  3. Which Lab Power Supply?
24 Posts 14 Posters 16.0k Views 10 Watching
  • I
    I
    Ironbar
    I am really considering this one:
    http://www.amazon.com/gp/product/B012LMOI84?colid=Y744CSFT9FT9&coliid=ICZ9KPR69X86E&ref_=wl_it_dp_o_pC_S_ttl
    EEVBlog has a little write up about it. It has a fan but it is variable and they say it is quite:
    http://www.eevblog.com/forum/testgear/inside-the-new-korad-ka3305p-linear-psu/
    • Igor KatkovI
      Igor KatkovI
      Igor Katkov
      What are the benefits of software controlled PSU versus turn-knob style?
      • tbowmoT
        tbowmoT
        tbowmo
        @Igor-Katkov
        on a sw controlled, you could have memories for the different voltages that you usually work with (for me that's 3V3, and 5V). Just a single press of a button to set the desired output voltage..
        Other than that, I don't see any advantages..
        • AnticimexA
          AnticimexA
          Anticimex
          It it is software controlled, you could also script things. Useful for testing stuff. Rough emulation of battery powered behavior and such.
          • HenryWhiteH
            HenryWhiteH
            HenryWhite
            wrote on last edited by HenryWhite
            Just buy a LTC3780 (link), exchange the pots, hook up a volt/amp display and there you have it: your own lab power supply which can deliver 1V-30V // 0A - 8A, 10A peak.
            Here's mine:
            AWIA 1 Reply Last reply
            • HenryWhiteH HenryWhite
              Here's mine:
              AWIA
              AWIA
              AWI
              @HenryWhite Looks good. I did something similar (not completely finished) but went too cheap ;-(
              A huge (0.3 V) noise/ripple on the output.... Are you able to measure the ripple with the converter you used? And what kind of transformer did you use?
              0_1460204514941_upload-fba2c7ca-80c5-4017-814e-03c5dda8de8a
              HenryWhiteH rvendrameR 2 Replies Last reply
              • AWIA AWI
                HenryWhiteH
                HenryWhiteH
                HenryWhite
                #21
                Looks good too!
                I can't measure it, because I don't have an oscilloscope (yet) :smile:
                For powering the module, I used an old 12V laptop power supply.
                • mountainmanM
                  mountainmanM
                  mountainman
                  Any thoughts on a case (ebay/ali) for homemade PSUs?
                  • AWIA AWI
                    rvendrameR
                    rvendrameR
                    rvendrame
                    @AWI , a did a similar thing, but never got the volt/amper meter work properly on the 'negative side'. Mine looks very similar (to not say identical) to yours... Would you mind to share how did you connected the V-A meters?
                    ESP8266 GW + mySensors 2.3.2
                    Alexa / Google Home
                    • rvendrameR rvendrame
                      AWIA
                      AWIA
                      AWI
                      @rvendrame As far as I remember there are two similar power positive voltage (isolated) power supplies with the meter in the positive line. Then connect the positive line of no 1 to the negative line of no 2.
