Changing CE/CS Pins used
Hi Hek,
In the earlier library versions we specified the pins for CE/CS when we specified the relay or sensor function( is it a function?)
ie: "Sensor gw(9,10);"Now you have moved these default values into the sensor.h file:
* @param _cepin The pin attached to RF24 Chip Enable on the RF module (defualt 9) * @param _cspin The pin attached to RF24 Chip Select (default 10) */ Sensor(uint8_t _cepin=9, uint8_t _cspin=10);My question is, can i override these pin values by continuing to call the function with the values i require?
ie: Sensor gw(8,9);or....do i need to change sensor.h /relay.h as i need?
( same applies with the interupt pin...i need to use pin D3.)
Greg
Yes, that's exactly how you would do it - the defaults only apply if the function is called without parameters.
Fantastic.. Thanks for this.
