  3. Power/ Usage sensor - multi channel - local display
41 Posts 6 Posters 24.8k Views 7 Watching
  • J jeti
    @AWI: :smiley: nevermind I will start workin on it
    Thanks again for the great work!
    J
    J
    jeti
    wrote on last edited by jeti
    #26
    was not that much work :smiley:
    this is the modified master-sketch from AWI i am starting to use. The changes i made:
    -deletion of LCD and rotray part
    -deletion of accumulation part
    -modified meterType to meter800, meter1000 and meter2000 this reflects meters with 800imp/khw;1000imp/kwh;2000imp/kwh
    I am using this with only one meter (2000imp/kwh) for now and works pretty nicly second different meter type is on the way.
    As I am a beginner please be gentle with comments :-)
    #include <MySensor.h>                   // MySensors network
    #include <Time.h>
    #include <ArduinoJson.h>                // used to parse the simple JSON output of the pulse meter https://github.com/bblanchon/ArduinoJson
    // Constants & globals
    const int NO_METERS = 1 ;               // actual meters used (max 12)
    const int NODE_ID = 152 ;                // fixed MySensors node ID
    const int JSON_LENGHT = 80 ;            // Maximum json string length
    // new V_TEXT variable type (development 20150905)
    const int V_TEXT = 47 ;
    // new S_INFO sensor type (development 20150905)
    const int S_INFO = 36 ;
    char lastLCD1[21] = "--                  "; // LCD message line
    typedef enum meterTypes: int8_t {meter800, meter1000, meter2000} ;             // metertype meter800, meter1000, meter2000;
    const char METER_NAMES[NO_METERS][4] = {"PC"} ; // meter names
    const meterTypes METER_TYPES[NO_METERS] = {meter2000};
    const unsigned long idleTime = 10000 ;  // Delay time for any of the states to return to idle
    unsigned long idleTimer ;               // Delay timer for idleTime
    union {                                 // used to convert long to bytes for EEPROM storage
        long kWhLongInt;
        uint8_t kWhLongByte[4];
        } kWhLong ;
    // Possible states for the state machine.
    // Idle: default state, show totals for in/out nett
    // Browse: dive into meter details
    // Update: update meter value (Wh total)
    // Reset: reset day values
    enum States: int8_t {IDLE, BROWSE, UPDATE, RST} ;
    uint8_t State = IDLE;                   // current state machine state
    // meter class, store all relevant meter data (equivalent to struct)
    class pulseMeter
    public:
        long UsageWh;                       // last (current) usage (in W) from pulse counter
        long UsageAccumWh;                  // usage accumulator (to keep in sync) from pulse counter
        long PowerW;                        // actual power, calculated from pulse "rate"
        long DayUsageWh;                    // daily usage for display
        meterTypes Type;                    // metertype for addition in totals: meter800, meter1000, meter2000;
        char Name[4] ;                      // meter name for display
    pulseMeter pulseMeters[NO_METERS] ;     // define power meters
    //pulseMeter meter800, meter1000, meter2000; //  pulse/kWh
    unsigned long tempUsageWh ;             // temporary store while manually updating (state UPDATE)
    // Json parser:  define parse object: <10> = number of tokens in JSON: ~10 per m (4 * [key, value] + key_total, value_total))
    // example: "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}"
    char json[JSON_LENGHT] ;        // Storage for serial JSON string (init for example)
    // flags & counters
    bool timeReceived = false;              // controller time
    bool newDay = false;                    // reset at 00:00:00
    unsigned long lastUpdate=0, lastRequest=0, lastDisplay=0, lastSyncKWH=0;  // loop timers for once in while events
    int updateMeter = 0;                    // current meter for update
    bool updateDisplayFlag = true ;         // indicate that display needs to be updated
    int currentMeter = 0;                   // active meter for update & check, cycles through meters (0..NO_METERS-1)
    int lastRotary = 0;                     // last rotary encoder position
    int updateIncrement = 1000 ;            // Interval multiplier for Update
    int errCount = 0 ;                      // error counter
    // *** Definition and initialisation
    // define the MySensor network
    MySensor gw;                            // pins used RFX24(default 9,10)
    // Initialize messages for sensor network
    MyMessage powerMsg(0,V_WATT);           // message to send power in W
    MyMessage usageMsg(0,V_KWH);            // message to send usage in kWH
    MyMessage textMsg(0,V_TEXT);            // message to send/receive text
    // function to reset the Arduino (jump to 0 address)
    void(* resetFunc) (void) = 0;//declare reset function at address 0
    void setup(void)
        gw.begin(incomingMessage, NODE_ID, false);              // this node is fixed, no repeat
        //Send the sensor node sketch version information to the gateway
        gw.sendSketchInfo("AWI-12ChannelPulse", "2.0");
        // Initialize the meter names
        // Register all Pulse counters to gw (they will be created as child devices from 0 to MAX-1)
        for (int x = 0; x < NO_METERS; x++){
            gw.present(x, S_POWER, METER_NAMES[x]);             // present power meters to gateway
            delay(10);                                          // give it some time to process
        delay(100);
        for (int x = 0; x < NO_METERS; x++){                    // initialize previous kWh values from EEPROM and init
            for (int y = 0; y < 4 ; y++){                       // convert from bytes
                kWhLong.kWhLongByte[y]= gw.loadState(x *4 + y) ;// EEPROM position = meter number * 4 bytes
                }                                               // controller is updated later automatically
            pulseMeters[x].UsageWh = kWhLong.kWhLongInt;
            strcpy(pulseMeters[x].Name, METER_NAMES[x] );       // copy string for meter names
            pulseMeters[x].Type = METER_TYPES[x];               // Set type
    void loop(void)
        // Before specific states, perform generic tasks
        unsigned long now = millis();                           // Timer in loop for "once in a while" events
        gw.process() ;                                          // process incoming messages
        // If no time has been received yet, request it every 10 second from controller
        if ((!timeReceived && (now-lastRequest > 10*1000)) ||
            (now-lastRequest > 3600000UL)){                     // request update every hour to keep in sync
            Serial.println(F("requesting time"));               // Request time from controller.
            gw.requestTime(receiveTime);
            lastRequest = now;
        // Check if new day has started (hour == 0) and reset day usage counters of meters
        if (hour()==0 && !newDay){
            newDay = true;
                pulseMeters[x].DayUsageWh = 0 ;                 // reset daily counters
                saveMeters(x);                                  // save meter values to EEPROM
        } else if(hour() != 0 && newDay)                        // reset newday flag if hour != 0
            { newDay = false;}
        // Every 10 seconds update one meter to controller to avoid traffic jams
        if (now-lastSyncKWH > 10000){
        //    printPulsemeter(updateMeter);
            sendPowerUpdate(updateMeter);                               // update the values for currentMeter
            updateMeter++ ;
            if (updateMeter >= NO_METERS){                              // increment and wrap current meter
                updateMeter = 0 ;}
            lastSyncKWH = now ;
        // Update sensors every 10 secs
        if (now-lastUpdate > 10000) {
            // get values to be displayed from controller
            lastUpdate = now;
        // get readings from serial (sent every 10s)
        // format {"m":meter,"c":count,"r":rate, "cA":countAccum}
        // use JSON parser to process (could be replaced by simple split routine, but this works just fine)
        if(readLineJSON(Serial.read(), json, JSON_LENGHT) > 0 ){        //dummySerial(), Serial.read()
        // if(readLineJSON(dummySerial(), json, 80) > 0 ){              //dummySerial(), Serial.read()
            Serial.println(json);
            storeMeterJSON(json);                                       //store the meter reading
            //calcMeterTotals();                                          // update totals
        // Ok, set incoming time
        Serial.print(F("Time value received: "));
        setTime(controllerTime);                                        // set the clock to the time from controller
        timeReceived = true ;
    // This is called when a message is received
      // Expect few types of messages from controller, V_VAR1 for messages
        if (message.type==V_TEXT) {
            // if message comes in, update the kWH reading for meter with value since last update
            //Serial.print("Last reading for sensor: ");
            //Serial.print(message.sensor);
            //Serial.print(", Message: ");
            //Serial.println(message.getString());
    // save Meter to EEPROM when needed
    void saveMeters(int8_t meterNo){
        kWhLong.kWhLongInt = pulseMeters[meterNo].UsageWh ;                     // convert to separate bytes via struct
            gw.saveState(meterNo * 4 + y, kWhLong.kWhLongByte[y])  ;            // EEPROM position = meter number * 4 bytes
    void sendPowerUpdate(int meterNo)
    // Sends update to controller for current meter
        gw.send(powerMsg.setSensor(meterNo).set((long)pulseMeters[meterNo].PowerW));            // meterNo * 100 ));
        gw.send(usageMsg.setSensor(meterNo).set((float)pulseMeters[meterNo].UsageWh/1000L ,3)); // send in kWh!
    int storeMeterJSON(char *json)
    /* convert JSON to values and store in corresponding meter (if used)
     input: JSON string (can be wrong formatted), with length
     output: changed meter record number or -1 if error
     use JsonParser
      StaticJsonBuffer<50> jsonBuffer;                          // 4 object  -> 4 + 4*10 = 44
      // char njson[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}";
        JsonObject& root = jsonBuffer.parseObject(json);
      if (!root.success())
            Serial.println(F("JsonParser.parse() failed"));
            errCount++ ;
            return -1;
      int m = (long)root["m"];
      if (m > NO_METERS){                                       // meter value out of range for used meters (m starts at 1)
        return -1 ;
      } else {                                                  // update meter values, Power is momentary, Usage is cumulative
        long newAccumWh = (long)root["cA"] ;
        long newWh = (long)root["c"] ;
        long diffAccumWh = newAccumWh - pulseMeters[m-1].UsageAccumWh;  // check for missed pulses by comparing cA with last stored value
        if (diffAccumWh >= newWh){                              // no difference or missed pulses -> correct: add difference
            pulseMeters[m-1].UsageWh += diffAccumWh;
            pulseMeters[m-1].DayUsageWh += diffAccumWh;
        else {                                                  // negative diff, out of sync -> add pulses only (can be out of range or restart)
            pulseMeters[m-1].UsageWh += newWh;
            pulseMeters[m-1].DayUsageWh += newWh;
        pulseMeters[m-1].UsageAccumWh = newAccumWh;             // always update sync counter (only for sync and error correction(serial))
        if ((long)root["r"] == 0){                              // calculate power from pulse rate (ms) and truncate to whole Watts
          pulseMeters[m-1].PowerW = 0;                          // if overflow assume no Usage
        } else if (pulseMeters[m-1].Type == meter800){
          pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]*0.8); // rate in microseconds for 800 pulse/kWh
          else if (pulseMeters[m-1].Type == meter1000){
          pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]); // rate in microseconds for 1000 pulse/kWh
           else if (pulseMeters[m-1].Type == meter2000){
           pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]/2); // rate in microseconds for 2000 pulse/kWh
          else {
            Serial.println("geht nicht");
        return m ;
    int readLineJSON(int readch, char *buffer, int len)
    /* checks for JSON and when started append char tot buffer and checks for line completion
    usage:
      static char buffer[80];
      if (readline(Serial.read(), buffer, 80) > 0) { // line complete}
      returns simple JSON
      static int pos = 0;
      int rpos;
      if (readch > 0) {
        switch (readch) {
          case '\n':                // Ignore new-lines
          case '\r':                // Return on CR
            rpos = pos;
            pos = 0;                  // Reset position index ready for next time
            return rpos;
          default:
            if (pos < len-1) {
              buffer[pos++] = readch;
              buffer[pos] = 0;
      // No end of line has been found, so return -1.
      return -1;
    int dummySerial()
    // Acts as a dummy JSON serial character generator for debugging
    // input: none
    // output: preset JSON string
      static int pos = 0;
      char json[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}\r{\"m\":2,\"c\":212,\"r\":2120000,\"cA\":212345}\r{\"m\":3,\"c\":212,\"r\":2120000,\"cA\":212345}\n\r";
      if (pos++ >= strlen(json)){
        pos = 0;
      return json[pos] ;
    void printPulsemeter(int meter)
    // prints the Pulsemeter record to serial out
      Serial.print("m:");
      Serial.print(meter);
      Serial.print("type:");
      Serial.print(pulseMeters[meter].Type);
      Serial.print(", power: ");
      Serial.print(pulseMeters[meter].PowerW);
      Serial.print(", usage: ");
      Serial.print(pulseMeters[meter].UsageWh);
      Serial.print(", day usage: ");
      Serial.println(pulseMeters[meter].DayUsageWh );
    //  Serial.print(", Ca: ");
    //  Serial.println(pulseMeters[meter].UsageAccumWh);
      MarkV
      Good evening,
      After a couple of weeks, again i'm busy with my arduino's, but now i have a rasberry with domoticz near my arduino, so i don't need to send it wireless.
      Is there a possibility to connect the master or slave arduino directly to my rasberry and read out the pulse meters???
      • mfalkviddM
        With MySensors version 1.6 (currently in development) you can connect the Arduino to the Raspberry Pi's USB port using a FTDI or CH340G. That type of connection is called a serial gateway. Before 1.6, the gateways do not support local sensors.
          MarkV
          wrote on last edited by MarkV
          #29
          So with 1.6 i can install the master software and connect my arduino master directly through usb without the rf24''s? ?
          • mfalkviddM
            I am not entirely sure what a master is, but yes, I think you can.
              MarkV
              #31
              I meen the master sketch like written above.
              I'd want to build a gateway but without the wireless RF part, just connect the master arduino directly through usb to the RasberryPi and readout the measurements.
              So in general:
              Kwh Meters -- cable --> Slave arduino <-- serial --> Master arduino <-- USB --> RasberryPi
              AWIA 1 Reply Last reply
              • M MarkV
                So in general:
                AWIA
                AWIA
                AWI
                @MarkV If you don't want it to be MySensors enabled and not used the display etc. it's easier to readout the slave with the raspberry. The protocol is a simple Json and if you use a nano for the slave you can connect it with usb..
                  MarkV
                  #33
                  Last weeks i'm trying to get it to work but without luck. Could you give a manual on how to get it working with json? What should we do? And how? On my rasberry, on the arduino and in domoticz??
                  • AWIA AWI
                    @FotoFieber To be honest .. a left over from some experiments. Just leave it out... you won't notice the difference.
                    MarkV
                    #34
                    @AWI
                    Goodmorning,
                    I've got a question, are you planning to re-write the script for the main and slave Arduino to the new MySensors 2.0 structuur?
                    I've also tryed to look on github if there's a page from you, but didn't find it...
                    • M MarkV
                      @AWI
                      Goodmorning,
                      AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      #35
                      @MarkV I updated the sketch for main a few months ago to development (pre-2.0). Also changed it a little for stability and removed the (complicated) JSON library The slave has no MySensors dependency.
                        MarkV
                        Super.
                        I've updated everything and it's up and running.
                        But my Master arduino (UNO clone) gives this readout on the USB port:
                        0;255;3;0;11;AWI-12ChannelPulse
                        0;255;3;0;12;2.0
                        0;0;0;0;13;Groep 1
                        0;1;0;0;13;Groep 2
                        0;2;0;0;13;Groep 3
                        0;3;0;0;13;Groep 4
                        0;4;0;0;13;Groep 5
                        0;5;0;0;13;Groep 6
                        0;20;0;0;36;Usage meter LCD
                        0;20;1;0;47;-
                        0;255;3;0;1;
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;20;2;0;47;
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;20;2;0;47;
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;20;2;0;47;
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;20;2;0;47;
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;20;2;0;47;
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;20;2;0;47;
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;20;2;0;47;
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;20;2;0;47;
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;20;2;0;47;
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;20;2;0;47;
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;20;2;0;47;
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        0;255;3;0;1;
                        0;1;1;0;17;0
                        0;1;1;0;18;-0.001
                        0;255;3;0;1;
                        0;2;1;0;17;0
                        0;2;1;0;18;-0.001
                        0;255;3;0;1;
                        0;3;1;0;17;0
                        0;3;1;0;18;-0.001
                        0;255;3;0;1;
                        0;4;1;0;17;0
                        0;4;1;0;18;-0.001
                        0;20;2;0;47;
                        0;255;3;0;1;
                        0;5;1;0;17;0
                        0;5;1;0;18;-0.001
                        0;255;3;0;1;
                        0;0;1;0;17;0
                        0;0;1;0;18;-0.001
                        Is this correct?
                        Because Domoticz doesn't change the values.
                        Also this is not the format, wich is past through in the JSON code from the slave to master duino??
                        • AWIA AWI
                          MarkV
                          @AWI
                          How is it that i get the readings like above? And after a while the sensor also stops with sending data, last connection stays on that time and date.
                          I've uploaded your github sketch and done a serial readout of the measuring arduino and that one functions proberbly. No faulty low voltage errors etc.
                          • M MarkV
                            @AWI
                            AWIA
                            AWIA
                            AWI
                            @MarkV Ok, one step at a time.. the output looks like the output of your (serial) gateway. Have you tried to switch on the "Master node" debug Serial.print() statements?
                            • AWIA AWI
                              MarkV
                              @AWI
                              It the serial output from the gateway arduino, wich i've got connected through usb.
                              I don't have a rotaryswitch connected and yesterday evening i connected a I2c Display just to see if something changes on that.
                              I noticed one thin, when i check the serial output, the timer on the display is reset. Further more when i stop the serial readout, the counter also stops, like if the hole thing go's into a idle or stop.
                              I've uncommented the debug informatie wich i could find:
                              // Handle incoming messages from the MySensors Gateway
                              void receive(const MyMessage &message) {  // Expect few types of messages from controller, V_VAR1 for messages
                                  if (message.sensor == LCD1_CHILD ) {
                                    strcpy(lastLCD1, message.getString());  // read payload in LCD string
                              Were could i read this debug information?
                              At this moment i got my arduino hooked up through usb to my rasberry to see if it keeps sending information.
                              I also changed all the cables to the meters.
                              This is how one meter looks like:
                              0_1462289685255_upload-a785d675-02ea-45c7-9888-2616d6a5c4f4
                              And a other one:
                              0_1462289751196_upload-ac4e8673-e392-43ac-aeea-1be31416479a
                              All the meters are showing also strange values on the axis.
                              Sorry for being such a noob at this.. :-S
                              • M MarkV
                                @AWI
                                And a other one:
                                AWIA
                                AWIA
                                AWI
                                @MarkV Hi Mark It is a rather complicated sketch, so not easy to debug remote.
                                You need to connect the master arduino to your USB and check with the serial monitor.
                                then add some Serial.print() statements starting form where the data is read.
                                The piece you commented out is where the node should receive information from the controller. I expect you didn't come far enough to set that up.
                                (as I noticed you are Dutch, we can use the chat function on the forum to get this working...please don't expect immediate answers..)
                                • AWIA AWI
                                  MarkV
                                  @AWI
                                  Goodevening
                                  Oh better, we definitie have to de that. When does it suit you?
                                  Grtz
