  3. MyController.org
  4. Browser downloads file instead of connecting to Login page?
Scheduled Pinned Locked Moved MyController.org
6 Posts 3 Posters 2.3k Views 3 Watching
  • crusher70C
    crusher70C
    crusher70
    Hi everyone,
    Firstly when working on my local LAN it works perfectly. However I have a small issue where by when connection from the web via dynamic IP > Router > Port forwarding. I enter the correct address and a connection is made however the browser downloads a file called download.
    I cannot seem to find any information on this error, although I'm probably looking in all the wrong places.
    Any help would be greatly appreciated.
    J A 2 Replies Last reply
    • crusher70C crusher70
      Hi everyone,
      J
      J
      jkandasa
      wrote on last edited by jkandasa
      @crusher70
      I hope you have enabled https (default settings) and using http. You should use https in your browser url. example https://dynamic-ip:8443/
        Hi everyone,
        anarro
        @crusher70
        Hi, If you want.. You can try disable https first, then try with https...
        • crusher70C
          crusher70C
          crusher70
          HI there,
          Good idea i'll give that a go while sorting out SSL Cert.
          • crusher70C
            crusher70C
            crusher70
            Yep worked first time without ssl. Just need to work out how to set-up the free ssl certificate i got from StartSSL.
            Thanks for your continued support its really appreciated.
            • crusher70C
              crusher70C
              crusher70
              In case anyone else is reading this post im going to try running through this post.
              I'll update with progress later.
              Self-Signed_Certificate Guide
