  3. Power/ Usage sensor - multi channel - local display
41 Posts 6 Posters 24.8k Views 7 Watching
  • M marten
    Arduino: 1.6.5 (Windows 7), Board:"Arduino Nano, ATmega328"
    sketch_oct03e:128: error: 'V_TEXT' was not declared in this scope
    sketch_oct03e.ino: In function 'void setup()':
    sketch_oct03e:162: error: 'S_INFO' was not declared in this scope
    sketch_oct03e.ino: In function 'void loop()':
    sketch_oct03e:337: error: 'V_TEXT' was not declared in this scope
    sketch_oct03e.ino: In function 'void incomingMessage(const MyMessage&)':
    sketch_oct03e:364: error: 'V_TEXT' was not declared in this scope
    Dit rapport zou meer informatie hebben met
    "Tijdens de compilatie uitgebreide uitvoer weergeven"
    ingeschakeld in Bestand > Voorkeuren.
    AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    #22
    @marten You need to use the "Development" branch of MySensors until the production version gets updated -or- you can uncomment the lines with "const int ..."
    // new V_TEXT variable type (development 20150905)
    //const int V_TEXT = 47 ;
    // new S_INFO sensor type (development 20150905)
    //const int S_INFO = 36 ;
    • J
      J
      jeti
      • J jeti
        @AWI thanks again!
        I am using your sketches with only one S0 Meter (the 2000pulse/kwh one).
        *One thing i just found out, that as long as the master arduino is connected to the serial port of my pc it is running fine but when its not, it does not send.I have checked the voltage at the radio and it is the same... I also do not have any display or rotary encoder, as I do the visualisation with FHEM.
        Do you know why this is the case? * -> Voltage was to low... but the secon question remains:
        Any idea to use differen pulses/kwh S0 meters? for example one 2000pulse/kwh and one 800 pulse/kwh.
        thanks in advance!
        AWIA
        AWIA
        AWI
        @jeti as mentioned in a previous post..
        There are a few ways of getting it changed:
        You can keep/ leave most as it is and when you send/ or display the values divide the pulses by two and double the Watt values in the routines "LCD_local_display" and "sendPowerUpdate"
        or: make the necessary calculations when the data comes in. This is a little more complicated in routine "storeMeterJSON" but if you understand the logic (including error corrrection) should be not too hard.
        I don't have the time at this moment to do it for you...
        J 1 Reply Last reply
        • AWIA AWI
          J
          J
          jeti
          @AWI: :smiley: nevermind I will start workin on it
          Thanks again for the great work!
          • J jeti
            J
            J
            jeti
            wrote on last edited by jeti
            #26
            was not that much work :smiley:
            this is the modified master-sketch from AWI i am starting to use. The changes i made:
            -deletion of LCD and rotray part
            -deletion of accumulation part
            -modified meterType to meter800, meter1000 and meter2000 this reflects meters with 800imp/khw;1000imp/kwh;2000imp/kwh
            I am using this with only one meter (2000imp/kwh) for now and works pretty nicly second different meter type is on the way.
            As I am a beginner please be gentle with comments :-)
            #include <MySensor.h>                   // MySensors network
            #include <Time.h>
            #include <ArduinoJson.h>                // used to parse the simple JSON output of the pulse meter https://github.com/bblanchon/ArduinoJson
            // Constants & globals
            const int NO_METERS = 1 ;               // actual meters used (max 12)
            const int NODE_ID = 152 ;                // fixed MySensors node ID
            const int JSON_LENGHT = 80 ;            // Maximum json string length
            char lastLCD1[21] = "--                  "; // LCD message line
            typedef enum meterTypes: int8_t {meter800, meter1000, meter2000} ;             // metertype meter800, meter1000, meter2000;
            const char METER_NAMES[NO_METERS][4] = {"PC"} ; // meter names
            const meterTypes METER_TYPES[NO_METERS] = {meter2000};
            const unsigned long idleTime = 10000 ;  // Delay time for any of the states to return to idle
            unsigned long idleTimer ;               // Delay timer for idleTime
            union {                                 // used to convert long to bytes for EEPROM storage
                long kWhLongInt;
                uint8_t kWhLongByte[4];
                } kWhLong ;
            // Possible states for the state machine.
            // Idle: default state, show totals for in/out nett
            // Browse: dive into meter details
            // Update: update meter value (Wh total)
            // Reset: reset day values
            enum States: int8_t {IDLE, BROWSE, UPDATE, RST} ;
            uint8_t State = IDLE;                   // current state machine state
            // meter class, store all relevant meter data (equivalent to struct)
            class pulseMeter
            public:
                long UsageWh;                       // last (current) usage (in W) from pulse counter
                long UsageAccumWh;                  // usage accumulator (to keep in sync) from pulse counter
                long PowerW;                        // actual power, calculated from pulse "rate"
                long DayUsageWh;                    // daily usage for display
                meterTypes Type;                    // metertype for addition in totals: meter800, meter1000, meter2000;
                char Name[4] ;                      // meter name for display
            pulseMeter pulseMeters[NO_METERS] ;     // define power meters
            //pulseMeter meter800, meter1000, meter2000; //  pulse/kWh
            unsigned long tempUsageWh ;             // temporary store while manually updating (state UPDATE)
            // Json parser:  define parse object: <10> = number of tokens in JSON: ~10 per m (4 * [key, value] + key_total, value_total))
            // example: "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}"
            char json[JSON_LENGHT] ;        // Storage for serial JSON string (init for example)
            // flags & counters
            bool timeReceived = false;              // controller time
            bool newDay = false;                    // reset at 00:00:00
            unsigned long lastUpdate=0, lastRequest=0, lastDisplay=0, lastSyncKWH=0;  // loop timers for once in while events
            int updateMeter = 0;                    // current meter for update
            bool updateDisplayFlag = true ;         // indicate that display needs to be updated
            int currentMeter = 0;                   // active meter for update & check, cycles through meters (0..NO_METERS-1)
            int lastRotary = 0;                     // last rotary encoder position
            int updateIncrement = 1000 ;            // Interval multiplier for Update
            int errCount = 0 ;                      // error counter
            // *** Definition and initialisation
            // define the MySensor network
            MySensor gw;                            // pins used RFX24(default 9,10)
            // Initialize messages for sensor network
            MyMessage powerMsg(0,V_WATT);           // message to send power in W
            MyMessage usageMsg(0,V_KWH);            // message to send usage in kWH
            MyMessage textMsg(0,V_TEXT);            // message to send/receive text
            // function to reset the Arduino (jump to 0 address)
            void(* resetFunc) (void) = 0;//declare reset function at address 0
            void setup(void)
                gw.begin(incomingMessage, NODE_ID, false);              // this node is fixed, no repeat
                //Send the sensor node sketch version information to the gateway
                gw.sendSketchInfo("AWI-12ChannelPulse", "2.0");
                // Initialize the meter names
                // Register all Pulse counters to gw (they will be created as child devices from 0 to MAX-1)
                for (int x = 0; x < NO_METERS; x++){
                    gw.present(x, S_POWER, METER_NAMES[x]);             // present power meters to gateway
                    delay(10);                                          // give it some time to process
                delay(100);
                for (int x = 0; x < NO_METERS; x++){                    // initialize previous kWh values from EEPROM and init
                    for (int y = 0; y < 4 ; y++){                       // convert from bytes
                        kWhLong.kWhLongByte[y]= gw.loadState(x *4 + y) ;// EEPROM position = meter number * 4 bytes
                        }                                               // controller is updated later automatically
                    pulseMeters[x].UsageWh = kWhLong.kWhLongInt;
                    strcpy(pulseMeters[x].Name, METER_NAMES[x] );       // copy string for meter names
                    pulseMeters[x].Type = METER_TYPES[x];               // Set type
            void loop(void)
                // Before specific states, perform generic tasks
                unsigned long now = millis();                           // Timer in loop for "once in a while" events
                gw.process() ;                                          // process incoming messages
                // If no time has been received yet, request it every 10 second from controller
                if ((!timeReceived && (now-lastRequest > 10*1000)) ||
                    (now-lastRequest > 3600000UL)){                     // request update every hour to keep in sync
                    Serial.println(F("requesting time"));               // Request time from controller.
                    gw.requestTime(receiveTime);
                    lastRequest = now;
                // Check if new day has started (hour == 0) and reset day usage counters of meters
                if (hour()==0 && !newDay){
                    newDay = true;
                        pulseMeters[x].DayUsageWh = 0 ;                 // reset daily counters
                        saveMeters(x);                                  // save meter values to EEPROM
                } else if(hour() != 0 && newDay)                        // reset newday flag if hour != 0
                    { newDay = false;}
                // Every 10 seconds update one meter to controller to avoid traffic jams
                if (now-lastSyncKWH > 10000){
                //    printPulsemeter(updateMeter);
                    sendPowerUpdate(updateMeter);                               // update the values for currentMeter
                    updateMeter++ ;
                    if (updateMeter >= NO_METERS){                              // increment and wrap current meter
                        updateMeter = 0 ;}
                    lastSyncKWH = now ;
                // Update sensors every 10 secs
                if (now-lastUpdate > 10000) {
                    // get values to be displayed from controller
                    lastUpdate = now;
                // get readings from serial (sent every 10s)
                // format {"m":meter,"c":count,"r":rate, "cA":countAccum}
                // use JSON parser to process (could be replaced by simple split routine, but this works just fine)
                if(readLineJSON(Serial.read(), json, JSON_LENGHT) > 0 ){        //dummySerial(), Serial.read()
                // if(readLineJSON(dummySerial(), json, 80) > 0 ){              //dummySerial(), Serial.read()
                    Serial.println(json);
                    storeMeterJSON(json);                                       //store the meter reading
                    //calcMeterTotals();                                          // update totals
                // Ok, set incoming time
                Serial.print(F("Time value received: "));
                setTime(controllerTime);                                        // set the clock to the time from controller
                timeReceived = true ;
            // This is called when a message is received
              // Expect few types of messages from controller, V_VAR1 for messages
                if (message.type==V_TEXT) {
                    // if message comes in, update the kWH reading for meter with value since last update
                    //Serial.print("Last reading for sensor: ");
                    //Serial.print(message.sensor);
                    //Serial.print(", Message: ");
                    //Serial.println(message.getString());
            // save Meter to EEPROM when needed
            void saveMeters(int8_t meterNo){
                kWhLong.kWhLongInt = pulseMeters[meterNo].UsageWh ;                     // convert to separate bytes via struct
                    gw.saveState(meterNo * 4 + y, kWhLong.kWhLongByte[y])  ;            // EEPROM position = meter number * 4 bytes
            void sendPowerUpdate(int meterNo)
            // Sends update to controller for current meter
                gw.send(powerMsg.setSensor(meterNo).set((long)pulseMeters[meterNo].PowerW));            // meterNo * 100 ));
                gw.send(usageMsg.setSensor(meterNo).set((float)pulseMeters[meterNo].UsageWh/1000L ,3)); // send in kWh!
            int storeMeterJSON(char *json)
            /* convert JSON to values and store in corresponding meter (if used)
             input: JSON string (can be wrong formatted), with length
             output: changed meter record number or -1 if error
             use JsonParser
              StaticJsonBuffer<50> jsonBuffer;                          // 4 object  -> 4 + 4*10 = 44
              // char njson[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}";
                JsonObject& root = jsonBuffer.parseObject(json);
              if (!root.success())
                    Serial.println(F("JsonParser.parse() failed"));
                    errCount++ ;
                    return -1;
              int m = (long)root["m"];
              if (m > NO_METERS){                                       // meter value out of range for used meters (m starts at 1)
                return -1 ;
              } else {                                                  // update meter values, Power is momentary, Usage is cumulative
                long newAccumWh = (long)root["cA"] ;
                long newWh = (long)root["c"] ;
                long diffAccumWh = newAccumWh - pulseMeters[m-1].UsageAccumWh;  // check for missed pulses by comparing cA with last stored value
                if (diffAccumWh >= newWh){                              // no difference or missed pulses -> correct: add difference
                    pulseMeters[m-1].UsageWh += diffAccumWh;
                    pulseMeters[m-1].DayUsageWh += diffAccumWh;
                else {                                                  // negative diff, out of sync -> add pulses only (can be out of range or restart)
                    pulseMeters[m-1].UsageWh += newWh;
                    pulseMeters[m-1].DayUsageWh += newWh;
                pulseMeters[m-1].UsageAccumWh = newAccumWh;             // always update sync counter (only for sync and error correction(serial))
                if ((long)root["r"] == 0){                              // calculate power from pulse rate (ms) and truncate to whole Watts
                  pulseMeters[m-1].PowerW = 0;                          // if overflow assume no Usage
                } else if (pulseMeters[m-1].Type == meter800){
                  pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]*0.8); // rate in microseconds for 800 pulse/kWh
                  else if (pulseMeters[m-1].Type == meter1000){
                  pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]); // rate in microseconds for 1000 pulse/kWh
                   else if (pulseMeters[m-1].Type == meter2000){
                   pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]/2); // rate in microseconds for 2000 pulse/kWh
                  else {
                    Serial.println("geht nicht");
                return m ;
            int readLineJSON(int readch, char *buffer, int len)
            /* checks for JSON and when started append char tot buffer and checks for line completion
            usage:
              static char buffer[80];
              if (readline(Serial.read(), buffer, 80) > 0) { // line complete}
              returns simple JSON
              static int pos = 0;
              int rpos;
              if (readch > 0) {
                switch (readch) {
                  case '\n':                // Ignore new-lines
                  case '\r':                // Return on CR
                    rpos = pos;
                    pos = 0;                  // Reset position index ready for next time
                    return rpos;
                  default:
                    if (pos < len-1) {
                      buffer[pos++] = readch;
                      buffer[pos] = 0;
              // No end of line has been found, so return -1.
              return -1;
            int dummySerial()
            // Acts as a dummy JSON serial character generator for debugging
            // input: none
            // output: preset JSON string
              static int pos = 0;
              char json[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}\r{\"m\":2,\"c\":212,\"r\":2120000,\"cA\":212345}\r{\"m\":3,\"c\":212,\"r\":2120000,\"cA\":212345}\n\r";
              if (pos++ >= strlen(json)){
                pos = 0;
              return json[pos] ;
            void printPulsemeter(int meter)
            // prints the Pulsemeter record to serial out
              Serial.print("m:");
              Serial.print(meter);
              Serial.print("type:");
              Serial.print(pulseMeters[meter].Type);
              Serial.print(", power: ");
              Serial.print(pulseMeters[meter].PowerW);
              Serial.print(", usage: ");
              Serial.print(pulseMeters[meter].UsageWh);
              Serial.print(", day usage: ");
              Serial.println(pulseMeters[meter].DayUsageWh );
            //  Serial.print(", Ca: ");
            //  Serial.println(pulseMeters[meter].UsageAccumWh);
              MarkV
              Good evening,
              After a couple of weeks, again i'm busy with my arduino's, but now i have a rasberry with domoticz near my arduino, so i don't need to send it wireless.
              Is there a possibility to connect the master or slave arduino directly to my rasberry and read out the pulse meters???
              • mfalkviddM
                With MySensors version 1.6 (currently in development) you can connect the Arduino to the Raspberry Pi's USB port using a FTDI or CH340G. That type of connection is called a serial gateway. Before 1.6, the gateways do not support local sensors.
                  MarkV
                  wrote on last edited by MarkV
                  #29
                  So with 1.6 i can install the master software and connect my arduino master directly through usb without the rf24''s? ?
                  • mfalkviddM
                    I am not entirely sure what a master is, but yes, I think you can.
                      MarkV
                      #31
                      I meen the master sketch like written above.
                      I'd want to build a gateway but without the wireless RF part, just connect the master arduino directly through usb to the RasberryPi and readout the measurements.
                      So in general:
                      Kwh Meters -- cable --> Slave arduino <-- serial --> Master arduino <-- USB --> RasberryPi
                      AWIA 1 Reply Last reply
                      • M MarkV
                        So in general:
                        AWIA
                        AWIA
                        AWI
                        @MarkV If you don't want it to be MySensors enabled and not used the display etc. it's easier to readout the slave with the raspberry. The protocol is a simple Json and if you use a nano for the slave you can connect it with usb..
                          MarkV
                          #33
                          Last weeks i'm trying to get it to work but without luck. Could you give a manual on how to get it working with json? What should we do? And how? On my rasberry, on the arduino and in domoticz??
                          • AWIA AWI
                            @FotoFieber To be honest .. a left over from some experiments. Just leave it out... you won't notice the difference.
                            MarkV
                            #34
                            @AWI
                            Goodmorning,
                            I've got a question, are you planning to re-write the script for the main and slave Arduino to the new MySensors 2.0 structuur?
                            I've also tryed to look on github if there's a page from you, but didn't find it...
                            • M MarkV
                              @AWI
                              Goodmorning,
                              AWIA
                              AWIA
                              AWI
                              #35
                              @MarkV I updated the sketch for main a few months ago to development (pre-2.0). Also changed it a little for stability and removed the (complicated) JSON library The slave has no MySensors dependency.
                                MarkV
                                Super.
                                I've updated everything and it's up and running.
                                But my Master arduino (UNO clone) gives this readout on the USB port:
                                0;255;3;0;11;AWI-12ChannelPulse
                                0;255;3;0;12;2.0
                                0;0;0;0;13;Groep 1
                                0;1;0;0;13;Groep 2
                                0;2;0;0;13;Groep 3
                                0;3;0;0;13;Groep 4
                                0;4;0;0;13;Groep 5
                                0;5;0;0;13;Groep 6
                                0;20;0;0;36;Usage meter LCD
                                0;20;1;0;47;-
                                0;255;3;0;1;
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;20;2;0;47;
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;20;2;0;47;
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;20;2;0;47;
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;20;2;0;47;
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;20;2;0;47;
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;20;2;0;47;
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;20;2;0;47;
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;20;2;0;47;
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;20;2;0;47;
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;20;2;0;47;
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;20;2;0;47;
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                0;255;3;0;1;
                                0;1;1;0;17;0
                                0;1;1;0;18;-0.001
                                0;255;3;0;1;
                                0;2;1;0;17;0
                                0;2;1;0;18;-0.001
                                0;255;3;0;1;
                                0;3;1;0;17;0
                                0;3;1;0;18;-0.001
                                0;255;3;0;1;
                                0;4;1;0;17;0
                                0;4;1;0;18;-0.001
                                0;20;2;0;47;
                                0;255;3;0;1;
                                0;5;1;0;17;0
                                0;5;1;0;18;-0.001
                                0;255;3;0;1;
                                0;0;1;0;17;0
                                0;0;1;0;18;-0.001
                                Is this correct?
                                Because Domoticz doesn't change the values.
                                Also this is not the format, wich is past through in the JSON code from the slave to master duino??
                                • AWIA AWI
                                  MarkV
                                  @AWI
                                  How is it that i get the readings like above? And after a while the sensor also stops with sending data, last connection stays on that time and date.
                                  I've uploaded your github sketch and done a serial readout of the measuring arduino and that one functions proberbly. No faulty low voltage errors etc.
                                  • M MarkV
                                    @AWI
                                    AWIA
                                    AWIA
                                    AWI
                                    @MarkV Ok, one step at a time.. the output looks like the output of your (serial) gateway. Have you tried to switch on the "Master node" debug Serial.print() statements?
                                    • AWIA AWI
                                      MarkV
                                      @AWI
                                      It the serial output from the gateway arduino, wich i've got connected through usb.
                                      I don't have a rotaryswitch connected and yesterday evening i connected a I2c Display just to see if something changes on that.
                                      I noticed one thin, when i check the serial output, the timer on the display is reset. Further more when i stop the serial readout, the counter also stops, like if the hole thing go's into a idle or stop.
                                      I've uncommented the debug informatie wich i could find:
                                      // Handle incoming messages from the MySensors Gateway
                                      void receive(const MyMessage &message) {  // Expect few types of messages from controller, V_VAR1 for messages
                                          if (message.sensor == LCD1_CHILD ) {
                                            strcpy(lastLCD1, message.getString());  // read payload in LCD string
                                      Were could i read this debug information?
                                      At this moment i got my arduino hooked up through usb to my rasberry to see if it keeps sending information.
                                      I also changed all the cables to the meters.
                                      This is how one meter looks like:
                                      0_1462289685255_upload-a785d675-02ea-45c7-9888-2616d6a5c4f4
                                      And a other one:
                                      0_1462289751196_upload-ac4e8673-e392-43ac-aeea-1be31416479a
                                      All the meters are showing also strange values on the axis.
                                      Sorry for being such a noob at this.. :-S
                                      • M MarkV
                                        @AWI
                                        And a other one:
                                        AWIA
                                        AWIA
                                        AWI
                                        @MarkV Hi Mark It is a rather complicated sketch, so not easy to debug remote.
                                        You need to connect the master arduino to your USB and check with the serial monitor.
                                        then add some Serial.print() statements starting form where the data is read.
                                        The piece you commented out is where the node should receive information from the controller. I expect you didn't come far enough to set that up.
                                        (as I noticed you are Dutch, we can use the chat function on the forum to get this working...please don't expect immediate answers..)
                                        • AWIA AWI
                                          MarkV
                                          @AWI
                                          Goodevening
                                          Oh better, we definitie have to de that. When does it suit you?
                                          Grtz
