  3. Add a second distance sensor to the same arduino?
18 Posts 3 Posters 4.6k Views 3 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    Absolutley none offence taken, I really suck at coding and my main methods are copy/paste and click on verify to check if it worked.
    I am using the developer branch that does not use the gw. stuff if that is what you mean?
    This is what I have tried for now but ofcourse it does not work.
    // Enable debug prints
    #define MY_BAUD_RATE 115200
    #include <NewPing.h>
    #define SONAR_A_CHILD_ID 1
    #define SONAR_B_CHILD_ID 2
    #define MOTION_A_CHILD_ID 3
    #define SONAR_A_TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define SONAR_A_ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MOTION_A_TRIGGER_PIN  2
    #define SONAR_B_TRIGGER_PIN  8  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define SONAR_B_ECHO_PIN     7  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    unsigned long SLEEP_TIME = 200; // Sleep time between reads (in milliseconds)
    unsigned long MOTION_SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    NewPing sonar_A(SONAR_A_TRIGGER_PIN, SONAR_A_ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    NewPing sonar_B(SONAR_B_TRIGGER_PIN, SONAR_B_ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    MyMessage SONAR_A_msg(SONAR_A_CHILD_ID, V_DISTANCE);
    int SONAR_A_lastDist;
    MyMessage SONAR_B_msg(SONAR_B_CHILD_ID, V_DISTANCE);
    int SONAR_B_lastDist;
    MyMessage msg(MOTION_A_msg, V_TRIPPED);
    boolean metric = true;
      pinMode(MOTION_A_TRIGGER_PIN, INPUT);      // sets the motion sensor digital pin as input
      sendSketchInfo("Distance+Motion Sensor", "1.0");
      present(SONAR_A_CHILD_ID, S_DISTANCE);
      present(SONAR_B_CHILD_ID, S_DISTANCE);
      present(MOTION_A_TRIGGER_PIN, S_MOTION);
      Serial.println(tripped);
     if(tripped)  {
      int SONAR_A_dist = metric?sonar_A.ping_cm():sonar_A.ping_in();
      Serial.print("Ping Sonar A: ");
      Serial.print(SONAR_A_dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      Serial.println(metric?" cm":" in");
      if (SONAR_A_dist != SONAR_A_lastDist) {
          send(SONAR_A_msg.set(SONAR_A_dist));
          SONAR_A_lastDist = SONAR_A_dist;
      wait(1000);
      int SONAR_B_dist = metric?sonar_B.ping_cm():sonar_B.ping_in();
      Serial.print("Ping Sonar B: ");
      Serial.print(SONAR_B_dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      if (SONAR_B_dist != SONAR_B_lastDist) {
          send(SONAR_B_msg.set(SONAR_B_dist));
          SONAR_B_lastDist = SONAR_B_dist;
      sleep(SLEEP_TIME);
    else{
      sleep(INTERRUPT,CHANGE, MOTION_SLEEP_TIME);
    Error: 'MOTION_A_msg' was not declared in this scope
    TheoLT 2 Replies Last reply
       if(tripped)  {
        wait(1000);
        sleep(SLEEP_TIME);
      else{
      TheoLT
      TheoLT
      TheoL
      @Cliff-Karlsson I'm sorry I haven't played with the development branch. I'm just using 1.5.4. But the part abount interrupts and pin2 and 3 stays the same. It's just how the Arduino works.
         if(tripped)  {
          wait(1000);
          sleep(SLEEP_TIME);
        else{
        TheoLT
        TheoLT
        TheoL
        @Cliff-Karlsson I think you want this:
        MyMessage msg(MOTION_A_CHILD_ID, V_TRIPPED);
        instead of
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          Thanks, sorry fore code-spamming but it feels like I am starting to get close to the first step witch is a succesful verify.
          The whole sketch verifies ok until it gets to the last "sleep" then I get this error:
          "expected constructor, destructor, or type conversion before '(' token"
          MyMessage MOTION_A_msg(MOTION_A_CHILD_ID, V_TRIPPED);
            boolean tripped = digitalRead(MOTION_A_TRIGGER_PIN) == HIGH;
            send(MOTION_A_msg.set(tripped?"1":"0"));  // Send tripped value to gw
           if(tripped)  {
            wait(1000);
            sleep(SLEEP_TIME);
          //else{
          TheoLT 1 Reply Last reply
             if(tripped)  {
              wait(1000);
              sleep(SLEEP_TIME);
            //else{
            TheoLT
            TheoLT
            TheoL
            @Cliff-Karlsson To me that's what this community is about. I'll have a loop. But no promise, as said before I haven't played with the development branch yet. But I do understand the compiler error
            • Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              wrote on last edited by Cliff Karlsson
              And if unclear I am trying to achieve in the end is:
              When PIR senses motion, activate both distance sensors for 30 seconds and deactivate PIR.
              After 30 seconds deactivate distance sensors and activate PIR again.
                TheoLT
                TheoLT
                TheoL
                @Cliff-Karlsson Is it giving the error on the first or the second sleep?
                I have to compliment @Hek and the other guys. They've made MySensors easier to program. The branch looks really great. Love it.
                  TheoLT
                  TheoLT
                  TheoL
                  @Cliff-Karlsson I think I found it.
                  it's in this part
                      sleep(SLEEP_TIME);
                              } // <--------- this ends the loop() method
                  //else{
                    sleep(INTERRUPT,CHANGE, MOTION_SLEEP_TIME); // <---- so this is not in the method
                  } // <-------- int this is also outside of the loop method
                  Change it to:
                      sleep(SLEEP_TIME);
                   //           }  // comment brace
                  //else{
                  • Cliff KarlssonC
                    Cliff KarlssonC
                    Cliff Karlsson
                    After commenting the bracket I get : 'DIGITAL_INPUT_SENSOR' was not declared in this scope
                      TheoLT
                      TheoLT
                      TheoL
                      @Cliff-Karlsson I'm sorry would love help you further. But it's getting late over here and my better half wants me to turn off the laptop.
                      12.5k
