  3. My 32bits ATSAM node project
26 Posts 9 Posters 13.5k Views 14 Watching
  • carlierdC
    carlierdC
    carlierd
    Very good job ! I will be happy when I will able to do 10% of your work ;)
      thx guys, that's really kind comments :)
      I hope to fix my small bug about upload in arduino ide, to share then. I don't know yet where it comes from.. I need to investigate as it's a little bit different compared to Arduino Zero because I'm using a "smaller" pincount chip so maybe it needs some tune.
      In other hand, I am already dreaming of a @Tekka's atsam ota bootloader lol ! few second upload with jlink with only two pins and then ota. But in other hand it's nice when usb is there, to have the native usb in ide so I really need to fix this (certainly software related..).
      Tests I did to try to understand:
      • with first homemade board ATSAMD21G: upload of adafruit bootloader (which I think is derived from the Zero or maybe the same). My device is then detected in Windows as an Adafruit device Virtual com port. In ide, I choose adafruit Feather board, upload sketch. Yeah! If I choose Zero board, it uploads too! And in Windows, my device is then detected as a Zero device. I can do inverse. So it's interchangeable but not recommanded because you need to take care about io mapping of boards, variant cpp...
      • with my second board, ATSAMD21E : I use bossa bootloader from atmel dedicated for this chip, BOSSA programming device comport well detected in windows on COM14 for instance, but I get a "no device found on comport14" when I try to upload in arduino ide..I tried with others bootloader, still the same..of course!
        If you are curious, Bossa is sort of avrdude which is included in arduino ide for atsam. I have multiple programmer, but for the moment I am using a Segger OB which is the same as Atmel ICE (I had luck to find this programmer, genuine, discounted!)
        wew! I have just got the blink led sketch uploaded from arduino ide on my custom D21E. great! now I need to check my board and io mapping. cool cool :)
          cool I have my Chi mote working on my custom board, after few changes in libs regarding atsam :)
          Next step, mysensors libs and I can't wait to receive my lora module to give a try. I have nrf smd footprint but no more in stock, so impatient that I'm thinking to unsolder one on another board :laughing:
          N 1 Reply Last reply
          • tbowmoT
            tbowmoT
            tbowmo
            @scalz
            Cool project! :)
            But RFM95W is not supported by MySensors yet? (at least I think that it doesn't.. Haven't seen a git commit for it in the library). So are you going to use another library for that module?
              @tbowmo thx :)
              I'm discovering the joy of new chip :) and the stuff about sam bootloader, arduinocore, board/pin def. I have not digged so much but still good to know how things are connected.
              Hopefully I found a bootloader+board def which fits almost with my pinout, but spi part which is not in same order. Cool this story of configurable sercoms..but that still needs to adapt a little bit pins define in variants...does I understand right? Sometimes it's very confusing all this stuff of pins define between boards etc..
              I have not tested the spi part yet, but very soon I will wire at least rfm69 and nrf. I have not received my Lora. I have looked at multiple libs, don't know yet which one. My first choice may be not radiohead, I will try it sure, but I would like something "standalone". I will start with basic examples! and then "standalone" will be easier to add to mysensors transport stuff I guess (my lazy way..) But don't know yet when :confused: I would like to finish what I have started on rfm69 part.
              • tbowmoT
                tbowmoT
                tbowmo
                @scalz
                Do the RFM95 use the same footprint as RFM69?
                About the SPI, you might need to hack the standard arduino SPI driver a bit (I have done this for the GW module..), depending on how you have wired your sercom/SPI unit..
                  @tbowmo
                  yes I have found where to hack spi pins...will give a try this evening I think. If I can't get it to work may I ask you ? :)
                  To resume a little bit about rfm, there are:
                  • RFM69HW : High power version (best known version)
                  • RFM69W : non-high Power version, pincompatible with RFM69HW
                  • RFM69CW : other non-high power version too, but not pincompatible with those above W
                  • RFM69HCW : High Power version again. But we could think this one is pincompatible with the simple CW. That's not the case! This one is pincompatible with RFM95W!
                  All these RFM69 are software compatible. Very confusing, isn't it? but more options!
                  As you can see, I have made this board for long range fun, and personal challenge :) With RFM69 high power version and RFM95 (outdoor, and that's why there is the lipo charger maybe basic solar app) .
                  But in case, I would like to have a lower power radio, I added nrf footprint. I couldn't add another low power RFM69! I will certainly have two version of this board: one long range, another RFM69CW+nrf maybe without lipo charger this time..
                    @tbowmo
                    hi. I was just thinking that I didn't give news about my mux!
                    in case, I guess you already know it, but that helped me so I share:
                    https://learn.adafruit.com/using-atsamd21-sercom-to-add-more-spi-i2c-serial-ports/creating-a-new-spi
                    I tried the howto for i2c too. worked nice.
                    so no need to hack the lib in my case. (even if I have rerouted my board to fit mattair pindefinition which I prefer because "real" pin number match to pin number in arduino..matter of taste).
                    Perhaps hacking libs could give a little bit more freedom but that's already pretty flexible like this, cool :)
                    I have not had lot of time for my lora modules yet, still on my desk, pfff :disappointed:
                    • TheoLT
                      TheoLT
                      TheoL
                      Amazing work again. I really love the name Chi-mote ;-)
                        @TheoL thx ;)
                        I am really beginning to like this little 32bit chip.. mux flexibility, enough memory, the price. Even if I was planning to use my jtag smd pins with pogo, usb cdc is cool for direct connection programming and uploading is really fast!
                        the only downside is, I was aware, it require to make changes in sensors libs , to add constructors for platforms defines+modifying a little bit our common wire, spi, interrupt functions. For testings purpose it's ok, but I should fork these libs to add my changes...so much work!!! for the moment I have tested/modified only few libs like SI7021, ambiant light sensors, apds9960, 9930, mems, neopixel etc., still local..
                        I will now post my design files soon for those who would like to try ;) I just need to make few tests/minor decisions on my design.
                        When I see those price of released lora boards...wow, sure could be better but I'm happy with my board. I thought that I could try to make my own rfm95 circuit onboard, could be cheaper and a little bit smaller. But generally, I prefer to use a FCC compliant module, especially for lora...and so I can have footprint for an other radio, more modular, who said useless lol!
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @scalz
                          Most of these sensors that you mention (si7021 etc) they are I2C, so only the base I2C driver needs to be adapted, so what changes are necessary for (for example) SI7021 to get working on the atsamd?
                            @tbowmo you're right, it's because of a wrong mapping!! If I only use something like Wire.begin(sda,scl) it didn't worked well for me. Of course this could be fixed in variant, sercom.. etc but I didn't want to change this or create mine (I prefer to stick an existing/well updated one). So the only thing I need, to "remap" my pins, is :
                            #include "wiring_private.h" // pinPeripheral() function
                            #if defined(MY_ATSAMBOARD)
                                TwoWire newWire(&sercom3, 22, 23);
                            And in setup, or in libs..
                                newWire.begin();
                                // Assign pins 13 & 11 to SERCOM functionality
                                pinPeripheral(22, PIO_SERCOM);
                                pinPeripheral(23, PIO_SERCOM);
                               Wire.begin();
                            And then I need to use my newWire object instead of common Wire.
                            rough example, not beautiful, that should be better done I know..but it's rough test and for my bad mapping. When remapped to the right pindef boards, that should work like it should do..
                            Hum..I will give another try to Wire.begin(x,y) to see, you make me not sure now...:confused:
                            In other hand, how libs manage if someone want to play with another i2c? Wire function and begin() are hardcoded in libs, so it use default i2c bus mapping...
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @scalz
                              I've made "local" copies of SPI / TwoWire libraries (Local as in mysensors specific), which are added to the SAMD GW hw profile in Arduino.
                              So people just choose the correct board, and everything is setup for them :)
                                @tbowmo cool, thx :) I forgot that's included in mysensors git! I will look at your work and diffcheck to see your changes. I will try this for this rev at least even if it's working with ugly cheat ;)
                                My next rev follow mattairtech board. So I won't need this, and no arduinocore files versioncheck . I let others doing this. So I will just choose the right hardware in ide and that should work like a Zero. This is actually what I am doing but I am cheating to fix my wrong mapping.
                                Thx for your feedbacks. I agree with you, each test/learning session takes a lot of time but I will try your way and report; the way I started to look but found a trick :)
                                  @tbowmo
                                  cool, finally I have made my board definition :blush:
                                  maybe I was missing something during my previous attempt as it was not so hard..
                                  works nice like you said ;)
                                  look at this upload speed!! not a big upload (just an example test sketch) but crazy cool :smiley:
                                  thx :+1:
                                  • KoreshK
                                    KoreshK
                                    Koresh
                                    wrote on last edited by Koresh
                                    Very interesting thread!
                                    I hope arduino project (and any child projects) will move to more fast hardware in near future!
                                      @Koresh oops didn't see your answer, thx seriously I'm very glad :) but there are still few things which are choking my eyes. That's why this one is not released yet. arghh, not enough time!
                                      • L
                                        L
                                        lafleur
                                        What the current status of your 32bit project??
                                        Also what work have you done with the RFM95 radio and it integration into MySensor 2.0b??
                                        I'm looking at doing some work with the RFM95 and do not want to duplicate work that may already been done or started.....
                                          #23
                                          on my desk lol I have not made a box for it yet! comm is working with basic libs examples. and I'm playing with my custom Zero and sensors. And I will be more tempted when I will have received my usb dongle pcb :)
                                          so you can do it if you want. like I said I will look at it bit later, if not already integrated ;)
                                          not a big thing that mostly need to do the transport layer. time I don't have for the moment..arghh
                                          mtiutiuM 1 Reply Last reply
