  3. Which Lab Power Supply?
24 Posts 14 Posters 16.0k Views 10 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @hek
    build one yourself? :)
    hekH 1 Reply Last reply
    • tbowmoT tbowmo
      @hek
      Yeah.. we're DIY people here right? :)
      • tbowmoT
        tbowmoT
        tbowmo
        @hek
        I'm still using my own "homegrown" lab supply, that I build 23 years ago :)
        • blaceyB blacey
          I bought this one - http://www.ebay.com/itm/Pro-30V-5A-Digital-DC-Power-Supply-Current-Tool-Precision-Variable-Adjustable-/370586966860?pt=LH_DefaultDomain_0&hash=item5648b45b4c upon recommendation from Peter Easton, the inventor of ControlLeo. Inexpensive and I have been pretty happy with it.
          @blacey There are many clones of this supply available, and I've work with one of these in the past.
          I can confirm it works OK indeed!
          • DammeD
            DammeD
            Damme
            Code Contributor
            I like this one, It's not fanless but hackable and 3 channels; http://www.meilhaus.de/en/rigol+dp832,i2.htm
            • Igor KatkovI
              Igor KatkovI
              Igor Katkov
              Some ppl suggest - DIY.
              The problem with DIY is that you need to know well what are you doing and you also need tools to debug your power supply when it does not work. Non of that applies to a typical novice.
              I suggest getting one of the low-end bench grade power supplies ~$100 on amazon.
              Example: http://www.amazon.com/gp/product/B00FPU6G4E
              Make sure you don't try to save $20 and buy the cheapest possible with low precision pots.
              Hi precision pots a re like $10+ a piece alone so you are likely to save nothing if decided to upgrade yourself. I did that and I regret it.
              One bench power supply is not enough so you can DIY your second one.
              • tbowmoT
                tbowmoT
                tbowmo
                I recently bought the digital edition of the korad supply http://m.reichelt.de/KA3005P/3/index.html?&ACTION=3&LA=446&ARTICLE=135689&artnr=KA3005P&SEARCH=Korad
                And being a sensor / control freak, I bought the one that could be controlled from a computer :) 109€ isn't that bad..
                • D
                  DavidZH
                  As I'm also searching for a new supply (I have a 2 x 30V/3A "LongWei" clone but it drifts like no other.... And I want something lighter). I tend to follow all the threads on the fora I frequent.
                  On the Tweakers.nl forum I saw a fellow tweaker who had bought one of the Korads and took EEVBlogs motto to heart. And that was a good thing! The wiring is prone to get torn on a sharp metal edge and that includes the line voltage wiring!!!!
                  So if you own one of these, please open yours up and check for abrasions!
                  The forum is in Dutch but the pictures speak for themselves: C.44 on GoT
                  My search will continue (the Rigol one looks very tempting. But that fan! :confounded: )
                  • GertSandersG
                    GertSandersG
                    GertSanders
                    I'm also interested to know if there is software for OSX that allows control of a power supply. Most power supplies have Windows software only :-(
                    • I
                      I
                      Ironbar
                      I am really considering this one:
                      http://www.amazon.com/gp/product/B012LMOI84?colid=Y744CSFT9FT9&coliid=ICZ9KPR69X86E&ref_=wl_it_dp_o_pC_S_ttl
                      EEVBlog has a little write up about it. It has a fan but it is variable and they say it is quite:
                      http://www.eevblog.com/forum/testgear/inside-the-new-korad-ka3305p-linear-psu/
                      • Igor KatkovI
                        Igor KatkovI
                        Igor Katkov
                        What are the benefits of software controlled PSU versus turn-knob style?
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @Igor-Katkov
                          on a sw controlled, you could have memories for the different voltages that you usually work with (for me that's 3V3, and 5V). Just a single press of a button to set the desired output voltage..
                          Other than that, I don't see any advantages..
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            It it is software controlled, you could also script things. Useful for testing stuff. Rough emulation of battery powered behavior and such.
                            • HenryWhiteH
                              HenryWhiteH
                              HenryWhite
                              wrote on last edited by HenryWhite
                              Just buy a LTC3780 (link), exchange the pots, hook up a volt/amp display and there you have it: your own lab power supply which can deliver 1V-30V // 0A - 8A, 10A peak.
                              Here's mine:
                              AWIA 1 Reply Last reply
                              • HenryWhiteH HenryWhite
                                Here's mine:
                                AWIA
                                AWIA
                                AWI
                                @HenryWhite Looks good. I did something similar (not completely finished) but went too cheap ;-(
                                A huge (0.3 V) noise/ripple on the output.... Are you able to measure the ripple with the converter you used? And what kind of transformer did you use?
                                0_1460204514941_upload-fba2c7ca-80c5-4017-814e-03c5dda8de8a
                                HenryWhiteH rvendrameR 2 Replies Last reply
                                • AWIA AWI
                                  HenryWhiteH
                                  HenryWhiteH
                                  HenryWhite
                                  #21
                                  Looks good too!
                                  I can't measure it, because I don't have an oscilloscope (yet) :smile:
                                  For powering the module, I used an old 12V laptop power supply.
                                  • mountainmanM
                                    mountainmanM
                                    mountainman
                                    Any thoughts on a case (ebay/ali) for homemade PSUs?
                                    • AWIA AWI
                                      rvendrameR
                                      rvendrameR
                                      rvendrame
                                      @AWI , a did a similar thing, but never got the volt/amper meter work properly on the 'negative side'. Mine looks very similar (to not say identical) to yours... Would you mind to share how did you connected the V-A meters?
                                      ESP8266 GW + mySensors 2.3.2
                                      Alexa / Google Home
                                      • rvendrameR rvendrame
                                        AWIA
                                        AWIA
                                        AWI
                                        @rvendrame As far as I remember there are two similar power positive voltage (isolated) power supplies with the meter in the positive line. Then connect the positive line of no 1 to the negative line of no 2.
