  3. What is the minimum distance between main voltages (PCB)
5 Posts 3 Posters 1.9k Views 2 Watching
  • ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    I am trying to design my own power supply and I am a bit worry about the minimum distance between hot and neutral lines ? I read in this link that according to EN61010, it shall be 3mm.
    Lots of people here do design there boards and I guess they have faced this issue before.
    • sundberg84S
      sundberg84S
      Hi!
      It depends... http://creepage.com/
      Example:
      Insulation: Basic
      Pollution Degree: 2
      Material Group: IIIa or IIIb
      Working Voltage: 250 Vrms or Vdc
      Creepage is 2.5 mm or 98.4 mils
      I try 3mm on my boards.
        GertSandersG
        GertSandersG
        GertSanders
        @ahmedadelhosni
        In my DRU I use 100 mil clearance for AC lines (and 100 mil width).
        • sundberg84S sundberg84
          Hi!
          Example:
          Insulation: Basic
          Pollution Degree: 2
          ahmedadelhosniA
          ahmedadelhosniA
          ahmedadelhosni
          @sundberg84 creepege differs from clearance. I guess if I add creepege then clearance can be decreased.
          I just cant find online which values are the minimum. Most of the search results requests to buy the certificates.
          • sundberg84S
            sundberg84S
            @ahmedadelhosni Yes - sorry, didnt read carefull enough.
