  3. Which are the *best* NRF24L01+ modules?
310 Posts 42 Posters 345.7k Views 37 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    @nftrix Another way to deal with the fact that some nrf24l01+ modules can not find the gateway, is by reducing the transmit powerlevel. Some of these modules "scream" so loud, that the receiver on the gateway gets a distorted signal and fails to recognise a proper packet.
    In my house I have had to reduce the transmit levels of most of my modules, and as a result they now all connect to the gateway without any caps.
    The NRF24 on the gateway does have a potent powersupply and caps on the board it is mounted on, but my sensornodes do not need it.
    • N
      N
      nftrix
      @samuel235 @GertSanders thanks for the feedback. I'm picking up some caps from the store today and will try them out. As for the power settings, I've been adjusting the data rate settings between 250kbs, 1 and 2Mbps but am seeing the same results. If the caps don't fix the issue, i'll start another thread to work through the problem, don't want to hijack this thread.
      Just wanted to confirm that the findings here did not make the NRF's on the store "not recommended" or anything.
      S 1 Reply Last reply
      • N nftrix
        Samuel235
        Most definitely not. They're more than recommended from most of us i think, from a quick look at the forum topics anyway.
        MySensors 2.1.1
        • GertSandersG
          GertSandersG
          GertSanders
          The speeds settings (250k, 1M, 2M) are not the same as the power settings (Low, Med, High, Max).
            @Fabien said:
            @NeverDie : Can you please post the sketch you use to test your NRFs modules. I just recieve 10 today from Itead. Same packaging that the ones you recieve. I just want to compare result in same conditions.
            OK, sure. It started out as RF toy code, and then I just evolved it. It contains a lot of commented out code that I haven't bothered to delete. If that gets in the way of your understanding, just delete the code that's commented out. Aside from that, it's straightforward.
            Here's the main transmitter code. After compiling and uploading, you should open a serial window on your computer to read the statistics it prints out:
             nRF24Sender Demo for RFToy
             This demo shows how to use RFToy to make a
             wireless temperature sensor. This is the
             sender module which transmits the current
             temperature value to a receiver module. The
             demo uses the Mirf library.
             This demo uses a 100K resistor and 100K
             thermistor to form a simple temperature
             sensor. Pin A1 is used to read the value.
             The connection is:
             VCC->100K->A1->thermistor->GND
             Written by Jonathan Goldin @ Rayshobby LLC
             Nov 2014
             For details, visit http://rayshobby.net/rftoy
            #include <Mirf.h>
            #include <nRF24L01.h>
            #include <MirfHardwareSpiDriver.h>
            #include <U8glib.h>
            U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);	// I2C / TWI
            void setup(){
               Set ce and csn pins
              Mirf.cePin = 17;
              Mirf.csnPin = 16;
              Mirf.spi = &MirfHardwareSpi;
              Mirf.init();
               * Configure reciving address.
              Mirf.setRADDR((byte *)"clie1");
               * Set the payload length to sizeof(unsigned long) the
               * return type of millis().
               * NB: payload on client and server must be the same.
              //Mirf.payload = sizeof(long);
               * Write channel and payload config then power up reciver.
               * To change channel:
               * Mirf.channel = 10;
               * NB: Make sure channel is legal in your area.
                // we use channel 90 as it is outside of WLAN bands
              // or channels used by wireless surveillance cameras
              //Mirf.channel = 90;
              Mirf.config();
              //This register value is not remembered between power cycles.
              //It defaults to 0x0F.
              //It should be initialized each time if different than 0x0F.
              Mirf.configRegister(RF_SETUP,0x07); //0x0F is 2mbps, max Tx power
                                                  //0x07 is 1mbps, max Tx power
                                                  //0x2F is 250kbps, max Tx power.
              Serial.println("OTA datarate set to  1Mbps.  Transmit Power set to Maximum.");
              // Read and print RF_SETUP
             byte rf_setup = 0;
             Mirf.readRegister( RF_SETUP, &rf_setup, sizeof(rf_setup) );
             Serial.print( "rf_setup = " );
             Serial.println( rf_setup, BIN );
              // OLED
              u8g.firstPage();
              do{
                uint8_t h;
                u8g.setFont(u8g_font_10x20);
                u8g.setFontRefHeightText();
                u8g.setFontPosTop();
                h = u8g.getFontAscent()-u8g.getFontDescent();
                u8g.drawStr(29,(u8g.getHeight()-h)/2,"Tx Sender");
              while(u8g.nextPage());
              Mirf.setTADDR((byte *)"serv1");
              Serial.write("Sending...\r\n");
              delay(200);
            } // End of *Setup*
            long temp;
              int temp1;
              int temp2;
              long timeTxSent;
              long timeRxReceived;
              long roundTrip;
              byte age1=52;
              byte age2=11;
              long txCounter=0;
              long matchCount=0;
              long differentCount=0;
              long lostCount=0;
              long cumulativeRoundTrip=0;
              long averageRoundTrip=0;
              boolean packetLost=false;
              float packetErrorRate=0;  //no errors yet, and maybe there never will be.
              float lostPacketRate=0;  //no packets lost yet.
              const int statusFrequency=500;  //How many iterations of main loop before printing status info.
              long minRoundTrip=9999; //value will be driven down when program runs
              long maxRoundTrip=0;  //value will be driven up when program runs
            void loop(){
              txCounter++;
              packetLost = false;  //It can't be lost, because it hasn't even been sent yet.
              temp = txCounter;  //getTemp(resistance);
              temp1=temp;
              timeTxSent=micros();
              Mirf.send((byte *)&temp);
              while(Mirf.isSending()){
              Serial.write("temp=");
              Serial.print(temp,DEC);
              Serial.write("\r\n");
              Serial.write("temp1=");
              Serial.print(temp1,DEC);
              Serial.write("Finished sending.\r\n");
              //delay(10);
              unsigned long time = millis();
              while ((!packetLost) && (!Mirf.dataReady())){
                //Serial.println("Waiting");
                if ( ( millis() - time ) > 8 ) {
                  //Serial.println("Timeout on response from Rx Echo Reflector!");
                  lostCount++;
                  packetLost=true;
              if (!packetLost) {
              Mirf.getData((byte *) &temp);
              timeRxReceived=micros();
              temp2 = temp;
              roundTrip =  timeRxReceived - timeTxSent;
              if (roundTrip < minRoundTrip) {
                minRoundTrip=roundTrip;
              if (roundTrip > maxRoundTrip) {
                maxRoundTrip = roundTrip;
              if(temp1 == temp2){
                matchCount++;
                cumulativeRoundTrip += roundTrip;
                averageRoundTrip = cumulativeRoundTrip/(txCounter-lostCount-differentCount);
                differentCount++;
                Serial.println("***DIFFERENT**");
                  Serial.println(temp1, BIN);
                  Serial.write("temp2=");
                  Serial.println(temp2, BIN);
              if ((txCounter%statusFrequency)==0) {
                if(temp1 == temp2){
                  Serial.print("Match");
                else {
                Serial.write(",");
              lostPacketRate = 100*((float)(lostCount))/((float)txCounter);
                Serial.print(txCounter);
                Serial.write(",lost=");
                Serial.print(lostPacketRate);
                Serial.write("%,T=");
                //Serial.write(".  ");
                Serial.write(",T1=");
                Serial.write(",T2=");
                Serial.print(temp2,DEC);
                Serial.write("%,RT=");
                Serial.print(roundTrip,DEC);
                Serial.write(",minRT=");
                Serial.print(minRoundTrip);
                Serial.write(",maxRT=");
                Serial.print(maxRoundTrip);
                Serial.write(",aRT=");
                Serial.print(averageRoundTrip,DEC);
                Serial.print(",#lost=");
                Serial.print(lostCount);
                //Serial.write(",mat=");
                //Serial.print(matchCount);
                Serial.write(",diff=");
                Serial.print(differentCount);
                delay(100); //give time for it to print out
                //txCounter = 0;  //restart gathering statistics
              delay(1000);  // keep the 'sending' message displayed on OLED for 1 sec
              u8g.firstPage();
              do{
              } while(u8g.nextPage());
              delay(2000);  // wait for 2 seconds till next transmission
            }  //End of main loop.
            Here's the code for the receiver node. It doesn't need to be plugged into a computer:
             nRF24Receiver Demo for RFToy
             receiver module which displays the received
             temperature value to OLED. The demo uses
             the Mirf library.
             Nov 2014
            #include <Mirf.h>
            #include "U8glib.h"
            void setup(){
              Serial.println("Echo Receiver.  Listening");
              Mirf.cePin = 17;  //???
              Mirf.csnPin = 16;  //???
               * Set the SPI Driver.
               * Setup pins / SPI.
              Mirf.init();
              Mirf.setRADDR((byte *)"serv1");
              Mirf.config();
             byte rf_setup = 0;
              u8g.firstPage();
              do{
                uint8_t h;
                u8g.drawStr(19,(u8g.getHeight()-h)/2,"Echo Rx");
            }  //End of *Setup* procedure
            void loop(){
               * A buffer to store the data.
              byte data[Mirf.payload];
               * If a packet has been recived.
               * isSending also restores listening mode when it
               * transitions from true to false.
              if(!Mirf.isSending() && Mirf.dataReady()){
                //Serial.print("Got packet: ");
                 * Get load the packet into the buffer.
                Mirf.getData(data);
                // Set the send address.
                Mirf.setTADDR((byte *)"clie1");
                 * Send the data back to the client.
                Mirf.send(data);
                 * Wait untill sending has finished
                 * NB: isSending returns the chip to receving after returning true.
                //Serial.println("Reply sent.");
            As background, here's a link to the RFToy:
            http://rayshobby.net/rftoy/
            Links to the RFToy library, as well as the hardware design, can be found there. It's all open source.
            This shows the pin assignments: https://github.com/rayshobby/rftoy-hw/blob/master/RFToy.png
            You'll need a pinout diagram to match-up those internal pins to the physical pins of whatever Arduino you're using. For instance, for an Uno, here's a pinout diagram which maps internal pins to physical pins:
            http://marcusjenkins.com/wp-content/uploads/2014/06/ARDUINO_V2.png
            That way you'll know how to properly wire-up your NRF24L01+ so that it works properly with the library code.
            So, I did that just now and tested it on the UNO, and so for the UNO the simplified wiring directions are:
            NRF24L01+Pin --- --> Uno Female Header Pin
            GND (1) ----------------------------> GND
            VCC (2) -----------------------------> 3.3V
            CE (3) ------------------------------> A3
            CSN (4) -------------------------------> A2
            SCK (5) --------------------------------> D13
            MOSI (6) --------------------------------> D11
            MISO (7) --------------------------------> D12
            IRQ(8) ---------------------------------> n/a
            The RFToy has an OLED screen that gets written to. You can remove that code if you wish, but leaving it in does no harm, even if you don't have an OLED screen on your arduino. I modified the code so that it's only written to during the setup loop, so regardless it shouldn't interfere with any of the measurements taken in the main loop..
            Hope that helps!
            parachutesjP
            parachutesjP
            parachutesj
            I just compiled and uploaded your code to two uno's and all I am getting is
            rf_setup = 111
            Sending...
            how long does it take to get any output on the serial monitor?
            • parachutesjP parachutesj
              rf_setup = 111
              Sending...
              @parachutesj
              I was using 3.3v pro mini's, not uno's. Maybe you have a level shift problem.
              parachutesjP 1 Reply Last reply
                @parachutesj
                parachutesjP
                parachutesjP
                parachutesj
                ok, thank you. using Nano's work. getting 13% loss is not too bad
                • GertSandersG GertSanders
                  @GertSanders
                  In your experience, which of the SMD modules have you found work the best?
                    @GertSanders
                    GertSandersG
                    GertSandersG
                    GertSanders
                    #212
                    So far I have only used this small SMD version
                    I bought it on Aliexpress:
                    http://www.aliexpress.com/item/5pcs-Free-Shipping-NRF24l01-2-4GHz-Wireless-Module-Mini-Version/32430542898.html
                      @GertSanders
                      Are you happy with their performance? I imagine the answer is yes, but I thought I'd ask just to be sure.
                        @GertSanders
                        GertSandersG
                        GertSandersG
                        GertSanders
                        I am, there is one on my front door, which needs to cross two floors to get to the gateway in the attic. Bleeps every time. Range (as far as I can see) is close to the classic small version.
                        Good enough for me.
                          Good enough for me.
                          #215
                          @GertSanders
                          Thanks! I just now ordered some of the same SMD modules using the link you provided. The last time I looked into this (at the start of this thread), it seemed as though just about everyone was using a different mix of modules and platforms. and that made an apples-to-apples performance comparison quite difficult. However, this time around, I'll be running the same modules as you on the same hardware platform as you (well, nearly so, assuming I build it to spec), and so if it works well for you it presumably should work the same for me too.
                          • HarrySteffH
                            HarrySteffH
                            HarrySteff
                            Good morning together, iam very new in mysensors forum, so this is my first post, and i have a question: a want to buy these NRF's can somebody tell me if they are okay?
                            https://www.amazon.de/Kuman-nRF24L01-Wireless-Transceiver-Compatible/dp/B01BVAAASY/ref=sr_1_fkmr0_1?ie=UTF8&qid=1464158231&sr=8-1-fkmr0&keywords=nordic+nrf24l01+10pcs
                            Thank you!
                            AWIA 1 Reply Last reply
                            • HarrySteffH HarrySteff
                              Thank you!
                              AWIA
                              AWIA
                              AWI
                              @HarrySteff There is no way (that I know of) to determine in advance if the modules work according to specification. Even different lots from the same supplier can vary in performance. I have a 5 out of 6 succes rate with different suppliers.
                              • HarrySteffH
                                HarrySteffH
                                HarrySteff
                                Thank you @AWI i will Order them to Test...
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  I have had an excellent experience with the SMD version. I cannot say if there are different versions of it, but all transceivers I purchased from different suppliers work flawlessly.
                                  S parachutesjP 2 Replies Last reply
                                  • alexsh1A alexsh1
                                    Samuel235
                                    @alexsh1 Do you have any links for the SMD versions that you can recommend, i'm wanting to try these now. Thanks.
                                    MySensors 2.1.1
                                    alexsh1A 1 Reply Last reply
                                    • S Samuel235
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #221
                                      @Samuel235 these were the ones I ordered last time. Tested all of them and very much pleased
                                      Look what I found on AliExpress
                                      http://s.aliexpress.com/ZfArmaqe
                                      • alexsh1A alexsh1
                                        parachutesjP
                                        parachutesjP
                                        parachutesj
                                        @alexsh1
                                        At which settings do you use them?
                                        I have those http://www.aliexpress.com/item/10PCS-LOT-NRF24L01-wireless-data-transmission-module-2-4G-the-NRF24L01-upgrade-version/1593276910.html
                                        And not so happy as they seem to loose connection from time to time over distance of 4-5m
                                        I set them at 250 and have good power & caps attached
                                        At least the chip seems to be original but not soldered very well
                                          @alexsh1
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @parachutesj I'll be honest with you - so far I had more luck with the SMD version which works 20m+ across a few walls than with a regular transceivers. Sometimes one needs to invite a shaman to make sure that nrf24l01+ works.
                                          I have 250kb rate on all nodes + caps. All works fine. With some regular nrf24l01+ I had issues with some batches and claimed money back successfully after ditching the whole batch. Luckily, this bad batch has not been working at all rather than working intermittently.
                                          Just a suggestion - did you change any settings on your gateway nrf24l01+? I'm using the amplified version by the way feeding it through AMS1117 LDO
