  3. Slim Node 5V-Mod
Slim Node 5V-Mod
17 Posts 7 Posters 8.8k Views 8 Watching
    I agree too for traces. and for instance some fabhouse has a 6mil trace min but often says 8mil is recommended. So if you don't want to have broken trace during pcb fab process, it's better 8mil min or 10mil is nice, for signals ;) For below, it's premium pcb, more expensive better quality..
    I have already used 8mil because it was compact, worked ok, but 12 or 10mil is usually my setting. and for power..16 to 20mils, it depends where..lol :)
    • SoloamS
      SoloamS
      Soloam
      wrote on last edited by Soloam
      Hi all, thank you for the replays, this is the first time that I use KiCat, so I used @m26872 design as a start up! For what I can see, the VCC and GND traces are 1,000mm and the signal traces 0,250 mm! Is it good? Not lots room in the PCB! I'll post better images, the ones that I've included are very low resolution!
      @ahmedadelhosni I think you are right, I've seen an image online and this was the layout, but now I've been looking at the datasheet (noob mistake) and I think that I missed them out! Tomorrow I'll assemble the test circuit and test it out!
      Thank you all
      • SoloamS
        SoloamS
        Soloam
        Main post updated, I'll validate the LE33 pin layout tomorow and post back!
        • m26872M
          m26872M
          m26872
          If you read through the connect radio - build site old comments you'll see that I've validated the labeled LE33 image posted there. If it turns out to be wrong again, please notify.
          • GertSandersG
            GertSandersG
            GertSanders
            Looking at the schematic, this should work fine.
            • SoloamS Soloam
              Hello all, I've been using m26872 slim node to some of my nodes, but my main problem was not being able to power it with 5V because the RF is only 3.3v. So I made some modifications to the design and now I'm asking for your help to see it and validate it! I'm no expert in electronics (not at all) and this is my first attempt with KiCat.
              The main idea is to power the Radio with a LE33A step down regulator! Here is the result:
              1_1460679153850_print.pdf
              BOM
              C1,C2,C3 : 0.1uF capacitor P-5mm (low to fit inside IC1 socket)
              C5 : 0.1uF capacitor P-2.5mm
              IC1 : Atmega328p
              R1 : 10k resistor 1/4W
              P4 : nRF24L01+
              U1: LE33A
              What do you think, will it work? My main concern is the Capacitors!
              Thank you all.
              Best Regards
              PS: Credits and tanks to @m26872 for the base design and help
              AWIA
              AWIA
              AWI
              @Soloam Any specific reason to use LE33A? The quiescent current of this LDO is typ. between 0.5 (no load) and 1.5 mA . Unless you are using a > 6 V input voltage I would suggest using the 662K. Can be soldered by (a stable) hand, small footprint, very cheap and quiescent current of only 1 uA (typ.).
              m26872M 1 Reply Last reply
              • AWIA AWI
                m26872M
                m26872M
                m26872
                @AWI - the notorious SMD-free concept violator - :wink:
                AWIA 1 Reply Last reply
                • m26872M m26872
                  AWIA
                  AWIA
                  AWI
                  @m26872 ouch.. :grinning: ok, a to-92 alternative MPC1700
                  But why drill holes...
                  • SoloamS
                    SoloamS
                    Soloam
                    @SMD is a lot harder to solder, I prefere this one :)
                    I checked the LE33 and my layout is correct, that is the correct way to put it!
                    • SoloamS
                      SoloamS
                      Soloam
                      Hi all! I have merged 3 boards into one 50x50 layout, this way I can send it to print in dirtypcbs.com and order 10 pcb's, that will make 30 nodes! The solution is similar to the one used by @m26872
                      • SoloamS
                        SoloamS
                        Soloam
                        Order submitted, now I just need to wait for the arrival!
                        I started also a new project that will control my light switches.
                        https://www.openhardware.io/view/83
                        badmannenB 1 Reply Last reply
                        • SoloamS Soloam
                          badmannenB
                          badmannenB
                          badmannen
                          @Soloam
                          Hello looks like a great board. Any progress on the Switch board?
                          //Henrik
                          rPi 3 - UNO R3 - Mini - Nano - custom
