  3. Anything to be concerned about, or caused by MQTT gateway?
8 Posts 2 Posters 1.3k Views 2 Watching
  • Mark SwiftM Offline
    Mark SwiftM Offline
    Mark Swift
    Hi Guys,
    I've finally built my multi sensor (rain, moisture, LUX, distance).
    On sensor startup I get the following:
    Starting sensor (RNNNA-, 2.0.0-beta)
    Radio init successful.
    send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=ok:Rn+M+T+H
    send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    send: 3-3-0-0 s=0,c=0,t=1,pt=0,l=0,sg=0,st=ok:
    send: 3-3-0-0 s=1,c=0,t=1,pt=0,l=0,sg=0,st=ok:
    send: 3-3-0-0 s=2,c=0,t=16,pt=0,l=0,sg=0,st=fail:
    send: 3-3-0-0 s=4,c=0,t=15,pt=0,l=0,sg=0,st=ok:
    send: 3-3-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=fail:
    send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:2.0.0-beta
    Init complete, id=3, parent=0, distance=1
    Moisture Sensor
    send: 3-3-0-0 s=0,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
    Rain Sensor
    send: 3-3-0-0 s=1,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
    548
    send: 3-3-0-0 s=2,c=1,t=37,pt=3,l=2,sg=0,st=ok:548
    Ping: 0 cm
    I'm using the MQTT gateway if that's related. Apart from the above failures the sensor works faultless. Further, if I use the standard repeater sketch for example I don't get the failures, so it must be lated to presentation, or something? The fails always occur in the same place.
    Can anyone help we diagnose if it's an issue?
    Mark
      Mark SwiftM Offline
      Mark Swift
      Sorry to bump this, I've been trying to work it out but I'm still not sure why these particular items fail. Can anyone offer any insight?
      • mfalkviddM Offline
        How close in time are the failing messages sent? There have been some cases where delaying 50-500ms between each send has helped.
          Mark SwiftM Offline
          Mark Swift
          @mfalkvidd I haven't changed anything from default, how would I introduce a delay for testing? Do you know what can cause such errors?
          Thank you!
          • Mark SwiftM Mark Swift
            Thank you!
            @Mark-Swift sending a lot in a short time can show power issues I guess.
            You add delay(500); between each send.
              Mark SwiftM Offline
              Mark Swift
              @mfalkvidd Makes sense, I'm currently using the latest development version and there's little in the sketch related to sends, do I need to edit one of the files in the library?
                Sorry, I'm not very familiar with the development version (still using 1.5).
                But it looks like the rain example is already waiting between each send (it uses wait, which is better than delay since delay blocks the radio from receiving):
                void presentation()  {
                  wait(DWELL_TIME);
                  present(CHILD_ID_RAIN_LOG, S_RAIN);
                  wait(DWELL_TIME);
                  present(CHILD_ID_TRIPPED_INDICATOR, S_MOTION);
                  wait(DWELL_TIME);
                #ifdef DHT_ON
                  present(CHILD_ID_HUM, S_HUM);
                  wait(DWELL_TIME);
                  wait(DWELL_TIME);
                You could try increasing DWELL_TIME from 125 to 500 and see if that helps.
                  Mark SwiftM Offline
                  Mark Swift
                  I'll give it a shot, thank you!
                  12.1k
