensor
                            DHT dht;
                            float lastTemp;
                            float lastHum;
                            //Messages
                            // Kontaktschalter
                            //TempMessage
                              //Tempsensor
                              //Tempsensor
                             //Tempsensor
                                if (!metric) {
                                  lastHum = humidity;
                            m26872M
                            m26872M
                            m26872
                            • siodS
                              siodS
                              siod
                              #288
                              Oh man, one problem solved, next just comes up...
                              edit2: I measured 0,02 Ampere consumption, isn´t that too much?
                              still learning...
                              • siodS siod
                                m26872M
                                m26872M
                                m26872
                                • siodS
                                  siodS
                                  siod
                                  OK thx for the hint, I guess I will just add a third AA battery, that should solve my problem...
                                  still learning...
                                  • siodS siod
                                    meddie
                                    @siod
                                    Greets Eddie
                                    • siodS
                                      siodS
                                      siod
                                      #292
                                      I really don't want to spam this thread...
                                      Edit : ah ok, the arduino is going to regulate down to 3.3v... Then I cant use 3AAs :(
                                      still learning...
                                      rsachocR 1 Reply Last reply
                                      • siodS siod
                                        rsachocR
                                        rsachocR
                                        rsachoc
                                        @siod I was in much the same position as you, but the simple suggestion is to use the SI7021, as per this thread. Otherwise, the links in the other thread are for the 5v builds.
                                        • siodS
                                          siodS
                                          siod
                                          I wasn't aware that the nrf24l01 is so sensitive to voltage higher than 1.9v. I would like to have a sensor design to which I can add different sensors, just for the purpose I need it right now. So most sensors need 3.3v or 5v and I have to decide if I use 3v cells, which are more expensive or use step up / step down regulators which will drain my batteries. I just want to keep the flexibility to add any sort of sensor to my board... What would you suppose to do, also I think I am not the only one who faces those problems. Of course I am a beginner and still have a lot to learn but I also just want to finish this project as I am working on it for a very long time now...
                                          still learning...
