  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 121.6k Views 58 Watching
    wow impressively cool :laughing:
    thx for your kindness, now I have homeworks to do!
    see you soon :)
    • ahmedadelhosniA
      ahmedadelhosniA
      ahmedadelhosni
      Sorry but I dont really get what you mean by freezy ?
      You mean a code is compiled but it enters an infinite loop for example ?
        yes that's it. a bug in your code, like infinite loop, ram troubles... that should be rare depending of your code. plus generally you/I test on breadboard before sending it in prod, but that can happen and is good to know ;)
        • scalzS scalz
          ahmedadelhosniA
          ahmedadelhosniA
          ahmedadelhosni
          @scalz great.
          This means that MYSBootloader can handle this problem and enter the bootloader mode even if the MCU freezes.
          @tekka you state that the current version can handle a freeze SW. Also if the new code is corrupted during programming by unverified CRC or whatever, it will also handle that problem and resets and wait for a new flashing order.
          Is this new in this version ? I am some how sure that MYSBootloader previously had a problem handling thoses types of failures, and that's why I was going to use DualOptiboot as I read before that it can handle those failures
          Sorry for lots of questions but I am trying to reorganise my info.
          • M mannkind
            [[topic:post-is-deleted]]
            rollercontainerR
            rollercontainerR
            rollercontainer
            @mannkind @tekka
            So its working with a GatewayW5100MQTTClient aswell? That would be fantastic, I thought its only for serial and ethernet gateways. Do I also have to use port 5003?
            • F
              F
              Fabien
              @tekka If this can help for an RFM69 version :
              https://github.com/vvvlc/Funky-FOTA
              • C
                C
                cdr
                @rollercontainer confirmed working with W5100mqtt here!
                • rollercontainerR
                  rollercontainerR
                  rollercontainer
                  I have to ask again: GatewayW5100MQTTClient or the old Broker Gateway?
                  I am not able to connect to my GatewayW5100MQTTClient on port 1883 or 5003 with MYSController 1.0.0beta.
                  The gateway is in working condition with openHAB.
                  • rollercontainerR rollercontainer
                    @mannkind @tekka
                    mannkind
                    rollercontainerR 1 Reply Last reply
                    • M mannkind
                      rollercontainerR
                      rollercontainerR
                      rollercontainer
                      @mannkind
                      THX! What difference a single letter makes... ^^
                      @cdr What do you use exactly?
                      • n1ck1355N
                        n1ck1355N
                        n1ck1355
                        wrote on last edited by n1ck1355
                        #27
                        Hello @ all :)
                        first thx to tekka for the great job :)
                        as the release notes say with the mysbootloader 1.3pre one can use the serial upload.
                        is its usable via the arduino ide? Because i can upload a sketch but it seems not to start.
                        also as rollercontainer asked is the myscontroller application usable via the old broker or with the new clientmqtt gateway?
                        Would be nice if there are some instructions how to use ;)
                        tekkaT 1 Reply Last reply
                        • n1ck1355N n1ck1355
                          Hello @ all :)
                          tekkaT
                          tekkaT
                          tekka
                          @n1ck1355 @rollercontainer MYSController does not support MQTT (at the moment), but have a look at MyController.org. Please provide more details regarding your issue with MYSBootloader 1.3pre.
                          • n1ck1355N
                            n1ck1355N
                            n1ck1355
                            thx tekka for clearing this :)
                            for my bootloader problem:
                            i burned the 1.3mysbootloader with the 8mhz config successfully from the arduino dev ide.
                            then i uploaded a little test sketch like this without errors:
                              Serial.begin(57600);
                              Serial.println("Setup Start");
                            but there is no output on the serial monitor. it lookes like the bootloader didn't start the sketch.
                            • F
                              F
                              Fabien
                              I try to add new hex file in MYSController 1.0 but after clicking "reload repo", it tells me 2107-15-31 is not a valid date specification. I don't have the ability to select firmware after this. And after a reboot the "reload repo" is garyed.
                              Arduino ide 1.6.7
                              csv :
                              10,Blink,1,Blink.ino.hex,blinking example
                              20,TimeReporter,1,TimeReporter.ino.hex,TimeReporter demo
                              30,SenseBender,1,SensebenderMicro.ino.hex,Sensebender micro
                              Another 'bug". It always ask me to download a "new" version ... I install it but ask me again (1.0 beta)
                              I think this issue is related to the last arduino IDE version.
                              tekkaT rubyanR 2 Replies Last reply
                              • F Fabien
                                Arduino ide 1.6.7
                                csv :
                                tekkaT
                                tekkaT
                                tekka
                                @Fabien Are you running MYSController on WINE? I updated a few things, please update to the most recent version of MYSController (build 3312, here or via update button) and post the log. Thanks.
                                F 1 Reply Last reply
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @n1ck1355 Please enable logging in MYSController, reboot the node and post the log here after a few mins of recording.
                                  • TakeroT
                                    TakeroT
                                    Takero
                                    Hi, i like OTA Update :-)
                                    How it is possible to change the Cannel from 76 to 105?
                                    • TakeroT Takero
                                      rollercontainerR
                                      rollercontainerR
                                      rollercontainer
                                      @Takero https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MyConfig.h#L387
                                      TakeroT 1 Reply Last reply
                                        TakeroT
                                        TakeroT
                                        Takero
                                        Yes, i know what, but this is not there I am looking for.
                                        The Autor wrote:
                                        Attached bootloader file, compiled with these settings:
                                        nRF24 (Channel 76, base address 0xA8A8E1FC00, data rate 250kbs)
                                        115200 baud (16Mhz) or 57600 (8Mhz)
                                        I want a Bootloader file with Channel 105.
                                        • TakeroT Takero
                                          rollercontainerR
                                          rollercontainerR
                                          rollercontainer
                                          sorry, you are right. Since the source isnt yet available, you cant compile your custom bootloader. So, thats a no.
