  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 345.6k Views 68 Watching
    shabba
    Its been a long time since I built one of these but I recall there were some gotchas. I have a bunch of version 2.2.3. Besides the silk screen showing wrong orientation for the regulator what else was there?
    Perhaps @aproxx could update first post?
    • A
      aproxx
      Hi @shabba.
      I assume you mean version 3.2.3 of the board?
      Besides the silkscreen of the LE33 being the other way around, there are a few other things to keep in mind:
      • The drill holes of the fuse/varistor on the 230v side might be a bit small. So it is advised to either make those holes a bit bigger, or to make the legs of the fuse/varistor a bit thinner using some sandpaper.
      • Make sure to solder the components in the correct order (As mentioned in the Word document, which is part of the ZIP file of the opening post).
      I'll update the first post of this topic in a few weeks, which includes the newer board version that fixes all the problems as stated above.
      S 1 Reply Last reply
      • A aproxx
        Hi @shabba.
        shabba
        @aproxx Thanks - It was a while since I did my last one so wanted to be clear. Looking forward to seeing new one. Great work - appreciated!
        • kurniawan77K
          kurniawan77K
          kurniawan77
          Ordered the boards... Can't wait!
          Ever thought of implementing ACS 712 ?
          • J
            J
            jemish
            I waiting for new version of two relay switch board.
            A 1 Reply Last reply
            • J jemish
              aproxx
              @jemish
              Then your wait is almost over! :) I'm currently doing my latest tests on the board, and so far everything works perfectly. I'll try and see if I can post everything during next weekend.
              Sefi NinioS 1 Reply Last reply
              • A aproxx
                @jemish
                Sefi NinioS
                Sefi NinioS
                Sefi Ninio
                @aproxx great news! This is something I look forward to!
                • Sefi NinioS
                  Sefi NinioS
                  Sefi Ninio
                  @aproxx will the second relay be opt-in?
                  I mean, will the board function normally with only one relay?
                  • Sefi NinioS Sefi Ninio
                    aproxx
                    @Sefi-Ninio
                    Yes, it will be perfectly possible to just install 1 relay on the board and it will still work fine.
                    More news in the next few days! ;)
                    • B
                      B
                      bruno
                      SuperCool!! :smile: :smile: :smile:
                      I have business trip to China in the middle of May, so I can take the PCBs directly from dirtypcbs!
                      Many Thanks for your work!!
                      • A
                        aproxx
                        The latest version of this board is available here!
                        Because of the large number of request a second (optional) solid state relay has been added to the board. Enjoy!
                        J 1 Reply Last reply
                        • B
                          B
                          bruno
                          Thanks!!
                          ranginkamanR 1 Reply Last reply
                          • A aproxx
                            J
                            J
                            jemish
                            @aproxx Where is the button/ Switch connection pin.
                            • J jemish
                              aproxx
                              @jemish
                              It's on the middle of the board on the top side. 4 pins are present to use as switch inputs. 2 pins are ground, and then pin 4 and 7 are available as well.
                              By closing the connection between pin 4 and ground you will switch te status of relay 1. When closing the connection between ground and pin 7 you'll switch the status of relay 2.
                              • A aproxx
                                Hi all,
                                **UPDATE April 17 2016 **
                                The latest version of this board is available HERE.
                                After spending a few months on this forum and a few prototypes later, I decided I wanted to build a small but cheap PCB which could be placed in either the wall behind the light switch, or above the lamp.
                                Besides the boards I've seen on this forum, I wanted these boards to contain a module to go from 230v AC to 5/3.3v DC in order to power an Arduino nano and the NRF module. I eventually ended up with a PCB which is about 4 by 4.5cm. So with all components attached I'm hoping to get in stuffed in a 5x5x3cm plastic printed case.
                                Modules which I've used to power the board:
                                [http://www.aliexpress.com/item/5-pcs-HLK-PM01-AC-DC-220V-to-5V-Step-Down-Power-Supply-Module-Intelligent-Household/32319202093.html?spm=2114.32010308.4.19.8oKfZg
                                UPDATE: 2015/09/18
                                As promised, I've got an update for this project. The board has been tested in the past week, and everything is working as expected. Compared to the previous board I've posted, I have updated the following:
                                • Solder pads of LE33CZ have been placed a little wider apart to avoid short circuit while soldering.
                                • Solder pads of the resettable fuse (Fuse2) has been placed closer together to better fit the fuses of the BOM.
                                • Moved the NRF24L01 connector a bit away from the solid state relay. Should make it easier to solder.
                                • Moved Fuse2 to another location on the board, away from the 230v circuit.
                                Some 3D pictures (Top and bottom):
                                Anyone who is interested can order the PCB HERE
                                Some documentation, complete list of required components and all gerber / DipTrace files (in case you would like to make some modifications) can be found here: MySensors board v3.2.3.zip.
                                Z
                                Z
                                zebmina
                                @aproxx I have a few left-over boards from the earlier release - where the holes for fuse2 were smaller than required (PTC Resettable Fuses 250V 1A TRF250-1000 PPTC Polymeric PTC PolySwitch). I wanted to use up the remaining boards, and wondering if the following fuse could be a substitute (USA-based, leads are smaller diameter and would fit the holes) - MF-R110 FUSE PTC RESETTABLE 1.10A HOLD MF-R110 110 MF.
                                Thanks for your guidance.
                                • Fat FlyF
                                  Fat FlyF
                                  Fat Fly
                                  http://www.aliexpress.com/item/5V-700mA-3-5W-AC-DC-Precision-Buck-Converter-AC-220v-to-5v-DC-step-down/32649591757.html?spm=2114.30010308.3.1.M5SbfZ&ws_ab_test=searchweb201556_0,searchweb201602_3_10057_10056_10065_10037_10055_10054_301_10059_10033_10058_10032_10017_107_10060_10061_10052_414_10062_10053_10050_10051,searchweb201603_2&btsid=985260cb-f95b-4394-b27e-6cd482ca0330
                                  Nca78N 1 Reply Last reply
                                  • Fat FlyF Fat Fly
                                    @Fat-Fly these tiny boards have really bad isolation and are dangerous tu use.
                                    And did you have a look at this 1-diode "rectifier" ? The ripple is probably awful and the result will affect the quality of the radio transmission.
                                    Saving 0.5$ compared to an HLK is really not worth it !
                                    • B bruno
                                      Thanks!!
                                      ranginkamanR
                                      ranginkamanR
                                      ranginkaman
                                      wrote on last edited by ranginkaman
                                      #269
                                      @bruno tanke you, very good.
                                      I share it in facebook.
                                      http://behsazmadar.ir
