  3. Add a second distance sensor to the same arduino?
18 Posts 3 Posters 4.5k Views 3 Watching
  • Cliff KarlssonC Offline
    Cliff Karlsson
    @barduino said:
    int8_t sleep(uint8_t interrupt1, uint8_t mode1, uint8_t interrupt2, uint8_t mode2, unsigned long ms=0);
    Ok so if PIRs are connected to PIN 10 and PIN 11 I would use:
    int8_t sleep(uint8_t 10, uint8_t CHANGE, uint8_t 11, uint8_t CHANGE, unsigned long ms=0);
      Cliff Karlsson
      Ok I got the two distance sensors to work and now I am trying to also add a motion sensor. First question, I read in the motion sensor sketch that only pin 2 and 3 generates interrupts and my radio is connected to pin 2 already. But I also recall reading something about pin 2 on the radio is not used so that means that I can use pin 2 and 3 for the PIRs, right?
      This is what I have come up with for now but I know there is some errors in it and I have not quite figured out the sleep part yet.
      And in the loop do I use ?
      if(tripped){"do distance stuff"}
      This is what I have go so far I added some white lines to the right of the parts that I added to the working distance sketch:
      // Enable debug prints
      #define MY_BAUD_RATE 115200
      #include <NewPing.h>
      #define SONAR_A_CHILD_ID 1
      #define SONAR_B_CHILD_ID 2
      #define MOTION_A_CHILD_ID 3 -------------------------
      #define SONAR_A_TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
      #define SONAR_A_ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
      #define MOTION_A_TRIGGER_PIN  2 ----------------------------
      #define SONAR_B_TRIGGER_PIN  8  // Arduino pin tied to trigger pin on the ultrasonic sensor.
      #define SONAR_B_ECHO_PIN     7  // Arduino pin tied to echo pin on the ultrasonic sensor.
      #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
      unsigned long SLEEP_TIME = 200; // Sleep time between reads (in milliseconds)
      unsigned long MOTION_SLEEP_TIME = 5000; // Sleep time between reports (in milliseconds) ------------------
      #define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway) ----------------------
      NewPing sonar_A(SONAR_A_TRIGGER_PIN, SONAR_A_ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
      NewPing sonar_B(SONAR_B_TRIGGER_PIN, SONAR_B_ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
      MyMessage SONAR_A_msg(SONAR_A_CHILD_ID, V_DISTANCE);
      int SONAR_A_lastDist;
      MyMessage SONAR_B_msg(SONAR_B_CHILD_ID, V_DISTANCE);
      int SONAR_B_lastDist;
      MyMessage msg(MOTION_A, V_TRIPPED); ----------------------------
      boolean metric = true;
        pinMode(MOTION_A_TRIGGER_PIN, INPUT);      // sets the motion sensor digital pin as input ----------------------
        sendSketchInfo("Distance+Motion Sensor", "1.0");
        present(SONAR_A_CHILD_ID, S_DISTANCE);
        present(SONAR_B_CHILD_ID, S_DISTANCE);
        present(MOTION_A_TRIGGER_PIN, S_MOTION); ----------------------
        boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH; ------
        Serial.println(tripped); -----
        send(msg.set(tripped?"1":"0"));  // Send tripped value to gw  -----
        sleep(INTERRUPT,CHANGE, SLEEP_TIME); -----
        int SONAR_A_dist = metric?sonar_A.ping_cm():sonar_A.ping_in();
        Serial.print("Ping Sonar A: ");
        Serial.print(SONAR_A_dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
        Serial.println(metric?" cm":" in");
        if (SONAR_A_dist != SONAR_A_lastDist) {
            send(SONAR_A_msg.set(SONAR_A_dist));
            SONAR_A_lastDist = SONAR_A_dist;
        wait(1000);
        int SONAR_B_dist = metric?sonar_B.ping_cm():sonar_B.ping_in();
        Serial.print("Ping Sonar B: ");
        Serial.print(SONAR_B_dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
        if (SONAR_B_dist != SONAR_B_lastDist) {
            send(SONAR_B_msg.set(SONAR_B_dist));
            SONAR_B_lastDist = SONAR_B_dist;
        sleep(SLEEP_TIME);
        T Offline
        T Offline
        TheoL
        wrote on last edited by TheoL
        @Cliff-Karlsson You can only use pin2 and pin3 as interrupt pins. You don't need to connect the NRF24L01+ to pin 2. So you can use both. I'm doing this with my doorbell works perfect.
        Notice. If you're node also receives messages from the gateway, you wont be able to put the node to sleep. MySensors currently doesn't support wake up on message arrival. That's why pin2 can be used for connecting sensors.
        I hope this makes sense ;-)
            wait(1000);
            sleep(SLEEP_TIME);
          T Offline
          T Offline
          TheoL
          @Cliff-Karlsson I'm not sure if you're aware of this. But in your setup, you need to start the MySensors communication. Like the gw.begin() and the presentation of the child's.
          I don't see this in your code:
          No offence. Just trying to help you.
            Cliff Karlsson
            Absolutley none offence taken, I really suck at coding and my main methods are copy/paste and click on verify to check if it worked.
            I am using the developer branch that does not use the gw. stuff if that is what you mean?
            This is what I have tried for now but ofcourse it does not work.
            unsigned long MOTION_SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
            MyMessage msg(MOTION_A_msg, V_TRIPPED);
             if(tripped)  {
              wait(1000);
              sleep(SLEEP_TIME);
            else{
              sleep(INTERRUPT,CHANGE, MOTION_SLEEP_TIME);
            Error: 'MOTION_A_msg' was not declared in this scope
            T 2 Replies Last reply
               if(tripped)  {
                wait(1000);
                sleep(SLEEP_TIME);
              else{
              T Offline
              T Offline
              TheoL
              @Cliff-Karlsson I'm sorry I haven't played with the development branch. I'm just using 1.5.4. But the part abount interrupts and pin2 and 3 stays the same. It's just how the Arduino works.
                 if(tripped)  {
                  wait(1000);
                  sleep(SLEEP_TIME);
                else{
                T Offline
                T Offline
                TheoL
                @Cliff-Karlsson I think you want this:
                MyMessage msg(MOTION_A_CHILD_ID, V_TRIPPED);
                instead of
                  Cliff Karlsson
                  Thanks, sorry fore code-spamming but it feels like I am starting to get close to the first step witch is a succesful verify.
                  The whole sketch verifies ok until it gets to the last "sleep" then I get this error:
                  "expected constructor, destructor, or type conversion before '(' token"
                  MyMessage MOTION_A_msg(MOTION_A_CHILD_ID, V_TRIPPED);
                    boolean tripped = digitalRead(MOTION_A_TRIGGER_PIN) == HIGH;
                    send(MOTION_A_msg.set(tripped?"1":"0"));  // Send tripped value to gw
                   if(tripped)  {
                    wait(1000);
                    sleep(SLEEP_TIME);
                  //else{
                     if(tripped)  {
                      wait(1000);
                      sleep(SLEEP_TIME);
                    //else{
                    T Offline
                    T Offline
                    TheoL
                    @Cliff-Karlsson To me that's what this community is about. I'll have a loop. But no promise, as said before I haven't played with the development branch yet. But I do understand the compiler error
                      Cliff Karlsson
                      wrote on last edited by Cliff Karlsson
                      And if unclear I am trying to achieve in the end is:
                      When PIR senses motion, activate both distance sensors for 30 seconds and deactivate PIR.
                      After 30 seconds deactivate distance sensors and activate PIR again.
                        T Offline
                        T Offline
                        TheoL
                        @Cliff-Karlsson Is it giving the error on the first or the second sleep?
                        I have to compliment @Hek and the other guys. They've made MySensors easier to program. The branch looks really great. Love it.
                          T Offline
                          T Offline
                          TheoL
                          @Cliff-Karlsson I think I found it.
                          it's in this part
                              sleep(SLEEP_TIME);
                                      } // <--------- this ends the loop() method
                          //else{
                            sleep(INTERRUPT,CHANGE, MOTION_SLEEP_TIME); // <---- so this is not in the method
                          } // <-------- int this is also outside of the loop method
                          Change it to:
                              sleep(SLEEP_TIME);
                           //           }  // comment brace
                          //else{
                            Cliff Karlsson
                            After commenting the bracket I get : 'DIGITAL_INPUT_SENSOR' was not declared in this scope
                              T Offline
                              T Offline
                              TheoL
                              @Cliff-Karlsson I'm sorry would love help you further. But it's getting late over here and my better half wants me to turn off the laptop.
