  3. Which are the *best* NRF24L01+ modules?
310 Posts 42 Posters 345.7k Views 37 Watching
  • A Avamander
    Would it be possible that someone would create a sketch that would detect fake modules and warn about discrepancies? I would hate to spend more money on fake modules.
    Yes, but currently the 'scene' is not aware of a decent way to distinguish fake from real.
    As soon as we know how to determine this a sketch can be written.
    • A
      Avamander
      Speed is one thing that can be tested, fakes are slower. Packet loss too. ACK with dynamic payloads too. Registers that exist only on fakes (the datasheet error one for example).
      • A Avamander
        I suppose you mean the maximum bitrate possible?
        Most fakes will handle all nRF bitrates flawlessly.
        Packet loss too
        I have not seen any proof of differences in reception between reals & fakes.
        The construction & orientation of the module on which the nRF is mounten will IMHO mostly determine the transmission quality.
        I'd like to see an algorithm which reliably determines fakes from real using packet loss.
        This is claimed to be a difference and it might be true for some modules, but all my fakes behave identical on-air compared with real nRF's (verified by sniffer)
        Again, the web is full of contradictory reports...
        Most of these fakes are very good copies and I doubt if anyone can find a software-only solution to determine real from fakes reliably.
        Our best bet would be to create an accurate power fingerprint of a genuine module and compare the fakes to it -- that's the only more or less consistent difference I've seen so far.
        Remember that even Nordic will perform an X-Ray on a suspicious nRF to be absolutely sure if its genuine or not.
        That said -- be my guest and try to create a sketch. The scene will thank you for it if you succeed ;-)
          #201
          The power fingerprint seems to work very well. I suggest you use that. The work is already done (see above).
          • N
            N
            nftrix
            wrote on last edited by nftrix
            #202
            Lots of useful info here, thanks everyone for the hard work!
            Based on the findings, are the NRF24L01+ modules linked on the shop page still the best recommendation? Is it worth adding the cap as a required part of the setup to increase reliability?
            Just received 20 units from the vendor linked through aliexpress and am working through issues which appear to be related to the radios (not using cap's currently)
            Starting...
            find parent
            send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
            find parent
            find parent
            find parent
            find parent
            sensor started, id=255, parent=255, distance=255
            S 1 Reply Last reply
            • N nftrix
              Starting...
              find parent
              find parent
              find parent
              find parent
              find parent
              Samuel235
              @nftrix I'm using nRF24L01+'s for all of my applications at the moment still with no issues at all. They are running perfectly smooth, without interference off of anything. I personally just soldered my caps straight onto my radios when they arrived, before even testing them. If you're not restricted by space, just solder/attach them straight to the module as they arrive through your door.
              As with your issue that you have shown, i would say give the cap a try before jumping to conclusions as it appears that its sending out a message asking the gateway to reply back with a connection package but its not finding it (I may be wrong, but that is what i see there). Give it a try and report back with your findings :)
              MySensors 2.1.1
              • GertSandersG
                GertSandersG
                GertSanders
                @nftrix Another way to deal with the fact that some nrf24l01+ modules can not find the gateway, is by reducing the transmit powerlevel. Some of these modules "scream" so loud, that the receiver on the gateway gets a distorted signal and fails to recognise a proper packet.
                In my house I have had to reduce the transmit levels of most of my modules, and as a result they now all connect to the gateway without any caps.
                The NRF24 on the gateway does have a potent powersupply and caps on the board it is mounted on, but my sensornodes do not need it.
                • N
                  N
                  nftrix
                  @samuel235 @GertSanders thanks for the feedback. I'm picking up some caps from the store today and will try them out. As for the power settings, I've been adjusting the data rate settings between 250kbs, 1 and 2Mbps but am seeing the same results. If the caps don't fix the issue, i'll start another thread to work through the problem, don't want to hijack this thread.
                  Just wanted to confirm that the findings here did not make the NRF's on the store "not recommended" or anything.
                  • N nftrix
                    Samuel235
                    Most definitely not. They're more than recommended from most of us i think, from a quick look at the forum topics anyway.
                    MySensors 2.1.1
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      The speeds settings (250k, 1M, 2M) are not the same as the power settings (Low, Med, High, Max).
                        @Fabien said:
                        @NeverDie : Can you please post the sketch you use to test your NRFs modules. I just recieve 10 today from Itead. Same packaging that the ones you recieve. I just want to compare result in same conditions.
                        OK, sure. It started out as RF toy code, and then I just evolved it. It contains a lot of commented out code that I haven't bothered to delete. If that gets in the way of your understanding, just delete the code that's commented out. Aside from that, it's straightforward.
                        Here's the main transmitter code. After compiling and uploading, you should open a serial window on your computer to read the statistics it prints out:
                         nRF24Sender Demo for RFToy
                         This demo shows how to use RFToy to make a
                         wireless temperature sensor. This is the
                         sender module which transmits the current
                         temperature value to a receiver module. The
                         demo uses the Mirf library.
                         This demo uses a 100K resistor and 100K
                         thermistor to form a simple temperature
                         sensor. Pin A1 is used to read the value.
                         The connection is:
                         VCC->100K->A1->thermistor->GND
                         Written by Jonathan Goldin @ Rayshobby LLC
                         Nov 2014
                         For details, visit http://rayshobby.net/rftoy
                        #include <Mirf.h>
                        #include <nRF24L01.h>
                        #include <MirfHardwareSpiDriver.h>
                        #include <U8glib.h>
                        U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);	// I2C / TWI
                        void setup(){
                           Set ce and csn pins
                          Mirf.cePin = 17;
                          Mirf.csnPin = 16;
                          Mirf.spi = &MirfHardwareSpi;
                          Mirf.init();
                           * Configure reciving address.
                          Mirf.setRADDR((byte *)"clie1");
                           * Set the payload length to sizeof(unsigned long) the
                           * return type of millis().
                           * NB: payload on client and server must be the same.
                          //Mirf.payload = sizeof(long);
                           * Write channel and payload config then power up reciver.
                           * To change channel:
                           * Mirf.channel = 10;
                           * NB: Make sure channel is legal in your area.
                            // we use channel 90 as it is outside of WLAN bands
                          // or channels used by wireless surveillance cameras
                          //Mirf.channel = 90;
                          Mirf.config();
                          //This register value is not remembered between power cycles.
                          //It defaults to 0x0F.
                          //It should be initialized each time if different than 0x0F.
                          Mirf.configRegister(RF_SETUP,0x07); //0x0F is 2mbps, max Tx power
                                                              //0x07 is 1mbps, max Tx power
                                                              //0x2F is 250kbps, max Tx power.
                          Serial.println("OTA datarate set to  1Mbps.  Transmit Power set to Maximum.");
                          // Read and print RF_SETUP
                         byte rf_setup = 0;
                         Mirf.readRegister( RF_SETUP, &rf_setup, sizeof(rf_setup) );
                         Serial.print( "rf_setup = " );
                         Serial.println( rf_setup, BIN );
                          // OLED
                          u8g.firstPage();
                          do{
                            uint8_t h;
                            u8g.setFont(u8g_font_10x20);
                            u8g.setFontRefHeightText();
                            u8g.setFontPosTop();
                            h = u8g.getFontAscent()-u8g.getFontDescent();
                            u8g.drawStr(29,(u8g.getHeight()-h)/2,"Tx Sender");
                          while(u8g.nextPage());
                          Mirf.setTADDR((byte *)"serv1");
                          Serial.write("Sending...\r\n");
                          delay(200);
                        } // End of *Setup*
                        long temp;
                          int temp1;
                          int temp2;
                          long timeTxSent;
                          long timeRxReceived;
                          long roundTrip;
                          byte age1=52;
                          byte age2=11;
                          long txCounter=0;
                          long matchCount=0;
                          long differentCount=0;
                          long lostCount=0;
                          long cumulativeRoundTrip=0;
                          long averageRoundTrip=0;
                          boolean packetLost=false;
                          float packetErrorRate=0;  //no errors yet, and maybe there never will be.
                          float lostPacketRate=0;  //no packets lost yet.
                          const int statusFrequency=500;  //How many iterations of main loop before printing status info.
                          long minRoundTrip=9999; //value will be driven down when program runs
                          long maxRoundTrip=0;  //value will be driven up when program runs
                        void loop(){
                          txCounter++;
                          packetLost = false;  //It can't be lost, because it hasn't even been sent yet.
                          temp = txCounter;  //getTemp(resistance);
                          temp1=temp;
                          timeTxSent=micros();
                          Mirf.send((byte *)&temp);
                          while(Mirf.isSending()){
                          Serial.write("temp=");
                          Serial.print(temp,DEC);
                          Serial.write("\r\n");
                          Serial.write("temp1=");
                          Serial.print(temp1,DEC);
                          Serial.write("Finished sending.\r\n");
                          //delay(10);
                          unsigned long time = millis();
                          while ((!packetLost) && (!Mirf.dataReady())){
                            //Serial.println("Waiting");
                            if ( ( millis() - time ) > 8 ) {
                              //Serial.println("Timeout on response from Rx Echo Reflector!");
                              lostCount++;
                              packetLost=true;
                          if (!packetLost) {
                          Mirf.getData((byte *) &temp);
                          timeRxReceived=micros();
                          temp2 = temp;
                          roundTrip =  timeRxReceived - timeTxSent;
                          if (roundTrip < minRoundTrip) {
                            minRoundTrip=roundTrip;
                          if (roundTrip > maxRoundTrip) {
                            maxRoundTrip = roundTrip;
                          if(temp1 == temp2){
                            matchCount++;
                            cumulativeRoundTrip += roundTrip;
                            averageRoundTrip = cumulativeRoundTrip/(txCounter-lostCount-differentCount);
                            differentCount++;
                            Serial.println("***DIFFERENT**");
                              Serial.println(temp1, BIN);
                              Serial.write("temp2=");
                              Serial.println(temp2, BIN);
                          if ((txCounter%statusFrequency)==0) {
                            if(temp1 == temp2){
                              Serial.print("Match");
                            else {
                            Serial.write(",");
                          lostPacketRate = 100*((float)(lostCount))/((float)txCounter);
                            Serial.print(txCounter);
                            Serial.write(",lost=");
                            Serial.print(lostPacketRate);
                            Serial.write("%,T=");
                            //Serial.write(".  ");
                            Serial.write(",T1=");
                            Serial.write(",T2=");
                            Serial.print(temp2,DEC);
                            Serial.write("%,RT=");
                            Serial.print(roundTrip,DEC);
                            Serial.write(",minRT=");
                            Serial.print(minRoundTrip);
                            Serial.write(",maxRT=");
                            Serial.print(maxRoundTrip);
                            Serial.write(",aRT=");
                            Serial.print(averageRoundTrip,DEC);
                            Serial.print(",#lost=");
                            Serial.print(lostCount);
                            //Serial.write(",mat=");
                            //Serial.print(matchCount);
                            Serial.write(",diff=");
                            Serial.print(differentCount);
                            delay(100); //give time for it to print out
                            //txCounter = 0;  //restart gathering statistics
                          delay(1000);  // keep the 'sending' message displayed on OLED for 1 sec
                          u8g.firstPage();
                          do{
                          } while(u8g.nextPage());
                          delay(2000);  // wait for 2 seconds till next transmission
                        }  //End of main loop.
                        Here's the code for the receiver node. It doesn't need to be plugged into a computer:
                         nRF24Receiver Demo for RFToy
                         receiver module which displays the received
                         temperature value to OLED. The demo uses
                         the Mirf library.
                         Nov 2014
                        #include <Mirf.h>
                        #include "U8glib.h"
                        void setup(){
                          Serial.println("Echo Receiver.  Listening");
                          Mirf.cePin = 17;  //???
                          Mirf.csnPin = 16;  //???
                           * Set the SPI Driver.
                           * Setup pins / SPI.
                          Mirf.init();
                          Mirf.setRADDR((byte *)"serv1");
                          Mirf.config();
                         byte rf_setup = 0;
                          u8g.firstPage();
                          do{
                            uint8_t h;
                            u8g.drawStr(19,(u8g.getHeight()-h)/2,"Echo Rx");
                        }  //End of *Setup* procedure
                        void loop(){
                           * A buffer to store the data.
                          byte data[Mirf.payload];
                           * If a packet has been recived.
                           * isSending also restores listening mode when it
                           * transitions from true to false.
                          if(!Mirf.isSending() && Mirf.dataReady()){
                            //Serial.print("Got packet: ");
                             * Get load the packet into the buffer.
                            Mirf.getData(data);
                            // Set the send address.
                            Mirf.setTADDR((byte *)"clie1");
                             * Send the data back to the client.
                            Mirf.send(data);
                             * Wait untill sending has finished
                             * NB: isSending returns the chip to receving after returning true.
                            //Serial.println("Reply sent.");
                        As background, here's a link to the RFToy:
                        http://rayshobby.net/rftoy/
                        Links to the RFToy library, as well as the hardware design, can be found there. It's all open source.
                        This shows the pin assignments: https://github.com/rayshobby/rftoy-hw/blob/master/RFToy.png
                        You'll need a pinout diagram to match-up those internal pins to the physical pins of whatever Arduino you're using. For instance, for an Uno, here's a pinout diagram which maps internal pins to physical pins:
                        http://marcusjenkins.com/wp-content/uploads/2014/06/ARDUINO_V2.png
                        That way you'll know how to properly wire-up your NRF24L01+ so that it works properly with the library code.
                        So, I did that just now and tested it on the UNO, and so for the UNO the simplified wiring directions are:
                        NRF24L01+Pin --- --> Uno Female Header Pin
                        GND (1) ----------------------------> GND
                        VCC (2) -----------------------------> 3.3V
                        CE (3) ------------------------------> A3
                        CSN (4) -------------------------------> A2
                        SCK (5) --------------------------------> D13
                        MOSI (6) --------------------------------> D11
                        MISO (7) --------------------------------> D12
                        IRQ(8) ---------------------------------> n/a
                        The RFToy has an OLED screen that gets written to. You can remove that code if you wish, but leaving it in does no harm, even if you don't have an OLED screen on your arduino. I modified the code so that it's only written to during the setup loop, so regardless it shouldn't interfere with any of the measurements taken in the main loop..
                        Hope that helps!
                        parachutesjP
                        parachutesjP
                        parachutesj
                        I just compiled and uploaded your code to two uno's and all I am getting is
                        rf_setup = 111
                        Sending...
                        how long does it take to get any output on the serial monitor?
                        • parachutesjP parachutesj
                          rf_setup = 111
                          Sending...
                          @parachutesj
                          I was using 3.3v pro mini's, not uno's. Maybe you have a level shift problem.
                          parachutesjP 1 Reply Last reply
                            @parachutesj
                            parachutesjP
                            parachutesjP
                            parachutesj
                            ok, thank you. using Nano's work. getting 13% loss is not too bad
                            • GertSandersG GertSanders
                              @GertSanders
                              In your experience, which of the SMD modules have you found work the best?
                                @GertSanders
                                GertSandersG
                                GertSandersG
                                GertSanders
                                #212
                                So far I have only used this small SMD version
                                I bought it on Aliexpress:
                                http://www.aliexpress.com/item/5pcs-Free-Shipping-NRF24l01-2-4GHz-Wireless-Module-Mini-Version/32430542898.html
                                  @GertSanders
                                  Are you happy with their performance? I imagine the answer is yes, but I thought I'd ask just to be sure.
                                    @GertSanders
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    I am, there is one on my front door, which needs to cross two floors to get to the gateway in the attic. Bleeps every time. Range (as far as I can see) is close to the classic small version.
                                    Good enough for me.
                                      Good enough for me.
                                      #215
                                      @GertSanders
                                      Thanks! I just now ordered some of the same SMD modules using the link you provided. The last time I looked into this (at the start of this thread), it seemed as though just about everyone was using a different mix of modules and platforms. and that made an apples-to-apples performance comparison quite difficult. However, this time around, I'll be running the same modules as you on the same hardware platform as you (well, nearly so, assuming I build it to spec), and so if it works well for you it presumably should work the same for me too.
                                      • HarrySteffH
                                        HarrySteffH
                                        HarrySteff
                                        Good morning together, iam very new in mysensors forum, so this is my first post, and i have a question: a want to buy these NRF's can somebody tell me if they are okay?
                                        https://www.amazon.de/Kuman-nRF24L01-Wireless-Transceiver-Compatible/dp/B01BVAAASY/ref=sr_1_fkmr0_1?ie=UTF8&qid=1464158231&sr=8-1-fkmr0&keywords=nordic+nrf24l01+10pcs
                                        Thank you!
                                        AWIA 1 Reply Last reply
                                        • HarrySteffH HarrySteff
                                          Thank you!
                                          AWIA
                                          AWIA
                                          AWI
                                          @HarrySteff There is no way (that I know of) to determine in advance if the modules work according to specification. Even different lots from the same supplier can vary in performance. I have a 5 out of 6 succes rate with different suppliers.
