  3. Best value sensors for Carbon Monoxide and Smoke
carbon monoxidesmokeair quality
27 Posts 6 Posters 15.4k Views 8 Watching
  • micahM micah
    @korttoma thanks, but ouch, $37 CAD seems expensive, since I already have real smoke detectors in the house, and since I'm planning 3 of these devices that would be over $110
    I was really hoping the answer would have been something like this MQ-9 :worried:
    alexsh1A
    alexsh1A
    alexsh1
    @micah
    There is no right or wrong answer to your question. The problem is that if you go for a cheap MQ* sensor, you will have to dive into calibration etc. I have MQ-135 and I am still struggling to calibrate it properly. With MH-Z14 it is much easier, but yeah you pay the price. Ultimately, this is up to you to decide.
    At this price level ($110) you can probably buy 2-3 z-wave smoke detectors and automate it with Vera or Domoticz.
    • korttomaK
      korttomaK
      korttoma
      I agree with @alexsh1 here. I have placed a MQ-2 in the ventilation pipe to detect smoke for incoming fresh air because sometimes smoke comes in from outside through ventilation and then I want to turn of the ventilation. I have not had any luck with this because the value I receive from the MQ-2 is not reliable and it seems to depend on temperature and humidity also.
      I have plans to replace it with an MH-Z14 but I have not done this yet. I don't know if this will solve my problem but I am hoping that it is a "You get what you pay for" kind of situation.
      • Tomas
        Samuel235
        Good morning guys, I'm currently designing my full room module, I too have had to spend many hours sifting through the various sensors, below I have included my choices. I chose to go down the two sensors for smoke route, one for fast burning fires and the other for the low flame smoldering type such as furniture fires. I don't think i will be using both in each module but the footprints will be on board and that way i can have different configurations on my modules depending on which room they will be located in throughout the house to stop false alarms being created due to incorrect sensor usage.
        Carbon Monoxide: ME2-CO @ $14.64 each
        Photoelectric (optical) Smoke Sensor: Custom made Infrared Emitter and Receiver setup using 1 IR LED 940nm pulsing at 38Mhz with 555 timer and a IR receiver
        Ionisation Smoke Sensor: MQ-2 @ £0.99 each. I will be removing them from the PCB they come on and locating them on my module board itself.
        If you are interested in anything else then please don't hesitate to question me. If the question is specific for my module then drop the comment onto that topic rather than clogging this topic up ;)
        Good luck and have fun sensing that dirty smoke!
        MySensors 2.1.1
        • alexsh1A
          alexsh1A
          alexsh1
          @Samuel235 Very interesting. Did you consider these sensors:
          (very tiny and low voltage)
          http://www.figarosensor.com/feature/tgs8100.html
          or
          http://www.figarosensor.com/feature/tgs5042_tgs5342.html
          S 1 Reply Last reply
          • alexsh1A alexsh1
            or
            Samuel235
            @alexsh1, as my very in depth updates on my module topic speaks about, i did indeed. And i absolutely loved them. But i just couldn't 'easily' get a hold of them in the UK.
            MySensors 2.1.1
            • alexsh1A
              alexsh1A
              alexsh1
              @Samuel235 I am based in the UK too and I found this -> http://www.soselectronic.com/?str=371&artnum=170939&name=figaro-tgs8100
                Samuel235
                And on that note, i have found the Carbon Monoxide Figaro Sensor for $22 so $8 more than the ME2-CO that i've ordered.
                Then you have just found the one that i've always struggled to get my hands on, the air quality sensor. Now i'm very tempted to order one of each to trial o.O These were my intended sensors to go for but because of the fact i couldn't get my hands on them and the price of the air quality one compared to that of MQ2 is high along with the price difference on the CO sensor too.
                To go with these two over the two i have on order it would cost around £16.40 more.
                MQ2 & ME2-CO: £11.50
                Figaro Sensors: £27.90
                Time to reconsider!
                MySensors 2.1.1
                  Samuel235
                  I have just ordered one of each of these sensors. I will report on my module topic with the experience when they arrive.
                  MySensors 2.1.1
                  alexsh1A 1 Reply Last reply
                  • S Samuel235
                    alexsh1A
                    alexsh1A
                    alexsh1
                    Yeah, I see you place the order :)
                    Transaction History
                    0 transactions in last 6 months.Sort by latest
                    Buyer Transaction Information
                    S***m M.
                    UK
                    1 piece
                    09 Apr 2016 00:07
                    Have you looked at the software side? Which library to use with Figaro?
                    I have itchy hands to get one ordered as my experience with MQ* sensors was not positive.
                    S 2 Replies Last reply
                    • alexsh1A alexsh1
                      Transaction History
                      S***m M.
                      UK
                      1 piece
                      09 Apr 2016 00:07
                      Samuel235
                      @alexsh1 Well, i ordered the one off of Aliexpress, but i can't get the air quality sensor that you linked. There is a 50EU spending minimum and a 8eu postage charge too. I'm not spending 50EU just for that one sensor >.<
                      I had a brief look at the software side before when i was contemplating purchasing these at the start of my designing. I can't remember much of it though.
                      MySensors 2.1.1
                      • alexsh1A alexsh1
                        Transaction History
                        S***m M.
                        UK
                        1 piece
                        09 Apr 2016 00:07
                        Samuel235
                        @alexsh1 - I have just dropped Figaro an email direct. So lets hope we get some leads to a company/source over here. I will keep you posted if i hear anything in return :)
                        MySensors 2.1.1
                        • S Samuel235
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @Samuel235 Good lad! I was gonna drop them a note, but you were quicker than me
                          • alexsh1A alexsh1
                            Samuel235
                            @alexsh1, to be honest, it might be worth you contacting them as well. I have dropped a little bit of information regarding us building modules as a community under the name of MySensors.org (I hope @hek doesn't mind), therefor by you contacting them and mentioning MySensors.org too it might show that they have some interest (which i have said to them) but the more interest that is shown, the more likely they will supply us ;)
                            MySensors 2.1.1
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              @Samuel235 Fair enough - I'll drop them a quick line.
                              BTW Have you considered MH-Z14?
                              • alexsh1A alexsh1
                                Samuel235
                                Correct me if i'm wrong here but this is for Carbon Dioxide, right? Are you thinking this for the smoke sensor/air quality sensor?
                                MySensors 2.1.1
                                • S Samuel235
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  That's right. CO2 and temperature are the air quality parameters. This is how most companies (Withings for example) measure air quality. Obviously, it is more complicated if you want to get precise as air quality is affected by other gases, volatile organic compounds, particulates etc.
                                  • alexsh1A alexsh1
                                    Samuel235
                                    @alexsh1, If i'm honest I'm only interested in knowing if there is smoke present in the air so this might work. However, they seem to come pre-mounted to a board and they are no cheaper than anything else i have been looking at. Still seems hard to get a hold of too.
                                    MySensors 2.1.1
                                    • S Samuel235
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      This sensor is expensive, but it is the most precise. Yes, there are disadvantages like the power (working current: 50mA mean value of the peak value of 100mA) and it is pre-mounted as you said, but this is all about precision here. They are available for $27+ on Aliexpress.
                                      • alexsh1A
                                        alexsh1A
                                        alexsh1
                                        http://www.aliexpress.com/item/FREE-SHIPPING-MH-Z14-Infrared-carbon-dioxide-sensor-module-Analog-output-environment-monitoring/32599614226.html?spm=2114.30010308.3.12.2bmxjq&ws_ab_test=searchweb201556_2,searchweb201602_5_10034_10033_507_10032_508_10020_10017_10005_10006_10021_10022_401_10018_10019,searchweb201603_2&btsid=d825bfa5-f2ac-46c3-8d40-7a3f66083d1f
                                        • alexsh1A alexsh1
                                          Samuel235
                                          @alexsh1, i must admit i like their properties but i'm not sure if thats too extreme. Maybe thats bumping the price for precision thats not needed that close. If i wanted to know the ppm exactly of the air i would get them right now. But i just care if the ppm touches a certain point roughly to then set the alarm status for the home automation controller.
                                          MySensors 2.1.1
