  3. Chinese Solar Lipo powered PIR led lamp.
42 Posts 9 Posters 32.6k Views 19 Watching
  • korttomaK korttoma
    I guess you meant U4 is the 3.3V regulator. I measured it to 3.3V and HT33 should be a regulator. Q1 and Q2 I think are transistors. U3 handles the solar charging. U1 is for the PIR but unfortunately there is no text on the chip. I will get you the link tomorrow but it is quite easy to find on aliexpress.
    gyroG
    gyroG
    gyro
    @korttoma
    sorry my typo: you are correct
    • U4 - HT33 is voltage regulator
    • yes Q1 and Q2 are transistors
    • U1 - PIR out test - measure voltage between PIN 6 and R3 when PIR is OF and ON. I think this drives Q2 (high brightness / low brightnes)
    also take picture of other side of circuit board, beause i think Q1 is conected to R10 and
    then further on the other side
    • korttomaK
      korttomaK
      korttoma
      Here is the link to the one I got but it seems like the prize is allot higher now since I paid 23,84$ including shipping -> http://www.aliexpress.com/item/1-Set-1200-Lumens-46-pcs-LED-Solar-Power-Motion-Sensor-Lamp-Ultra-thin-PIR-Outdoor/32354254209.html
      Also it took like 10 weeks for it to arrive so maybe another seller would be a better fit.
      • Tomas
      • korttomaK
        korttomaK
        korttoma
        There is not much on the other side of the board, just a status LED, a button to turn it on and the PIR.
        • Tomas
        gyroG 1 Reply Last reply
          gyroG
          gyroG
          gyro
          @korttoma
          Are you sure that this light has two modes of operation or only one: when a person is present is activated for 15s and then switched off
          • korttomaK
            korttomaK
            korttoma
            I'm sorry I did not test the device I just read the manual so I think that yes it has 2 modes for LED brightness.
            • Tomas
              gyroG
              gyroG
              gyro
              @korttoma
              Don't be sorry.I am not an circuits expert, I just try help you figure things out.
              You wil have to test this lamp a little bit.
              it looks that Q1 drives U1 active/not active when there is sun, but how/what turns on dimm lights in dark?
              Did you measure U1 pin 6 when pir active/not active?
              • korttomaK
                korttomaK
                korttoma
                In the application I will use this one I actually do not care so much for the built in PIR and LED, I just see it as a smart enclosure with a solar battery power-supply built in. I will tap in to the 3.3V regulator to power a pro mini that has an external PIR and (LDR) Light sensor. In addition to this I would like to add voltage measurement for the battery. BTW, did you komplette your sketch? I would like to copy the battery voltage sensor part. I will look att figuring out the circuit later, it does not look to complicated.
                • Tomas
                  gyroG
                  gyroG
                  gyro
                  @korttoma
                  I did try some battery measurement variants. The following code works best for me. I suggest that you first try the following sketch.
                  • measure the voltage with voltmeter on VCC pin and correct #define VREF value so it will be a close as possible to measured value before you integrate into case specific code
                  // define values for the battery measurement
                  #define R1 1e6
                  #define R2 330e3
                  #define VMIN 2.8
                  #define VMAX 4.2
                  #define ADC_PRECISION 1023
                  #define VREF 1.13
                  int oldBatteryPcnt = 0;
                  int batteryVoltage = 0;
                  int BATTERY_SENSE_PIN = 0;
                  int val = 0;
                       analogReference(INTERNAL1V1);
                       analogReference(INTERNAL);
                    Serial.begin(9600);
                     //float batteryPcnt = getBatteryPercentage();
                    //val = analogRead(BATTERY_SENSE_PIN);
                    //Serial.println(batteryVoltage);
                    float batteryVoltage = getBatteryPercentage();
                    float batteryV= batteryVoltage;
                    float batteryVmap = fabs(fmap(batteryV, 2.5, 4.2, 0.0, 1000.0));
                    int batteryPcnt = batteryVmap / 10;
                    if (batteryPcnt >= 100) {
                  	  batteryPcnt = 99;
                     Serial.print("Battery voltage: ");
                     Serial.print(batteryPcnt);
                     Serial.println(" %");
                  delay(2000);
                     /*if (oldBatteryPcnt != batteryPcnt) {
                       // Power up radio after sleep
                       //gw.sendBatteryLevel(batteryPcnt);
                       oldBatteryPcnt = batteryPcnt;
                    // totally random test values
                  float getBatteryPercentage() {
                    // read analog pin value
                    int inputValue = analogRead(BATTERY_SENSE_PIN);
                    // calculate the max possible value and therefore the range and steps
                    float voltageDividerFactor = (R1 + R2) / R2;
                    float maxValue = voltageDividerFactor * VREF;
                    float voltsPerBit = maxValue / ADC_PRECISION;
                    float batteryVoltage = voltsPerBit * inputValue;
                    float batteryPercentage = ((batteryVoltage-VMIN)/(VMAX-VMIN))*100;
                    //int batteryPercentage = map(batteryVoltage, 0, maxValue, 0, 100);
                    //return batteryPercentage;
                    return batteryVoltage;
                  float fmap(float x, float in_min, float in_max, float out_min, float out_max) {
                  	return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
                  • korttomaK
                    korttomaK
                    korttoma
                    This means that you use A0 for measuring right?
                    #define R1 1e6
                    #define R2 330e3
                    And you have used 1Mohm and 330kohm for the resistors?
                    • Tomas
                      #define R1 1e6
                      #define R2 330e3
                      gyroG
                      gyroG
                      gyro
                      wrote on last edited by gyro
                      #36
                      Hi @korttoma
                      • yes battery sense is A0
                      • yes R1 and R2 are resistors values to measure Lipo voltage
                      • korttomaK
                        korttomaK
                        korttoma
                        Thanks for the code and the additional info. Measuring the battery seems to work as expected but using the Internal reference seems to mess with the light level measurement LDR. Is it possible to use indifferent reference for different analog inputs? Or do I need to recalculate my LDR voltage divider?
                        • Tomas
                        • korttomaK
                          korttomaK
                          korttoma
                          I managed to squeeze in a pro mini and radio that is now powered from the 3.3V available from the built in circuit board. It has battery voltage measurement, light level and a external PIR.
                          • Tomas
                            gyroG
                            gyroG
                            gyro
                            #39
                            @korttoma great that you maneged to connect it lamp..
                            I don't know if analog reference is than set for all analog interfaces..
                            Just one more thing you should adjust:
                            I have figured out that I need to raise alarm for lower threshold for battery to higher than 3V (now is 2.5V!) because regulator voltage drop is ~250mV, and mini pro drops out at around 2.8V..
                            But the whole concept now works fairly good
                            • ranseyerR
                              ranseyerR
                              ranseyer
                              wrote on last edited by ranseyer
                              #40
                              im waiting to my Chinese Lamps. So i ordered in the meantime one directly in Germany: TaoTronics Solar ...-16 LED (Model TT-HSL002)
                              https://www.amazon.de/gp/product/B00REDHZMW
                              As you can see there is very different PCB. Do you have a hint for me if modification makes Sense ?
                              ed: now with external images:
                              Greetings
                              • ranseyerR ranseyer
                                Greetings
                                gyroG
                                gyroG
                                gyro
                                #41
                                @ranseyer
                                This one looks is a little complicated. I think you should wait for china version :)
                                Take a picture of other side of circuit also.
                                ranseyerR 1 Reply Last reply
                                • gyroG gyro
                                  @ranseyer
                                  ranseyerR
                                  ranseyerR
                                  ranseyer
                                  @gyro
                                  Thanks for the Answer. Mine was produced in China too...
                                  Her the picture of the backside:
                                  No connections, but a board name: YYGF-601L.
                                  I would be happy for any hints...
