  3. NRF24L01+PA+LNA wiring question
15 Posts 5 Posters 7.5k Views 4 Watching
  • parachutesjP
    parachutesjP
    parachutesj
    Hi there,
    I just received 2 NRF24L01+PA+LNA from the ebay shop linked on the store page and I am not sure if I connected them false or they are both broken.
    I understand, that they need a stable power source with 3.3V which I provided. I connected GND and VCC to the external power supply making sure it has enough juice and all other pins according to the radio wiring guide. All data sheets I found state, that the wiring is identical to the NRF24L01+
    So did I win the lottery and received two faulty examples?
    When connecting them and powering up my node, I do not see anything in the serial monitor - as soon as the standard radio without external antenna is attached, it works.
    I am lost...
    SJ
    • T
      TimO
      Just a guess: Are GND from the NRF24L01+ and the Arduino interconnected? Did you use the external supply together with the standard radio too?
      parachutesjP 1 Reply Last reply
      • T TimO
        parachutesjP
        parachutesjP
        parachutesj
        @TimO
        Thank you, yes I powered it completely via breadboard and the only power came via external supply during one of the tests.
        • T
          TimO
          Strange! Sounds to me, the arduino is not starting up, if the NRF24L01+PA+LNA is connected. Maybe there is a bypass between VCC and GND? Did you check the voltage on VCC?
          The wiring between those radio modules is indeed identical.
          • marekdM
            marekdM
            marekd
            Hi, did you try to use standard NRF24 with the same wiring? That is the shortest way to check are they faulty or your wiring is not so good.
            • marekdM marekd
              parachutesjP
              parachutesjP
              parachutesj
              @marekd @TimO
              yes, exactly same wiring. But works now!
              So to summarize:
              the +PA+LNA pin layout is similar, it seems quite picky in power requirements, so using external stable power is mandatory!
              After adding a capacitor AND changing the Arduino to a Nano it got to life. I do not know what the problem with that UNO was I 've been testing for hours but after changing it, all good now.
              Thank you all for your help.
              SJ
              • OitzuO
                OitzuO
                Oitzu
                wrote on last edited by Oitzu
                @parachutesj
                Maybe it didn't liked the signals from the UNO. :P You would maybe see something on a oszi but it's probably not worth the hassle. :)
                Other guess: 5V Uno 3.3V nano?
                There are also many topics on this forum how to get the PA/LNA module in a working state, can be quite tricky and frustrating.
                • OitzuO Oitzu
                  @parachutesj
                  parachutesjP
                  parachutesjP
                  parachutesj
                  @Oitzu
                  I don't have any measurement equipment at hand or qualifications to use it so all trial and error :-(
                  But power of the two shouldn't make any differences - I always connected external power as I have been warned and stepped it down to 3.3V.
                  Anyhow, as much information we collect, the easier it will become for others to learn
                  marekdM 1 Reply Last reply
                  • parachutesjP parachutesj
                    @Oitzu
                    marekdM
                    marekdM
                    marekd
                    @parachutesj
                    I'm using it at Nano (serial gateway), with power supply from Nano - and works just fine - no problem whatsoever. No extra caps.
                    Have one UNO and will make some test later and tell you how it works.
                    • marekdM
                      marekdM
                      marekd
                      OK, so I made quick tests with my UNO, just replace standard NRF model with PA/LNA and works OK. Maximum current draw was around 62 mA (with standard MySensors setting for NRF) so there should be no current problem. Power supply for UNO is standard Sony phone charger .85A 5V. There are 2 sensors connected to this UNO (DS18b20 and RTC3231SN).
                      • marekdM marekd
                        parachutesjP
                        parachutesjP
                        parachutesj
                        @marekd
                        thank you for your efforts. Maybe I got cheep ones... where did you order your radios?
                          @marekd
                          marekdM
                          marekdM
                          marekd
                          @parachutesj no problem. I ordered from http://www.ebay.com/itm/310651702557?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                          like other things 😎
                          • marekdM marekd
                            like other things 😎
                            parachutesjP
                            parachutesjP
                            parachutesj
                            @marekd
                            THX
                            got mine from the same seller - strange. I will try later with an original UNO and see how this goes.
                              @marekd
                              THX
                              Matt
                              @parachutesj
                              Couple of things - get yourself a cheap multimeter. Indispensable and pretty important piece of kit when you are doing this kind of stuff, will save you frying stuff and help with trouble shooting.
                              The PA+LNA version needs around 120 milli amps at peak power (from memory) some of the duinos cant supply this.
                              And use the caps as suggested in the wiring guide for the NRF modules on this site.
                              Cheers,
                              Matt
                              • M Matt
                                @parachutesj
                                Cheers,
                                Matt
                                parachutesjP
                                parachutesjP
                                parachutesj
                                @Matt
                                Thanks for that. Will follow your advise.
                                Actually I tested the radio with a few other Arduinos and all work except the one which I used in original post. So I guess this is faulty and already trashed.
                                Cheers,
                                SJ
