  3. Is this possible? MQTT & Node request...
5 Posts 3 Posters 1.9k Views 3 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    Evening all,
    I'm currently using the MQTT client on an ESP8266. I have a number of sensors deployed using a mixture of Nano's and Mini's.
    I'd like to know if this is possible:
    Node 1 - Rain Sensor (Digital input) / Soil Sensor (Digital Input) / Light Sensor
    Node 2 (Sleeps and wakes every 10 minutes) - Relay
    I'd like Node 2 to wake and check either the values of node 1, or alternatively check a source such as NodeRED for the values. Based on the values open / close the relay.
    Currently I have the MQTT client connected to Mosquitto.
      Yes, it is possible to send a request-message to any node (see api).
      But your Node1 have to answer Node2's requests-messages manually in its incomingMessage-method. As The MySensors library doesn't keep any last state by itself.
      • Mark SwiftM
        Mark SwiftM
        Mark Swift
        Hello @hek
        Thank you for the reply, and the amazing MySensors.
        Do you think I could have Node2 request some kind of status from NodeRed for example, rather than the Node directly?
        Cheers,
        Mark
        noelgeorgiN 1 Reply Last reply
          Sure, if NodeRed can keep the state and answer req-messages. I don't know the full capabilities of NodeRed.
          • Mark SwiftM Mark Swift
            Hello @hek
            Cheers,
            Mark
            noelgeorgiN
            noelgeorgiN
            noelgeorgi
            @Mark-Swift check this for node-to-node communication http://forum.mysensors.org/topic/3467/basic-setup-network/2 as @hek said setup a database in nodered to save the values received from node-1 and you could request that from node-2
