  3. MyController.org
  4. Browser downloads file instead of connecting to Login page?
Scheduled Pinned Locked Moved MyController.org
6 Posts 3 Posters 2.2k Views 3 Watching
  • crusher70C Offline
    crusher70C Offline
    crusher70
    Hi everyone,
    Firstly when working on my local LAN it works perfectly. However I have a small issue where by when connection from the web via dynamic IP > Router > Port forwarding. I enter the correct address and a connection is made however the browser downloads a file called download.
    I cannot seem to find any information on this error, although I'm probably looking in all the wrong places.
    Any help would be greatly appreciated.
    J A 2 Replies Last reply
    • crusher70C crusher70
      Hi everyone,
      J Offline
      J Offline
      jkandasa
      wrote on last edited by jkandasa
      @crusher70
      I hope you have enabled https (default settings) and using http. You should use https in your browser url. example https://dynamic-ip:8443/
        Hi everyone,
        A Offline
        A Offline
        anarro
        @crusher70
        Hi, If you want.. You can try disable https first, then try with https...
          crusher70C Offline
          crusher70
          HI there,
          Good idea i'll give that a go while sorting out SSL Cert.
            crusher70C Offline
            crusher70
            Yep worked first time without ssl. Just need to work out how to set-up the free ssl certificate i got from StartSSL.
            Thanks for your continued support its really appreciated.
              crusher70C Offline
              crusher70
              In case anyone else is reading this post im going to try running through this post.
              I'll update with progress later.
              Self-Signed_Certificate Guide
