  3. Best value sensors for Carbon Monoxide and Smoke
carbon monoxidesmokeair quality
27 Posts 6 Posters 15.4k Views 8 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    @Samuel235 Very interesting. Did you consider these sensors:
    (very tiny and low voltage)
    http://www.figarosensor.com/feature/tgs8100.html
    or
    http://www.figarosensor.com/feature/tgs5042_tgs5342.html
    S 1 Reply Last reply
    • alexsh1A alexsh1
      or
      Samuel235
      @alexsh1, as my very in depth updates on my module topic speaks about, i did indeed. And i absolutely loved them. But i just couldn't 'easily' get a hold of them in the UK.
      MySensors 2.1.1
      • alexsh1A
        alexsh1A
        alexsh1
        @Samuel235 I am based in the UK too and I found this -> http://www.soselectronic.com/?str=371&artnum=170939&name=figaro-tgs8100
          Samuel235
          And on that note, i have found the Carbon Monoxide Figaro Sensor for $22 so $8 more than the ME2-CO that i've ordered.
          Then you have just found the one that i've always struggled to get my hands on, the air quality sensor. Now i'm very tempted to order one of each to trial o.O These were my intended sensors to go for but because of the fact i couldn't get my hands on them and the price of the air quality one compared to that of MQ2 is high along with the price difference on the CO sensor too.
          To go with these two over the two i have on order it would cost around £16.40 more.
          MQ2 & ME2-CO: £11.50
          Figaro Sensors: £27.90
          Time to reconsider!
          MySensors 2.1.1
            Samuel235
            I have just ordered one of each of these sensors. I will report on my module topic with the experience when they arrive.
            MySensors 2.1.1
            alexsh1A 1 Reply Last reply
            • S Samuel235
              alexsh1A
              alexsh1A
              alexsh1
              Yeah, I see you place the order :)
              Transaction History
              0 transactions in last 6 months.Sort by latest
              Buyer Transaction Information
              S***m M.
              UK
              1 piece
              09 Apr 2016 00:07
              Have you looked at the software side? Which library to use with Figaro?
              I have itchy hands to get one ordered as my experience with MQ* sensors was not positive.
              S 2 Replies Last reply
              • alexsh1A alexsh1
                Transaction History
                S***m M.
                UK
                1 piece
                09 Apr 2016 00:07
                Samuel235
                @alexsh1 Well, i ordered the one off of Aliexpress, but i can't get the air quality sensor that you linked. There is a 50EU spending minimum and a 8eu postage charge too. I'm not spending 50EU just for that one sensor >.<
                I had a brief look at the software side before when i was contemplating purchasing these at the start of my designing. I can't remember much of it though.
                MySensors 2.1.1
                • alexsh1A alexsh1
                  Transaction History
                  S***m M.
                  UK
                  1 piece
                  09 Apr 2016 00:07
                  Samuel235
                  @alexsh1 - I have just dropped Figaro an email direct. So lets hope we get some leads to a company/source over here. I will keep you posted if i hear anything in return :)
                  MySensors 2.1.1
                  • S Samuel235
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @Samuel235 Good lad! I was gonna drop them a note, but you were quicker than me
                    • alexsh1A alexsh1
                      Samuel235
                      @alexsh1, to be honest, it might be worth you contacting them as well. I have dropped a little bit of information regarding us building modules as a community under the name of MySensors.org (I hope @hek doesn't mind), therefor by you contacting them and mentioning MySensors.org too it might show that they have some interest (which i have said to them) but the more interest that is shown, the more likely they will supply us ;)
                      MySensors 2.1.1
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        @Samuel235 Fair enough - I'll drop them a quick line.
                        BTW Have you considered MH-Z14?
                        • alexsh1A alexsh1
                          Samuel235
                          Correct me if i'm wrong here but this is for Carbon Dioxide, right? Are you thinking this for the smoke sensor/air quality sensor?
                          MySensors 2.1.1
                          • S Samuel235
                            alexsh1A
                            alexsh1A
                            alexsh1
                            That's right. CO2 and temperature are the air quality parameters. This is how most companies (Withings for example) measure air quality. Obviously, it is more complicated if you want to get precise as air quality is affected by other gases, volatile organic compounds, particulates etc.
                            • alexsh1A alexsh1
                              Samuel235
                              @alexsh1, If i'm honest I'm only interested in knowing if there is smoke present in the air so this might work. However, they seem to come pre-mounted to a board and they are no cheaper than anything else i have been looking at. Still seems hard to get a hold of too.
                              MySensors 2.1.1
                              • S Samuel235
                                alexsh1A
                                alexsh1A
                                alexsh1
                                This sensor is expensive, but it is the most precise. Yes, there are disadvantages like the power (working current: 50mA mean value of the peak value of 100mA) and it is pre-mounted as you said, but this is all about precision here. They are available for $27+ on Aliexpress.
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  http://www.aliexpress.com/item/FREE-SHIPPING-MH-Z14-Infrared-carbon-dioxide-sensor-module-Analog-output-environment-monitoring/32599614226.html?spm=2114.30010308.3.12.2bmxjq&ws_ab_test=searchweb201556_2,searchweb201602_5_10034_10033_507_10032_508_10020_10017_10005_10006_10021_10022_401_10018_10019,searchweb201603_2&btsid=d825bfa5-f2ac-46c3-8d40-7a3f66083d1f
                                  • alexsh1A alexsh1
                                    Samuel235
                                    @alexsh1, i must admit i like their properties but i'm not sure if thats too extreme. Maybe thats bumping the price for precision thats not needed that close. If i wanted to know the ppm exactly of the air i would get them right now. But i just care if the ppm touches a certain point roughly to then set the alarm status for the home automation controller.
                                    MySensors 2.1.1
                                      #24
                                      @samuel235 I have made some attempts with some professional supplier for some exotic ics, and even if we own a company (with my dad) they were not interested..by opensource hardware! Ok for samples, but they asked me if I wanted to be incubated! Sure if I was working in iot, kickstarter etc could tempt me a lot but it's a lot of time that I don't have, plus I'm alone on my projects...
                                      So it Seems they are more interested by big commercial batchs than our humble maker community. Not sure they like opensource schematics...or maybe for their chick :) Too bad but I was not surprised. The only thing I thought then would be to ask our chinese friend for help.
                                      I hope you will have good news, just my story, btw these are nice sensors :)
                                      • epierreE
                                        epierreE
                                        epierre
                                        @micah said:
                                        Alarm clock (with remote access, personalized wake-up midi songs, manual and auto snooze i.e.: if you don't get out of bed it rings again)
                                        Wake-up light
                                        MH-Z14 is working fdine for me over 2 years... no fault, always good values out of it, I can only recomment it ;-)
                                        z-wave - Vera -> Domoticz
                                        • epierreE epierre
                                          Wake-up light
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @epierre
                                          The only downside is (1) price and (2) it cannot be used with batteries
