  3. Power/ Usage sensor - multi channel - local display
41 Posts 6 Posters 24.8k Views 7 Watching
    MarkV
    wrote on last edited by MarkV
    #31
    I meen the master sketch like written above.
    I'd want to build a gateway but without the wireless RF part, just connect the master arduino directly through usb to the RasberryPi and readout the measurements.
    So in general:
    Kwh Meters -- cable --> Slave arduino <-- serial --> Master arduino <-- USB --> RasberryPi
    AWIA 1 Reply Last reply
    • M MarkV
      So in general:
      AWIA
      AWIA
      AWI
      @MarkV If you don't want it to be MySensors enabled and not used the display etc. it's easier to readout the slave with the raspberry. The protocol is a simple Json and if you use a nano for the slave you can connect it with usb..
        MarkV
        #33
        Last weeks i'm trying to get it to work but without luck. Could you give a manual on how to get it working with json? What should we do? And how? On my rasberry, on the arduino and in domoticz??
        • AWIA AWI
          @FotoFieber To be honest .. a left over from some experiments. Just leave it out... you won't notice the difference.
          MarkV
          #34
          @AWI
          Goodmorning,
          I've got a question, are you planning to re-write the script for the main and slave Arduino to the new MySensors 2.0 structuur?
          I've also tryed to look on github if there's a page from you, but didn't find it...
          • M MarkV
            @AWI
            Goodmorning,
            AWIA
            AWIA
            AWI
            wrote on last edited by AWI
            #35
            @MarkV I updated the sketch for main a few months ago to development (pre-2.0). Also changed it a little for stability and removed the (complicated) JSON library The slave has no MySensors dependency.
              MarkV
              Super.
              I've updated everything and it's up and running.
              But my Master arduino (UNO clone) gives this readout on the USB port:
              0;255;3;0;11;AWI-12ChannelPulse
              0;255;3;0;12;2.0
              0;0;0;0;13;Groep 1
              0;1;0;0;13;Groep 2
              0;2;0;0;13;Groep 3
              0;3;0;0;13;Groep 4
              0;4;0;0;13;Groep 5
              0;5;0;0;13;Groep 6
              0;20;0;0;36;Usage meter LCD
              0;20;1;0;47;-
              0;255;3;0;1;
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;20;2;0;47;
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;20;2;0;47;
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;20;2;0;47;
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;20;2;0;47;
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;20;2;0;47;
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;20;2;0;47;
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;20;2;0;47;
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;20;2;0;47;
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;20;2;0;47;
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;20;2;0;47;
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;20;2;0;47;
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              0;255;3;0;1;
              0;1;1;0;17;0
              0;1;1;0;18;-0.001
              0;255;3;0;1;
              0;2;1;0;17;0
              0;2;1;0;18;-0.001
              0;255;3;0;1;
              0;3;1;0;17;0
              0;3;1;0;18;-0.001
              0;255;3;0;1;
              0;4;1;0;17;0
              0;4;1;0;18;-0.001
              0;20;2;0;47;
              0;255;3;0;1;
              0;5;1;0;17;0
              0;5;1;0;18;-0.001
              0;255;3;0;1;
              0;0;1;0;17;0
              0;0;1;0;18;-0.001
              Is this correct?
              Because Domoticz doesn't change the values.
              Also this is not the format, wich is past through in the JSON code from the slave to master duino??
              • AWIA AWI
                MarkV
                @AWI
                How is it that i get the readings like above? And after a while the sensor also stops with sending data, last connection stays on that time and date.
                I've uploaded your github sketch and done a serial readout of the measuring arduino and that one functions proberbly. No faulty low voltage errors etc.
                • M MarkV
                  @AWI
                  AWIA
                  AWIA
                  AWI
                  @MarkV Ok, one step at a time.. the output looks like the output of your (serial) gateway. Have you tried to switch on the "Master node" debug Serial.print() statements?
                  • AWIA AWI
                    MarkV
                    @AWI
                    It the serial output from the gateway arduino, wich i've got connected through usb.
                    I don't have a rotaryswitch connected and yesterday evening i connected a I2c Display just to see if something changes on that.
                    I noticed one thin, when i check the serial output, the timer on the display is reset. Further more when i stop the serial readout, the counter also stops, like if the hole thing go's into a idle or stop.
                    I've uncommented the debug informatie wich i could find:
                    // Handle incoming messages from the MySensors Gateway
                    void receive(const MyMessage &message) {  // Expect few types of messages from controller, V_VAR1 for messages
                      if (message.type==V_TEXT) {
                        // if message comes in, update the kWH reading for meter with value since last update
                        Serial.print("Last reading for sensor: ");
                        Serial.print(", Message: ");
                        if (message.sensor == LCD1_CHILD ) {
                          strcpy(lastLCD1, message.getString());  // read payload in LCD string
                    Were could i read this debug information?
                    At this moment i got my arduino hooked up through usb to my rasberry to see if it keeps sending information.
                    I also changed all the cables to the meters.
                    This is how one meter looks like:
                    0_1462289685255_upload-a785d675-02ea-45c7-9888-2616d6a5c4f4
                    And a other one:
                    0_1462289751196_upload-ac4e8673-e392-43ac-aeea-1be31416479a
                    All the meters are showing also strange values on the axis.
                    Sorry for being such a noob at this.. :-S
                    • M MarkV
                      @AWI
                      And a other one:
                      AWIA
                      AWIA
                      AWI
                      @MarkV Hi Mark It is a rather complicated sketch, so not easy to debug remote.
                      You need to connect the master arduino to your USB and check with the serial monitor.
                      then add some Serial.print() statements starting form where the data is read.
                      The piece you commented out is where the node should receive information from the controller. I expect you didn't come far enough to set that up.
                      (as I noticed you are Dutch, we can use the chat function on the forum to get this working...please don't expect immediate answers..)
                      • AWIA AWI
                        MarkV
                        @AWI
                        Goodevening
                        Oh better, we definitie have to de that. When does it suit you?
                        Grtz
